Exhaust Fluid Reserve! Warning
01-09-2014, 02:57 PM | #1 |
411
Rep 3,049
Drives: 2009 BMW 335d
Just got this on my nav screen. Will link to it instead of showing the image as the pic is pretty big:
View post on imgur.com So I know that my passive tank hasn't been able to accept urea for over a year now and the vent is most likely clogged. See here: Link I've only been filling in the active tank since that time. So my question is, would the above "Exhaust Fluid Reserve!" warning message that I got be reading the overall amount between the two tanks or is it reading only the passive tank? Thanks. |
01-09-2014, 03:31 PM | #2 |
411
Rep 3,049
I just poured 1 gallon into the active tank when I got home. I believe the active tank holds 1.5 gallons so I was pretty much bone dry, assuming that the passive tank was completely empty.
Question: I used the 1/2 gallon bottle that twists and pushes into the active tank port. Can I cut the bottom out of it and pour DEF from a bigger jug into it next time, instead of continuously buying these 1/2 gallon bottles? |
01-09-2014, 03:44 PM | #3 |
Jumping Jack Flash
321
Rep 1,692
Drives: 2021 X3 M40i
The passive tank is 14.4 liters and the active tank is 7.4 liters. I can't tell from the literature exactly how the "time to refill" signal is generated. Both reservoirs have level sensors. It has been my experience that I get about 500 miles per liter, worst case.
Your plan to cut out a hole in the 0.5g bottle and reuse it is my plan too, but I haven't actually done it yet. According to something I read, the filler bottle works such that it won't "overfill" the reservoir. I am not a good enough engineer to know if that has something to do with the vacuum created by the filling process and whether cutting a hole would mess up that mechanism.
2021 X3 M40i: M Sport Differential, Adaptive M Suspension.
Previous BMWs: 1971 BMW 2002, 1973 BMW R75/5, and 2011 BMW 335d Previous Other Vehicles: '67 Cougar, '70 911e, '86 Jetta Diesel, '05 and '12 Foresters, et al. Last edited by 335dFan; 01-10-2014 at 03:21 PM.. |
01-09-2014, 03:56 PM | #4 |
411
Rep 3,049
Thanks for the input 335dFan. I just put another 1/2 gallon into the active tank. That's about 1.5 gallons or 5.7 litres into it.
EDIT: I would plan to cut out the bottom of the 1/2 gallon screw on bottle and use that as I poured DEF into it. Last edited by GreekboyD; 01-09-2014 at 04:10 PM.. |
01-10-2014, 05:34 AM | #5 |
TL/DR
57
Rep 234
Drives: 2009 335d Sport
Why cut a hole in the container?
I just used a knife to break the security tabs holding the Nozzle on, and then screwed the top off and refilled it. Then screw back on the nozzle and you're good to go. |
01-10-2014, 06:40 AM | #6 |
411
Rep 3,049
01-10-2014, 07:33 AM | #7 |
Jumping Jack Flash
321
Rep 1,692
Yeah, this is a much better idea. Thanx.
Previous BMWs: 1971 BMW 2002, 1973 BMW R75/5, and 2011 BMW 335d Previous Other Vehicles: '67 Cougar, '70 911e, '86 Jetta Diesel, '05 and '12 Foresters, et al. |
01-10-2014, 09:09 AM | #8 |
411
Rep 3,049
So the message went off this morning about 2 minutes after driving the car. I'll address my passive tank issue at some point this summer as the car is under warranty either way. I just hate the possibility of not having the car for 1-2 weeks as they wait for parts, etc.
01-10-2014, 09:37 AM | #10 |
Jumping Jack Flash
321
Rep 1,692
Passive tank sits above the active tank, as does their fill ports; passive fill port above the active fill port. Others may confirm, but I am pretty sure this is the way it is.
01-10-2014, 10:41 AM | #12 |
Jumping Jack Flash
321
Rep 1,692
Here is a picture of the two fill ports.
01-10-2014, 11:26 AM | #13 |
147
Rep 2,383
You have to push in rather hard before the smaller bottle will release its fluid, you would have to modify that if you want to try using it as a funnel with the base cut out. Like others have said, I just ground away the "child proofing" on the cap so I can refill it with a funnel from the larger 2.5 gallon jugs.
Speakers: CDT Audio HD-42 comps--front doors (RAAMmat deadened), CDT ES-06 6.5" woofers--kickpanl Pods, Hertz EBX202R dual 8" ported trunk sub. Amps: Phoenix Gold RSd 500.4 (comps & pods). PG RSd 600.1 (sub). Power & Ground: 4AWG Streetwires w/RockFosgt RFDB1 distro blocks. Input: HU lineout--Kicker KISL RCA adapters--RockFosgt RFIT-6 cables--Audiocontrol Matrix--Monster cables--RSd 500.4--lineout Monstr Cabl to RSd 600.1.
01-10-2014, 01:42 PM | #14 | |
411
Rep 3,049
01-10-2014, 03:12 PM | #15 |
411
Rep 3,049
So here is a pic of the nozzle that came with the 2.5 gallon jug. At first glance it looks to have the same diameter as the .5 gallon screw and push bottles. Hopefully this can work on our ports:
View post on imgur.com |
01-10-2014, 03:44 PM | #16 |
Rep 43
That hose will not work on our car. I bought the same jug from CND tire and it didn't work. Go to VW/audi and buy a bottle of their DEF fluid ( ask for the small bottle around $20). With this bottle, you can screw it onto the filler port and fill the tank. After you're done, just unscrew the top ( there's tab that you'll have to break to open it) and refill the bottle with DEF.
01-10-2014, 03:47 PM | #17 | |
Jumping Jack Flash
321
Rep 1,692
01-10-2014, 06:22 PM | #19 |
411
Rep 3,049
Thanks toy_soldier.
Worked like a charm! Great idea and pics from DnA Diesel too! |
01-10-2014, 07:08 PM | #21 |
Jumping Jack Flash
321
Rep 1,692
01-10-2014, 07:26 PM | #22 |
411
Rep 3,049
