View Poll Results: When did your rear brake pads really need changing for the first time? | |||
0 - 10,000 miles | 2 | 4.00% | |
10,001 - 20,000 miles | 7 | 14.00% | |
20,001 - 30,000 miles | 15 | 30.00% | |
30,001 - 40,000 miles | 12 | 24.00% | |
40,001 - 50,000 miles | 6 | 12.00% | |
50,001+ miles | 8 | 16.00% | |
Voters: 50. You may not vote on this poll |
01-10-2014, 10:01 AM | #1 |
29
Rep 131
When did you actually change your rear brake pads for the first time?
I'm due for service soon, and the CBS indicates that I need rear brake pads serviced in 4000km (so at 24,400km = 15,250mi)
I've read a few anecdotes about the CBS being calibrated incorrectly, so I just wanted some rough stats for when I bring the car into BMW. |
01-10-2014, 01:56 PM | #2 | |
perennial neophyte
Rep 19
http://x3.xbimmers.com/forums/showthread.php?t=645517 |
01-10-2014, 08:18 PM | #3 |
X3 Owner/Driver
212
Rep 785
Drives: 2018 X3 M40i
http://x3.xbimmers.com/forums/showthread.php?t=806891
This is more current My rear said 1400 miles remaining from about 13000 until my service center reset the computer at 22000. do not trust that at all. If it annoys you have it reset. Either way, you can only determine brake life the old fashioned way - measure the pads.... esp on the rear. I will answer the poll when i change mine. still on orig front and rear - 24000 miles - I don't have a long commute so I have not racked up the miles like I have on past cars. kind of nice for a change.
2018 X3 M40i G01 | Phytonic Blue | Mocha | Premium+Exec | Driver Assist | Adaptive M Suspension
2011 X3 XDrive35i F25 l Deep Sea Blue l Mojave Leather l Sport, DHP, Premium, Nav/Technology, Cold Weather, Convenience [traded in] 2008 328XI E91 Sportwagon l Sparkling Graphite [traded in] |
01-11-2014, 01:12 PM | #4 |
Rep 76
My rear pads have indicated replacement in 5000 KM since I turned 40 000 KM. Now I am at 47 000 KM and the car still tells me to replace in 5000 KM. I'll have them check the pads physically in a month's time when the car is due for some other work but my plan is not to do anything until the service indicator tells me I have less than 3000 KMs left.
01-13-2014, 03:40 PM | #5 | ||
29
Rep 131
Thanks. I've seen both of the linked threads, but the majority of replies in both threads were current mileage plus remaining mileage before service according to CBS.
I was hoping that a lot of the people who made those responses have actually had their pads changed by now and can answer this poll. Quote:
I don't think mine has stopped counting down at all though |
01-13-2014, 10:51 PM | #6 |
12
Rep 140
90% city mileage.
Rear pads replaced at 18,522 mileage, 16April2013. * 2011 X3 35i Service Invoice dated 7Jan2014, Mileage 28,477. Verbatim: "...Front pads are 3MM and rotors are below spec of 26.4MM. L/F is 26.3MM and R/F is 26.3MM. Replaced the front brake pads and sensor. Replaced the front rotors. Cleaned brake wells...." * Warranty. * Total Invoice $0.00 Last edited by 96_Impreza; 01-14-2014 at 10:58 PM.. |
01-27-2014, 08:03 AM | #10 |
54
Rep 343
I have ~40,000mi on my '11 X3. A year ago, I had the count down stop at 1400mi. Dealer checked pads and stated I had plenty of pad left. They reset the countdown timer to 6000mi or so.
Now, the countdown timer is stuck at 3100mi. Been that way for about 2-3000mi. Will probably make an appointment after winter unless I hear a "grind" There are brake sensors in addition to the mileage countdown, correct? (like there were on the E83?) |
09-25-2014, 02:43 PM | #11 |
29
Rep 131
Update:
When I left off back in January, I had 21,000km on the odometer and had the service indicator reset to 24,000km remaining. Fast forward to 2 weeks ago, the indicator had dropped to 0km left and dropped by 50km every time I started the car (even if I only drove 5km last trip). I finally got the car in today (31,000km on the clock) with the cbs indicating that the brakes were due 700km ago. The dealership measured the rear pads at 4.5-5mm remaining (another 5-10k km to go), reset the CBS, and applied a software update that's supposed to fix the rate that it counts down. Last edited by Tangsta; 09-25-2014 at 07:02 PM.. |
12-01-2014, 05:32 AM | #13 |
Rep 26
Here is what I found:
My car had 57k KM on the counter. It started to give me warnings on the rear pads. The thing is that it has a sensor build in so when pads wears of it will also at one point start to wear of that sensor. At this point a yellow warning will be shown. Before this point You can go into the menu yourself and reset the value for next service. Also,if you change the pads yourself the service could be resetted to new pads. When the yellow warning shows it wil start to count down. If you change the pads at this point,remember also changing the sensor(only 1, on the right wheel)If not, timer could not be reset as the sensor has a variable resistor giving the countdown. |
12-01-2014, 10:11 AM | #15 |
46
Rep 323
I just ticked over to 51000 miles. Computer has been saying pads will be due in about 3k miles since around 45k. Not sure when I'll have to do it, guess I'll just wait for the actual sensor to go off. Bummer that it had to wait until my warranty went out though.
12-03-2014, 03:43 PM | #17 |
49
Rep 196
Had my rears changed at 32k and haven't changed fronts yet (currently 43.5k-ish), and the fronts will probably last until at least 50k.
all "k"s refer to k-miles, not km (somewhat) related question, how long has anyone been able to stretch their first set of TIRES! (the only thing we actually have to pay for right? I almost got to 40k, but I probably should have changed them at 30k)
Current: '16 F80 BSM/SO 6MT | '17 F54 Clubman S [Wife's]
Previous: '14 E84 28i, Valencia/Terra/X-line, '12 F25 35i ZAP, Jet/Chestnut, JB Stage 1, '88 E24 635CSi, '00 S4 Imola/Black Stg II APR/Milltek/AWE & some garbage GM SUVs! |
12-03-2014, 03:45 PM | #18 | |
49
Rep 196
02-02-2015, 03:02 PM | #19 |
29
Rep 131
Finally had my rear pads and rotors changed at 36,600km with 3mm left.
A bit disappointing that the brakes have such a short life... hopefully the next set is a little better. |
02-02-2015, 08:16 PM | #20 |
Rep 27
Drives: 2015 X3 xDrive28i
Just turned in my 2013 with over 49,000 miles and still had original front and rears. According to the on-board system rears were due at 59,000 and fronts at 79,000.
In terms of the tires, replaced them around 30,000 with non-RFT. I felt the ride was way better.
2015 BMW X3 xDrive28i Deep Sea Blue Metallic / Leather Oyster Nevada
2013 BMW X3 xDrive28i Vermillion Red Metallic/Leather Nevada Mojave, Retired with 49,750 miles |
02-02-2015, 08:26 PM | #21 | |
Macgyver
208
Rep 942
GTX3076R , ADV, JB4, FMIC, BOV, 17"APEX, 255/40/17 SQ, 6-SPD Manual
02-02-2015, 08:26 PM | #22 | |
439
Rep 1,732
Last time they checked I had about 5mm left. |
