29DC plus some fuel codes
01-12-2014, 02:08 PM | #1 |
88
Rep 1,174
Hey guys,
Thanks in advance for your humble opinions. I've read some threads on this, and came to a conclusion that it is most likely my fuel pump(i do have Terrys walbro inline pump upgrade). The car is throwing the 29DC code every time i give it more than 20% throttle. Car shakes, and shortly after, stalls. While the car is cold, it is somewhat drivable, and i can make a 10-15 mile drive in it, but after it warms up it dies as soon as i touch the throttle. I changed out the coils, spark plugs, and the low pressure fuel sensor, yet the problem persists. All i can think is that the walbro went bad? Even tho i installed it less than 6 months ago, and have driven the car maybe 5000 miles since the install. Any ideas? |
01-12-2014, 02:24 PM | #2 | |
34
Rep 1,093
EDIT: Scratch that. I believe I have my codes mixed up and that is actually injection cylinder switch off?. I would suggest you check your high side fuel pressure sensor. If this is good then it is your HPFP not the low side LPFP or booster. If you have a cobb, JB etc. to log with that is probably your cheapest method of troubleshooting unless your still under warranty.
07 335XI (A008006) 6AT ~94K miles JB4 G5 ISO VSRF DP's
09 135I M (VK80379) 6MT. Race Project car. 1) Install Cobb/piggyback? and Motiv 600 Kit[HTA3076R w/ tial .82] 2) JRZ or Moton suspension. 3) Build high flow intake manifold with multi-port fuel and relocate OFH 4) Build full cage 5) Complete staged twin setup with HTA4205R [w/Tial 1.16] 6) Complete dry sump system Last edited by Ingeniator; 01-12-2014 at 03:03 PM.. Reason: mixed up codes. |
01-12-2014, 03:27 PM | #3 | ||
88
Rep 1,174
01-13-2014, 05:11 PM | #5 |
55
Rep 495
I do not know about the code, but symptoms sound like a bad injector. When you changed the spark plugs did you notice any of them darker than the others?
GIAC stage II|AA DP|AA Charge pipe and BOV|AFE S2 Intake|HELIX FMIC
01-13-2014, 05:14 PM | #6 |
88
Rep 1,174
01-13-2014, 06:18 PM | #7 |
40
Rep 623
I'm having the EXACT same issue your having. Injection cylinder switch off. I changed my plugs to see if that helped and I guess move on to coil packs since it doesnt give me a specific cylinder This is what I cant stand though...Start throwing parts at it not knowing if its going to be fixed or not. The car ran completely fine with the stock LPFP and about 8 gallons E85, 4 gallons 93. As soon as I installed, or my buddy installed the Walbro drop in 465LPH fuel pump, this issue comes up immediately. We even went to the extent of taking the fuel pump back out, checking all the lines, making sure everything was perfect and thought it was a faulty pump. I was pissed so we tried my buddy who has a perfectly good walbro 455lph AND SAME SHIT!!! So I have been trying to diagnose this issue FOREVER and am on a mission to make sure I figure this shit out!!!
[SIZE="2"]Crimson Red E92 335i M-sport 6-speed with MHD custom stage 2+ flash only , 40% E85/93 mix,+ HRE P40S wheels, KW Clubsport, M3 sways,+BMW performance CF Mirrors, BMW Performance CF deck lid spoiler,+ CF interior trim, p3 vent boost gauge,+ LUX angel eyes (11.73@124mph on street tires)
01-14-2014, 12:48 PM | #8 | |
88
Rep 1,174
01-14-2014, 01:12 PM | #9 |
Rep 101
Drives: 2009 335i x-drive
I had something similar when I went to the back-end flash. I had all the settings right for my G5 ISO and it still did it. So I reloaded the firmware into the G5 then reset defaults and everything cleared up. Just a thought.
01-14-2014, 01:24 PM | #10 |
88
Rep 1,174
Just turned my car in to the dealer to get injectors replaced. I'll try resetting the flash after i get it back. Thanks for the advice
01-14-2014, 01:30 PM | #11 |
Rep 101
01-14-2014, 01:44 PM | #12 |
88
Rep 1,174
01-14-2014, 02:58 PM | #13 |
456
Rep 6,478
Whenever fuel cuts that abruptly (assuming that is the issue itself, and not merely the resulting outcome of an unrelated problem) I usually look to the high pressure side. Low pressure issues usually involve crappy starts and breaking up, not outright fuel shutoff.
E88 N54 Alpinweiss/Coral Red/Motiv HTA 3586r Tial .82AR/Other stuff...652WHP
F30 N55 XDrive EBII |
