335d SCR Catalytic Converter/Center Muffler
01-17-2014, 05:09 PM | #1 |
614
Rep 2,410
http://www.realoem.com/bmw/showparts...15&hg=18&fg=10
Have been looking for a good deal on this for awhile to further some modifications. The realoem price is hugely inflated if you are patient and have time to wait... Finally found a good deal on a new unit, and bought it. Thought I'd share some details with the community. It weighs just under 40 lbs. The diameter of the opening (without the DEF "mixer") that mates to the DPF unit is just under 3" diameter with an outside pipe circumference of ~9.4". This is the minimum circumference of this entire section, and most likely the maximum restriction based on cross section area. The pipe turns from round to oval shortly after the DPF connection. The diameter of this pipe up to the catalyst has a minimum circumference of ~10" at the input to the catalyst where the pipe then flares outward to meet the larger area of the catalyst. Post catalyst the oval is quite large at ~ 13", then slowly necks down to the dual pipe connection where it is ~11.5" by the 2nd NOx probe/sensor. The dual pipe sections are ~7.5" circumference everywhere except for one bend that necks down to ~7.25". The combination of the dual path pipe, even with the neckdown point on the one side, seems quite sufficient and should not be the limitation in this section. There may be some work coming along where there will be some interesting exhaust work done in conjunction with the Ecotune modifications... If anyone is interested in some particular data/measurements related to this item before it becomes altered, please let me know. Otherwise it might be too late. Last edited by TDIwyse; 01-17-2014 at 06:49 PM.. Reason: Changed "diameter" to "circumference" in 2 places... |
01-17-2014, 06:34 PM | #3 |
765
Rep 3,557
haha, TDI i think you said diameter a couple times when you meant circumference. 7.25" diameter, that would be huge, right?
I have a tape called a "Pi" tape. It is a very flexible tape made for bending around not perfectly circular cross section. As you might guess, it is off by the factor Pi so that even though you are measuring around the circumference, the readout is diameter in inches as C=Pi*D. I think i got it from mcmaster carr about 10 years ago. |
01-17-2014, 06:43 PM | #4 | |
614
Rep 2,410
01-17-2014, 06:45 PM | #5 |
614
Rep 2,410
01-17-2014, 07:19 PM | #6 |
8
Rep 140
Id like to gut the whole thing myself and just add something to keep the noise down. I love turbo whistle, but ths car is my DD so I don't want it to crazy. Not even to concerned about performance at this point in the game, I just want the sound. Silly slow speed limits really take the joy away from copious amounts of torque.
Anyways keep up the good modding! |
01-18-2014, 10:45 AM | #7 |
765
Rep 3,557
So, did you buy that whole long assy shown in the realOEM link? (EDIT: i studied the pictures and it appears the answer is Yes.) If yes, I'm curious if you are putting your original one on the shelf and modding the new one "in steps" as you stated? I may have some questions on measurements but i can measure my OEM one too.
Welding in your mods or using clamps? Probably a little of both i would think. Best of luck. The pioneer is yet again stepping out on the end of the tree limb ..... Last edited by BB_cuda; 01-18-2014 at 11:12 AM.. |
01-18-2014, 10:58 AM | #8 |
765
Rep 3,557
One more for you please. Since you had the DEF injection tuned out as well, did you drain out the DEF and somehow purge the lines of that system? That urea stuff eventually crystallizes and would clog up. Someone who doesn't intend to use it again may not care but you seem the type to not butcher the OEM equipment (DPF aside ) and save it for a rainy day. Example was where you bought the Ebay EGR cooler to get the water fittings and left your OEM one alone. So, back to my original question. Did you/are you removing the whole SCR system tanks and all? If this were done, i could see how the stuff could be cleaned out with warm distilled water. Just sayin' ....
