Seat Creak
11-03-2007, 04:59 AM | #1 |
58
Rep 793
Drives: F30 328i
Seat Creak
Anyone here experienced the driver's seat creaking? Mine's started to do this during braking and accelerating, and if you move back and forth in the seat when stationary. I've done a search and found people complaining of this, but not found a definite cause or cure. Time for a trip to the dealer methinks...
Behold! F30 328i M-Sport - Tanzanite Blue with Opal White Leather
11-03-2007, 05:02 AM | #2 |
The Tarmac Terrorist
948
Rep 29,345
Drives: 997.2 GT3
yes i have found the passenger seat squeeks if someone is sat in it! does piss me off, new cars especially BMW's should not do this. I do have a solution though, would you like to hear it....???
Turn DAT DAMN STEREO UP TO DA MAX MO FO
997.2 GT3
11-03-2007, 06:12 AM | #3 |
25
Rep 1,130
get some silicon seal spray... from most autoshops. I sprayed along where the leather(ette) lower parts of the seat rub on the plastic trim, and it sorted out the drivers side... though I need to do the passenger side still.
11-03-2007, 08:45 AM | #4 |
Defected to the dark side.....
210
Rep 5,795
Drives: BMW M5 LCi
My drivers one is doing the same - every time you accelerate away it creaks with your bdy weight pressing against it. - also when you are cornering it creaks
It is going into the dealer on Wed to have the new clutch and flywheel fitted s will mention it and see if they can look at it whilst it's in. I won't hold my breath tho as I asked em to look at it last time they had it. The car got delivered back with the seat still creaking and not a word from the stealer since BMW customer service is lacking in quite a few dealers from what I gather reading some of the recent post's on here! Paul |
11-03-2007, 08:46 AM | #5 |
48
Rep 2,022
Drives: X5 g05
I just want to know what Carlos is doing in the passenger seat to make it creak.
Current: E90 335d (May 2007) | Black/Black | Prof Hifi | Prof Nav | 6FL | Fully Electric Seats | Xenons | Folding Mirrors | PDC
Previous: 325ci Conv. Black/Black with lots of ACS Previous: z3 3.0 Silver with Black&Red Leather |
11-03-2007, 08:49 AM | #6 |
948
Rep 29,345
Drives: 997.2 GT3
997.2 GT3
11-03-2007, 01:51 PM | #7 |
1867
Rep 13,043
Drives: BMW M340I G20
My drivers seat does it.it's the right hand bolster, anoying because ever time I depress the clutch I notice it.
11-03-2007, 05:23 PM | #8 | |
210
Rep 5,795
Drives: BMW M5 LCi
Is that the cause of the creak then - the leather and plastic surfaces rubbing against each other?? anyone got creaking fabric/cloth/alcantara seats? - this may confirm it! |
11-03-2007, 08:42 PM | #9 |
Under the radar
41
Rep 840
Mine does this and I **hate** it. Its a really loud creak, definitely not the leather. Its the seat itself. Its especially bad under acceleration and braking.
11-03-2007, 08:47 PM | #10 |
Moderator
322
Rep 5,493
When you accelerate, does the seat make a clicking sound as your body weight shifts backwards? It does on mine, then clicks when the bodyweight goes forward as I brake. It sounds like a seat-runner bolt is loose and there is movement in the seat frame, but I've gone round with a wrench and tightened everything as much as I can. I've even sprayed lube oil down there, everywhere, but it didn't help. My dealer doesn't even know what it is (although that's not suprising, given the current state of my car )
... ... DMS Remap Review ----- Quaife LSD Review ----- Hartge Antiroll Bars Review ----- Bilstein PSS10 B16 Ride Control Review ----- Detail by ShineOn ----- Paintshield Review |
11-03-2007, 08:52 PM | #11 | |
Moderator
322
Rep 5,493
At the moment, I'm using a leather feed and conditioner from DFS Sofas, but might try the Zymol stuff as it's actually a little cheaper unbelievably!!
11-03-2007, 09:18 PM | #12 | |
Under the radar
41
Rep 840
http://www.e90post.com/forums/showpo...7&postcount=40 |
11-03-2007, 09:21 PM | #13 | |
Moderator
322
Rep 5,493
11-04-2007, 05:58 AM | #14 | |
58
Rep 793
Drives: F30 328i
http://www.e90post.com/forums/showpo...4&postcount=19 and this: http://www.e90post.com/forums/showpo...6&postcount=22 I've booked my car in for next Monday so I'll take this info along so they fix it properly!
11-04-2007, 07:45 AM | #15 | |
Under the radar
41
Rep 840
Yes, my strap was not caught. I will report back if the PB Blaster (lubrication like a really good WD40) does not keep the problem away. The creak was definitely coming from that pivot joint. |
11-06-2007, 03:32 PM | #16 |
1050
Rep 3,154
i had a noise coming from the passenger seat - underneath - so i just sprayed some carbaflo! what a cowboy.. but it did the trick!
pricey stuff but the nuts http://www.carbaflo-direct.com/findoutmore.html |
11-07-2007, 02:43 AM | #17 |
96
Rep 3,465
Ive heard on the grapevine that the volume of the seatcreak is in direct proportion to the size of the arse which is sat upon it
C350 cdi sport estate facelift 457lbft
130i M SportMercedes C350 CDI Sport Estate AutoMini Cooper Auto.Mercedes E250 CGI,Lexus IS-F,R36, RS4 Saloon,ML 420 CDI SPORT,M6, 335d, C55, C32, M3, M5, S3, ALL SOLD but fondly remembered |
11-07-2007, 04:24 AM | #18 |
18
Rep 859
Drives: E92 320i M Sport
11-07-2007, 04:54 AM | #19 | |
58
Rep 793
Drives: F30 328i
11-07-2007, 05:03 AM | #20 | |
18
Rep 859
11-19-2007, 05:25 PM | #21 | |
38
Rep 853
2008 SG E60 535i 2006 AW E90 325i |
11-20-2007, 01:42 AM | #22 |
58
Rep 793
Drives: F30 328i
I did mention it to my dealer's service dept yesterday, said they never heard of it.
