Please recommend infinite baffle subwoofer (e93)
01-09-2014, 01:38 PM | #1 |
27
Rep 189
Hi Guys,
Can you please recommend a sub I could mount as infinite baffle in ski opening on my e93 335? budget 300-500$........ I want something that pounds hard. Thanks Dan |
01-09-2014, 05:49 PM | #3 |
223
Rep 5,120
12" fi q with all options except high qts, and internal leads.
http://store.ficaraudio.com/q12/ http://www.amazon.com/gp/aw/d/B003GF...&pi=SX200_QL40 |
01-09-2014, 08:37 PM | #4 | |
69
Rep 994
iPhone 6 Plus (iTunes library/iTunes radio/Waze, etc) to Airport Express via AirPlay. Toslink out of Airport Express to Helix P-Six DSP. PHD AF 1.C tweeters, PHD FB 4.1 midranges. Jehnert Door Cards and mid-bass'.
01-09-2014, 08:40 PM | #5 |
300
Rep 3,969
Not sure you can squeeze a 15 in the e93.
IDMax 12 JBL GTI MKII 12 JL 12W7 JL 12W6 If I had to choose one...IDMax.
Mobridge DA2 > JBL MS-8 > ARC XDi 600/4 > JBL Gti 408 Mids & Vifa OT19 Tweeters; PG Ti2 1600.5 > Morel HCW-10 & IDMax 15
01-09-2014, 08:50 PM | #6 |
223
Rep 5,120
01-10-2014, 01:37 PM | #9 |
Rep 209
+1
and would be great to see pics..its hard to find SUB install pics on e93 cabrios. pics, stats, & measurements would be great for any sub set ups. |
01-10-2014, 01:50 PM | #10 |
27
Rep 189
I will for sure post pics.................. noooww can anyone recommed an amp that can do 1500rms x 1, good price / quality ratio?
01-10-2014, 02:20 PM | #11 |
300
Rep 3,969
A good rule of thumb for IB is to go with an amp that can provide at least 50% of the sub's max rated RMS power rating. That's because when the sub is not in an enclosure the cone will move more freely and it requires less power to achieve the same output compared to a closed or vented enclosure.
david in germany730.00 |
01-10-2014, 08:37 PM | #12 |
223
Rep 5,120
Like kaigoss said you don't need 1500 watts rms for infinite baffle. Those are the ratings for the sub in a sealed or ported box. I would look for an amp around 600-700 watts rms.
01-10-2014, 08:39 PM | #13 |
223
Rep 5,120
02-11-2014, 04:57 PM | #14 |
8
Rep 213
Curious why people are recommending the FiQ over Fi's IB312 which is meant for IB and why not the acoustic elegance IB12 isn't being recommended, Kai I know you have the 15, do you not like it? I've heard it can be hit or miss getting a sub from AE in the quoted time frame and can even take months..which scares me away
I'm planning on ditching my JL 10W7 that is in a sealed enclosure firing thru ski-pass and trying the IB setup. So I'm very interested too. I need the trunk space and my 10w7 sounds muddy only giving it 500W off my alpine pdx-v9 which I don't feel like switching out for something bigger... |
02-11-2014, 05:43 PM | #15 | |
300
Rep 3,969
Applying that same sort of logic for the e93, where you can only fit a single 12, I think the AE would not perform well. Also excursion (not just xmax but xmech) becomes important because the sub has to move a lot more than a 15 to achieve good output. I'm between the JBL and the IDMax, the JBL can be had for a great price but has an ugly behind, while the IDMax is sexy but carries a larger price tag. Not sure what I'm gonna do just yet...
02-11-2014, 06:21 PM | #16 | |
8
Rep 213
Well I'm pretty much looking for the same thing, definitely something with some punch. I don't want to swap amps, will 500w push the JBL or IDMax tho? Maybe IDQ would be good as well. OP did you ever make a decision? |
02-11-2014, 06:41 PM | #17 |
16
Rep 80
I would love to hear the results of this project. Could the e93 backseat be sealed properly for IB setup? I would like to try it one day.
Hi-Fi | AudioControl D6.1200 & Crescendo-S1V2 | FiQ 12" | Morel MSW 265 8" | Morel MSW 114 | Dayton AMT Tweeters
02-11-2014, 07:08 PM | #18 | |
223
Rep 5,120
Because the Fi Q has a lower vas than the IB3. In a larger space the Ib3 would be ideal. |
02-11-2014, 07:12 PM | #19 |
69
Rep 994
i told you earlier it works great. i wouldn't have kept it for ~4 years if it wasn't amazing.
02-11-2014, 07:32 PM | #20 | ||
300
Rep 3,969
02-11-2014, 07:36 PM | #21 |
300
Rep 3,969
I think your 10w7 might work as well! What does the birth sheet say on your PDX? Let me model those bad boys again, I'll post the results shortly.
02-11-2014, 07:40 PM | #22 |
300
Rep 3,969
What is the trunk volume of the e93?
