Removing run flats
01-21-2014, 02:03 PM | #1 |
12
Rep 145
Removing run flats
Well the time has come round for a new set of rears and I'm just wondering is it worth getting rid of the RFT?
Would I need to have the sensors programmed out? I don't have a screen only the obc. Thanks |
01-21-2014, 02:51 PM | #2 |
15
Rep 192
I do recommend moving away, If you do change from runflats then you should do all 4 as it's not recommended to only change 2, no sensor coding out as it works out the tyre is flat by looking at the time for the wheel to do one rotation compared to the other.
01-21-2014, 03:33 PM | #4 |
114
Rep 1,058
Drives: G01 BMW X3 30d M Sport Plus
Non fun flats on the rear and run flats on the front will be no problem, it's a not recommended to mix them up on the same axles.
01-21-2014, 04:54 PM | #5 |
Wheelbarrow Edition
60
Rep 1,608
My local place wouldn't fit non rft's to the rear while i still had rft's up front.
Apparently the rear washes away if you run rft's upfront with non rft's on the rear. Id change all 4 personally Last edited by Jase 320d; 01-21-2014 at 05:44 PM.. |
01-21-2014, 05:37 PM | #6 | |
Beemer Heaven
462
Rep 2,941
Drives: BMW M4 Competition
Garage List 2018 BMW F82 M4 Comp [0.00]
2017 BMW F30 330d M ... [0.00] 2014 BMW F30 330d M ... [0.00] 2009 BMW E90 330d M ... [0.00] 2006 BMW E90 330d M ... [0.00] 2002 BMW E46 325i S ... [0.00] |
I would change all four rather than mixing RFT and none RFT on a car.
Scott
2018 BMW M4 Competition 2019 Mini Countryman Cooper S : 2008 Mini Cooper |
01-21-2014, 05:38 PM | #7 |
118
Rep 2,216
Drives: E91 330d M Sport
Oh well, their loss. Absolutely no difference in grip between RFT and normal tyres. I'd change all 4 too, and sell the part worns on ebay or on here - but there's no issue with having them on just one axle.
Just how many Yorkshire sheep can you fit inside one exhaust?
01-21-2014, 05:44 PM | #8 |
Wheelbarrow Edition
60
Rep 1,608
01-22-2014, 01:15 AM | #9 |
53
Rep 1,249
What do you lot do if you ever get a puncture?
Ive thought about doing these to try and save my poor kids in the back as its a very bumpy ride snd even worse back there
E90 lci 330d, alpine white, pro nav, adaptive xenons, heated electric leather, folding mirrors, alpine retrofit kit with L7 subs, performance grilles, 40w led angel eye bulbs
01-22-2014, 03:08 AM | #10 |
Rep 106
I have non- RFT on the back and RFT on the front. No problems what so ever and have been on for about 2 months.
I have a genuine BMW inflater an genuine tyre weld should I get a puncture. |
01-22-2014, 03:55 AM | #11 |
Wheelbarrow Edition
60
Rep 1,608
do you push it though....
The rft can take higher cornering speeds as it stays flatter to the road as there is very little sidewall flex. A non rft will break away earlier as it has more give in it. Well thats what i have been lead to believe |
01-22-2014, 04:36 AM | #12 |
Rep 13
Have always stuck with RFT as saved many a time stuck on the m3 in the cold and dark!
Never noticed that much of a price difference either.....about £40 difference? Would happily pay 40 quid to let me get home rather than stranded mucking about on the side of the road. |
01-22-2014, 06:42 AM | #13 |
7
Rep 35
I was wondering what the neatest setup would be when using non rft. I bought my car from a guy who's fitted continentals but I don't have a back up plan at the moment if there's a flat!
01-22-2014, 06:44 AM | #14 |
Photographer
412
Rep 2,643
Stiff sidewall will break away sooner but more controlled.
Soft sidewall will hold on longer, but break away more harshly. I have RFTs on the back, nons on the front, front has a huge amount more grip, back end loves to step out of roundabouts if prodded, DSC goes crazy. |
01-22-2014, 06:47 AM | #15 |
100
Rep 476
I have RFT's on the back. Michelin ZR's and Non RFT's on the front. This after 10k is a lot better for me. No tram linning or pulling from the front. Handles better also. I'm sure it might handle slightly better with NON RFT's at the back also, but i carry no spare wheel.
01-22-2014, 10:33 AM | #18 |
56
Rep 1,241
Go bother some american on your forum!
01-22-2014, 10:34 AM | #19 |
56
Rep 1,241
Thats the biggest load of sausage meat i have ever heard!
01-22-2014, 10:43 AM | #20 |
Wheelbarrow Edition
60
Rep 1,608
01-22-2014, 11:34 AM | #21 | |
31
Rep 559
Now I am really puzzled, on the tech forum post MIXED TYRES you say mixing tyres is stupid idea? |
