01-14-2014, 08:42 PM | #1 |
21105
Rep 20,741
Drives: 2021 911 turbo
New 275/35 19 Michelin PSS for the F8X?
When I decided to switch to 275/35R19 tires on my E92, I did some in depth research to understand the differences between a 265/35 and a 275/35 regarding contact patch dimensions and tire weight tradeoff. I came to the conclusion that the 275 offered 20% more rubber on the road vs the 265 mostly due to smaller grooves in the thread.
http://www.m3post.com/forums/showthread.php?t=848092 Based on the picture from the Detroit release, it seems that the 275/35 on the F8X has the wider grooves of the 265 tire (also as on the 235/35, 245/35 and 255/35). See picture below of the 275/35 on my E92 vs the 275/35 on the F80. Last edited by CanAutM3; 02-13-2015 at 08:15 AM.. |
01-14-2014, 08:52 PM | #3 |
21105
Rep 20,741
01-14-2014, 09:03 PM | #5 |
21105
Rep 20,741
01-14-2014, 09:12 PM | #8 |
21105
Rep 20,741
01-14-2014, 09:14 PM | #9 |
3439
Rep 4,981
I'm sure tirerack could answer your question then.
Trying to judge this from differing distances with different wear patterns is only going to lead to guesses. |
01-14-2014, 09:48 PM | #11 | |
5457
Rep 7,037
I'm actually putting on a new set of rears on this Friday after 24k miles on the first set. Superb tires. |
01-14-2014, 09:54 PM | #12 | |
Commander-In-Chief
2070
Rep 8,898
Contact patch
01-15-2014, 08:44 AM | #13 | |
21105
Rep 20,741
However here we are not discussing contact patch size. The contact patch is the the area where the tire deforms to contact the road. The pressure inside the tire times the contact patch area equals the load the tire is carrying (minus the load the sidewall is carrying). This area remains relatively constant regardless of the thread pattern of the tire; this because the air pushes on the inside of the tire and not on the individual thread blocks. So a slick tire will have the same contact patch size (tire deformation) than a wet tire with big grooves (assuming same inflation pressure and sidewall stiffness). However, since the slick tire does not have any grooves, it has much more rubber in contact with the road and therefore more grip. Comparing the two 275/35 PSS tires above, both will have essentially the same contact patch area, but the one with the smaller grooves will have more rubber in contact with the road, hence more grip. Last edited by CanAutM3; 12-28-2015 at 10:12 AM.. |
01-15-2014, 01:42 PM | #14 |
516
Rep 18,858
More rubber in contact with the road does not mean more grip. It means the total distribution of weight is over a larger surface area, so less downward pressure per square inch.
Measuring grip is much more complex than that. |
01-15-2014, 02:42 PM | #15 | |
21105
Rep 20,741
A tire gripping the road is more than just normal force times the friction coefficient as you imply. There are two major components to tire grip: standard friction and rubber element interlocking with the pavement irregularities. The later is directly related to how much rubber is contact with the road. Otherwise, why would race cars use slicks? Last edited by CanAutM3; 01-15-2014 at 03:48 PM.. |
01-15-2014, 03:59 PM | #16 |
430
Rep 4,567
This is the part where I hijack the thread and complain that Michelin has yet to develop a 285/30-19 application of the PSS.
'09 E92 M3: Space Gray, Black, Carbon Leather | ZTP 2MK ZPP 2MT 6FL | link 1 / link 2
Mods: M Performance exhaust | ZCP retrofit | Euro airbox | GTS DCT flash | JPN 240 ECU flash | Euro LCI taillights | CRT lip | OEM alarm retrofit | Space Gray bumper plugs | BMW Performance: Mk. II spoiler / Mk. II non-electronic steering wheel / mirror caps / front grilles / side gills / intake louvers / emblem |
01-16-2014, 02:09 AM | #17 |
609
Rep 10,407
Let's not forget correcting the very common misconception that a wider tire has the same contact area as a narrower tire at the same inflation pressure. This is certainly a bit OT to the OP but was being discussed. This "fact" works for things like spherical balloons, not tires with heavy steel belts, stiff side walls and stiff solid rubber tread blocks.
This myth is very clearly refuted here.
E92 M3 | Space Gray on Fox Red | M-DCT | CF Roof | RAC RG63 Wheels | Brembo 380mm BBK | | Vorsteiner Ti Exhaust | Matte Black Grilles/Side Gills/Rear Emblem/Mirrors | | Alekshop Back up Camera | GP Thunders | BMW Aluminum Pedals | Elite Angels | | XPEL Full Front Wrap | Hardwired V1 | Interior Xenon Light Kit | |
