E92 Sirius Module, Bracket and which connector
11-02-2007, 09:45 PM | #1 |
29
Rep 633
While there is a DIY for the E90 version and location of the Sirius module under the trunk pan in the forward part of the trunk, I can't find anything in the search for the E92 driver side side mounted module.
There are 3 separate cables wrapped and ready there, 2 look the same connector wise and the 3rd is the Antenna. Which one is used, and how do you tell, and I obviously have the wrong bracket for the wiring location. Does anyone have the installation sheet for the E92? thx. |
11-02-2007, 10:41 PM | #3 |
532
Rep 4,021
Drives: 2008 335xi Coupe
Here is a pic of my install.... US unit in a Canadian Car...rocks....no Canadian Content BS....
"Aerodynamics are for people who cannot build engines"......Enzo Ferrari
11-02-2007, 10:43 PM | #4 |
اوليسيس
196
Rep 4,678
where did you find it? and what hardware did you use?
11-02-2007, 10:44 PM | #5 |
532
Rep 4,021
It is a kit from www.circlebmw.com. They have an install kit where they put everything together.....awesome....great price too.
11-02-2007, 10:45 PM | #6 |
اوليسيس
196
Rep 4,678
damn....that was quick.
thanks BTW.
11-03-2007, 04:04 PM | #7 | |
29
Rep 633
Just for info, for the E92 with the cabling under the left rear trap door there, you need: Bracket PN: 65-11-0-035-509 (expensive) Trim PN: 51-47-7-122-411 (raises the left side stuff and door accordingly) Radio PN: 65-20-9-142-850 or 65-12-6-987-545 (E92) Here's a link for the BMW E92 Sirius Install .. Left rear cable location |
11-03-2007, 04:40 PM | #8 | |
532
Rep 4,021
Humm......I called the guys at Circle BMW and they told me BMW changed parts a couple of times.... Your car also needs the Satellite pre-install kit.
11-03-2007, 04:43 PM | #9 |
29
Rep 633
yes.. it has that. Pretty easy to tell as the cable plugs are there under the trap door wrapped in velcro blankets. The antenna is obvious, and the shorter of the two that are the same is the plug for the radio. The long one is for the CD.
11-15-2007, 10:57 AM | #10 |
29
Rep 633
Just to summarize, there are three variants of the module number for the Radio, and they all seem to work. I got one of the original part numbers (Nov 2006 unit), and patched it into the MOST fiber ring, had it programmed under Progman 27.02.
All worked. For the past few years, they have been promising to get the Satellite option "soon", but it hasn't happened. So, as it stands, if you want integrated SIRIUS in Canada, you have to make it a DIY as BMW won't sell the parts kit, then you have to find dealer willing to play along to get it into the loop. But it all works great if you do.. Apparently, the Canadian Progman is just like the US version, uncut and uncensored for the great white north. DIY Hint for Canuks: So, for Canadians, Tischer BMW in Maryland will sell you what you need using Canadian dollars, and if you live on the west coast, Brian Jessel will do the programming for you. I believe there is a dealer in Toronto that will do the same. |
11-25-2007, 10:31 PM | #11 |
CHEAT TO WIN!!
99
Rep 1,350
i live in canada also, and i'm not sure if my car will have the sat radio preinstalation kit, since my car is still on order,
but i wanted to know, if i install the sat radio(either XM or Sirius) will it configure with the iDrive system or not? in other words, can i change channels with the voice commad and stuff or do i have ot use the actual sat radio reciever?
Current: 2013 E92 M3, 6MT, SSII on Fox Red Extended
Previous: 2008 E92 335xi, 6MT, AW on Saddle Brown |
11-25-2007, 11:13 PM | #12 | |
532
Rep 4,021
All Canadian cars should have the sat pre-install kit called SA693 (or something like that) Once you physically install it, you need to update the car's programming. It is fully integrated....really sweet.
11-25-2007, 11:21 PM | #13 |
29
Rep 633
Like he says.. the Sirius ends up on the same fiber "MOST" loop as everything else, so is fully integrated, just like everything else.. just needs to be recognized by the programming once it's on the loop.
11-26-2007, 10:20 PM | #15 |
26
Rep 1,826
Drives: E92 335i
What's the deal with the musical Sirius brackets on the E92? I appear to have the harness for the CD-changer-location Sirius mount, but the other spot next to the TCU is wide open and seems to have all the right mounting bits. Is there something else that's supposed to go in this spot, or do older E92's just get stuck with an empty bay?
Is the left-rear Sirius module installed where HD-Radio/DAB are supposed to go? |
11-26-2007, 10:29 PM | #16 | |
29
Rep 633
Hope this helps. |
11-26-2007, 10:45 PM | #17 | |
532
Rep 4,021
11-27-2007, 12:21 AM | #19 | ||
26
Rep 1,826
Drives: E92 335i
Well, according to the PDF above and our other DIY's, Sirius was in the Sirius spot from sedan SOP to 05/06, then it switched to the CD-changer spot until 03/07, then switched back? What the hell? The cables I see in my coupe (10/06) line up with LH's observations. T, you have a 2008, which puts you outside the window of weirdness. Are the cables long enough to peel out of the harness to mount the receiver where it's supposed to live? It'd suck to reduce the trunk volume just to leave a useless space somewhere else. |
11-27-2007, 07:01 AM | #20 | |
532
Rep 4,021
When you activate the module you get 12 months free.....
11-27-2007, 07:02 AM | #21 | |
532
Rep 4,021
11-27-2007, 09:02 AM | #22 |
26
Rep 1,826
Drives: E92 335i
I think the parts issue is well understood now; I'm just really curious about why BMW moved this around.