01-18-2014, 11:42 AM | #9 | |
614
Rep 2,410
I'm planning to alter the one already on the car and keep this new one pristine, in case I want to sell it to recover some of the $'s. Or if things get damaged/messed up with the modifications, I can revert to this new one. It's basically for risk mitigation. Looking at things this morning I may start by cutting off the existing exhaust where the ends of this SCR part stop (so basically the muffler/tips) and using some clamped on angled bends (to direct the exhaust away from the underside of the car) to see what it sounds like "straight piped" but with the mid cat still in place. The end of the SCR section dual pipe diameters is just right for a 2.5" O.D. pipe adapter (had it lying around from my old jeep cummins conversion project) to slip on nice and tight, so making a quick clamp on angle adapter should be easy. Then go to a "test pipe" in place of the mid cat and check sound and boost logs (to make sure "desired" and "actual" are in agreement without any overshoot) with the straight piped situation. But I'm thinking I'll eventually go with a resonator on each dual exhaust section where the mufflers are presently at, but I'd like to learn about the sound/boost impact along the way. |
01-18-2014, 11:48 AM | #10 | |
614
Rep 2,410
Actually, I was contemplating removing the passive tank and keeping the active tank for my water/methanol system tank ... I think that would be kinda neat. |
01-18-2014, 11:49 AM | #11 |
8
Rep 140
when all is said and done, Im thinking straight piped with one or two resonators. I want the turbo to have some sound but I don't want it so loud its all I hear in the cabin. I plan eventually to have a shop weld a single system straight back from the eco tune DP this will allow me to keep my complete exhaust system without damaging anything.
Well that's the plan anyways. |
01-18-2014, 11:51 AM | #12 | |
8
Rep 140
Part of the reason I want to remove the tank is to be able to put a different bumper on there, without the fill door. |
01-18-2014, 01:12 PM | #13 | |
614
Rep 2,410
01-19-2014, 06:40 AM | #14 | |
96
Rep 1,592
Drives: 2011 335d, M-Sport
(This was obviously a shot of test fitment, final will be cleaner) Honestly,I'm most anxious to hear how much weight you are able to drop with a less cluttered DPF-back exhaust design. Did you weigh all the stock components? On a side note, I was able to house the tank and pump in the section above, but if you remove the tank & pumping assembly for the DEF, there is plenty of room for the pump below this compartment (still behind the axel, though)
01-19-2014, 11:20 AM | #15 | ||
614
Rep 2,410
01-19-2014, 03:17 PM | #16 | |
765
Rep 3,557
Also, notice your panel has the hole cut for the cargo "D" hook hardware to mount to chassis. Did your's come that way? I had to get an earlier year E90 panel from salvage yard to mount those cargo hooks. I cut the passenger side OEM one as I had a junk yard piece for a template. |
01-19-2014, 06:08 PM | #17 | ||
96
Rep 1,592
01-19-2014, 06:31 PM | #18 | |
614
Rep 2,410
01-20-2014, 07:49 AM | #19 |
96
Rep 1,592
Well, I knew about it because most folks stateside use it to house aftermarket amps in upgraded stereo systems and was able to ID the piece through realoem, but I found this thread when looking to give more detail here...
http://www.e90post.com/forums/showthread.php?t=419252 This gives all of the details on the full Euro "luggage compartment package". IMO, its probably how the car shouldve come in the first place with the exception of maybe the CD changer compartment. Enjoy. |
01-25-2014, 12:48 PM | #21 |
614
Rep 2,410
Well, straight piping in place of the mufflers actually sounds really good (SCR mid cat is still in place, and the DOC portion inside the DPF canister is still in place). A little rumble on start up, a really faint hint of turbo whistle from the outside, and a nice sound inside the cabin when applying the skinny pedal hard. No drones or resonances that I could find in various driving speeds/rpm's. At cruising speeds it's not really different from how it sounded with the mufflers.
I had been checking out the youtube video's of 335d's straight piped with all the cats/silencers/DPF's out and I really didn't care for the very prominent turbo whistle, and I thought things sounded a little too "metalic" or "tinny". Think I'd get tired of that. But trying to base sounds from youtube/cell phone recordings and video's is not the same as hearing things in person. I like how things sound with the present configuration, so I'm not going to fuss around with the resonators after all. The 2.5" Vibrant Ultra Quiet resonators weight about 6 lbs each on my scale, so they would be ~12 lbs + some pipe to bridge the distance, so probably ~16-17 lbs when its all done. Would still save about 22-23 lbs over OEM. But just having straight pipe (I've got 5 ft of 60mm stainless here) should only be ~6-7 lbs. So that would be a 33-34 lb savings. I tried taking a recording of the sound, but it's too windy (9F air temp with 30mph NW winds) and most of what comes through is just wind noise. |
01-25-2014, 01:13 PM | #22 |
8
Rep 140
Good work! I was thinking of dropping the mufflers and having cyba tips welded in but havent done that due to the up coming dpf delete. Want noise but not to much while cruising. Good to see you making progress
