spare wheel
01-11-2014, 04:34 PM | #1 |
Rep 13
spare wheel
Got a E92 330d (pre lci). I'm finally getting rid of the runflats and need a spare wheel. Does anyone have a wheel for sale or can point me in the right direction.
Cheers Davie |
01-11-2014, 06:24 PM | #2 |
11
Rep 314
I got mine off eBay, it's an e46 17" space saver, if you hold out you should get one at a decent price. You'll need a jack etc aswell, again I've got one out of an e46
01-12-2014, 03:05 AM | #4 |
86
Rep 381
Currently two on eBay which will fit your car and end today. I had been looking for two months and non came up so bit the bullet and purchased the rim from the steelers for £146 and got the tyre fitted separately for £65 which worked out still £58 cheaper than the stealers for the wheel/tyre together. Be careful as not many fit on eBay so do your research.
01-12-2014, 09:21 AM | #6 |
337
Rep 1,661
That eBay number comes up with a few full sized E46 wheels - no steel spares.
If you're going for full size, then just get an E9x wheel. The E46 has a different offset to the E9x, so be careful if buying a full size E46 wheel. Others have said that the E46 spare will fit (even with different offset) BUT the 16" ones won't fit over the larger front brakes - as will probably be fitted to your 330d. You need a 17" rim. The E6x wheel does definitely fit, as I have one (that you can't have!). This is probably why E6x wheels are more expensive on eBay than E46 wheels. Mike |
01-12-2014, 10:23 AM | #7 |
86
Rep 381
eBay has two for your car which is the same as mine(330d) 1 ends at 2000hrs and is current
Y on £165 which is for the complete kit and not just the when'll and the other one ends at 2101hrs and is currently at £125 and is the wheel on its own |
01-16-2014, 04:40 PM | #8 | |
Rep 13
01-17-2014, 03:18 AM | #9 |
21
Rep 309
Drives: VW T5 Campervan...
Not sure what e92 330d calipers are like, but my 17" e46 space saver fits over the front calipers on my e90 330i...
