01-14-2014, 02:56 PM | #1 |
30
Rep 242
Speed Hump Question
So I went over a speed hump earlier, not travelling very fast - I am taking it quite easy at the moment. Big, solid sounding clunk/bang through the car as the rear half travelled over it.
I don't have an aero kit and the car sits reasonably high being x-drive. I do have the adaptive suspension though. Had a quick look around underneath but could not see any obvious damage and i can't believe the hump was high enough to have hit the car at that speed but i can't rule this out. Could this be something to do with the adaptive suspension? I am not referring to the faint clunking noise some have experienced over minor bumps. This seemed more significant and was a one off. Has anyone else with the adaptive dampers experience similar over speed humps? |
01-14-2014, 02:59 PM | #2 |
1875
Rep 3,432
Was the hump one of those that are built out of blocks that are pinned to the road..?
Because sometimes some of the blocks come loose and it's the block banging on the ground you can hear as a bang when you go over them… sounds like it's hitting the car, but it's not (well, it's not on the one like that near me that is like that, anyway)…
CAR HISTORY - Golf GTI 245 - F30 340i M Sport - F30 330d M Sport MPPK - F30 320d Sport - 997 Gen2 GT3 - 987 Cayman S - 986 Boxster S - Ibiza Cupra - Polo 16v - E30 M3 (Official GB import) - Integra 16v - Mk2 Polo S - Mk1 Golf C
01-14-2014, 03:06 PM | #3 | |
Supreme Being
1804
Rep 5,425
I get it all the time and the first few times scare the living c**p out of me. I've had it when hitting even minor pot holes or when one wheel hits a metal drain cover. I 'tested' this was not a one off by taking one of my old routes with a hump-back bridge; the E92 used to fly over it, this one makes a hideous noise! You really have to time the power and coast just right. I've put it down to the xDrive mechanics but I guess the suspension is more likely. I'm not going to worry about it now as I'm half expecting it the whole time.
Current: F90 M5 Competition
Gone: F80 M3 Competition Pack / M135i / F15 X5 M50d / Saab 9-5 Aero HOT / F30 335d xDrive M Sport / E92 LCI 320d M Sport / E46 320d M Sport Touring / E46 318i Touring |
01-14-2014, 03:11 PM | #4 |
12
Rep 153
Same thing happened to me but with the front LHS suspension. Didn't sound good at all (horrid clanking sound). I was going a little to fast at the time. I guess we just need to learn to slow down a bit more when going over speed bumps
01-14-2014, 03:30 PM | #5 |
30
Rep 242
Agreed, i will be taking it very easy, grandma style from now on over the bumps. It scared the cr@p out of me, bearing in mind i only picked the car up on saturday.
The hump wasn't the bolted in block type, but wider than the ones you can often straddle and without much of a curved gradient - particularly nasty and will be avoiding that route from now on. |
01-14-2014, 03:58 PM | #6 |
12
Rep 153
The humps I had trouble with were made from tarmac and are on a long driveway to my local golf driving range (my second home) so route avoidance id not really an option for me -will just take it a bit easier. Don't want to hear that sound ever again!
01-14-2014, 04:35 PM | #7 |
1050
Rep 3,154
Just wondering what the best suspension mode would be to tackle bumps? comfort might be quite wallowy..and potentially cause the car to bounce over?
Sport is firmer so perhaps that would be better? Thanks |
01-14-2014, 05:33 PM | #8 |
Supreme Being
1804
Rep 5,425
I think it's more likely the rebound making the noise, on which basis comfort should be better as it's rebounding slower?!
I hit a bump during heavy breaking from speed the other day - I thought the wheels had come of, or at least would come out square! All seems to be well so I guess we have to live with it!
01-14-2014, 05:46 PM | #9 | |
1983
Rep 3,216
Drive over speed bumps with one side ENTIRELY on the bump, and the other staying on the 'normal' tarmac |
01-14-2014, 09:24 PM | #10 |
2294
Rep 4,451
Never knew this, I generally straddle the bump as it avoids the worst of it, looks like I'll be changing my ways then!
01-15-2014, 02:48 AM | #11 |
Rep 44
Notoriously bad for run flats, had a fairly new tyre on a previous car, lasted about 6k (me stupidly straddling humps) blew out on me after a fairly long motorway journey. Inner edge was ripped open. I don't think it's as bad for standard tyres though. I might be wrong but won't make that mistake again.
01-15-2014, 03:03 AM | #12 | |
2294
Rep 4,451
01-15-2014, 03:05 AM | #13 |
23
Rep 191
I was driving along a country road and went over a relatively slight hump at around 40mph......could have easily been going faster as the road was NSL and clear visibility ahead. I usually do 60 in my merc on this stretch.
The car made a massive bang, so much so that I pulled over to double check I hadn't hit anything or damaged something. Pretty sure I hadn't done either but not a great sound really. |
01-15-2014, 03:07 AM | #14 |
61
Rep 949
Yes, this happened the first time I drove over one. I think the adaptive gets a bit confused and tries to compensate for the "bump" as it does for potholes etc.
I now switch to sport and it goes over much better as the electronics make the dampers have less give in them. |
01-15-2014, 05:06 AM | #16 | |
Supreme Being
1804
Rep 5,425
01-15-2014, 05:33 AM | #17 |
23
Rep 191
01-15-2014, 07:37 AM | #18 |
163
Rep 641
01-15-2014, 12:22 PM | #19 |
1983
Rep 3,216
Go have a chat with a 'proper' tyre fitter. Someone that owns their own business, though even a manager from ATS will be abe to show you the stacks of wrecked inners on tyres.
Or go look on something like honestjohn.co.uk - the number of people reporting issues, and what the professionals view (including tyre makers) is of the cause. The professionals may be wrong, of course. But have a good look at what happens to a car's suspension and tyres when straddling |
01-15-2014, 02:05 PM | #21 |
Rep 10
Funnily enough I was going to post something similar, had a couple of experiences with potholes where y the noise from the front was so bad I had to pull over and was expecting to see a buckled wheel or broken suspension.
Happened again yesterday at 30 mph small pot hole but the bang from the front scared the hell out of me, never come across a car that hits the top of its suspension so easily, surly cant be good for the car |
