E90 330i cheapest place to buy coolant?
01-09-2014, 10:42 AM | #1 |
Rep 99
I notice two days ago my coolant is low in my reservoir. Do I have to use bmw coolant or can I use stuff like Peak or Prestone? What's the cheapest place to buy bmw coolant?
01-09-2014, 10:49 AM | #2 |
Curmudgeon and Pedant
690
Rep 3,489
The cheapest place to buy BMW coolant is... the BMW dealership.
Really, this has been covered multiple times, in multiple forums. Please do a search. One of the terms you can use is: "g48 antifreeze". |
01-09-2014, 10:51 AM | #3 |
441
Rep 1,351
some coolants say mixes with any car any make like prestone but bmw claims their coolant is special for their cars because of some chemical anitoxidants and other crap. IF you get the dealer coolant you have to dilute it yourself with distilled water. BOth works but if you love your car pay a little extra but totally upto you. I had the same headache
01-09-2014, 12:37 PM | #6 |
26
Rep 313
The dealer. Dude, coolant is only around $30 how cheap do you wanna get.
It's better to use their coolant (well, maybe not there is better ones out there) anyway. Also, what is annoying to see is how people buy a luxury car and they want to start cheaping out on small bucks. I mean, yeah who wants to spend money they don't want to, but don't cheap out at start buying even cheaper crap out there to save a few bucks so you can buy your date a meal tonight while you take her out in your BMW. |
01-09-2014, 12:38 PM | #7 |
8
Rep 84
Zerex G-05 is the aftermarket equivalent, I believe. They sell it at O'Reilly's around here for $17/gal (full strength, so mix w distilled water also). It even has BMW/Mini Cooper listed on the container. I know some people say go get BMW coolant from the dealer, but I don't have a dealer that close and I buy from them as a last resort since they rip you off on everything else.
01-09-2014, 06:00 PM | #8 | |
Rep 99
Is Zerex G-05 what you used it your car?
01-09-2014, 06:16 PM | #9 |
The Tanzanian
1317
Rep 1,508
Drives: BMW M3, Audi RS6, Mini Cooper
Yup, I took my out of warranty 07 to the dealer here and they filled the coolant for free no questions asked. I actually went to parts first to try and buy but they just said I should bring it round back.
01-09-2014, 06:21 PM | #10 |
19
Rep 595
In the end, it really doesn't matter as long as you A) Change your coolant when needed as preventative maintenance and B) DON'T mix coolants which are incompatible with each other (so if you're going with non BMW coolant, it's best to do a good flush).
01-09-2014, 06:39 PM | #11 |
Rep 137
I would use the BMW coolant from the dealership. Mix 50/50 with Distilled Water and you'll be good to go. Also, you may be able to just go to the dealer and ask them to top it off for you. You'd be surprised.
2006 330xi 6MT - Deep Green Metallic/Beige Dakota - Every Option but Sports Package. No mods.
01-09-2014, 07:21 PM | #12 | |
103
Rep 2,783
http://images.peakauto.com/PEAK_long..._LORES%201.pdf |
01-09-2014, 08:52 PM | #14 |
Rep 65
So if its just from evaporation loss you just add water. Otherwise your not keeping a 50/50 ratio but rather more coolant than water. Coolant doesn't evaporate, water does.
01-09-2014, 09:03 PM | #15 |
17364
Rep 18,757
This is not correct. The water does not separate from the coolant and escape the system. If the coolant reservoir cap is weak or defective it can allow for vaporized coolant to escape the system, which then needs to be replaced with a 50/50 mix of coolant and (distilled) water. The cooling system can also leak from the temperature probe in the bottom radiator hose.
01-09-2014, 09:24 PM | #16 |
Rep 65
So straight water evaporates at 212 and Ethylene glycol or whatever is in coolant evaporates at 387 ish. I'm pretty sure its not evaporating since coolant is at 190 during normal conditions. There are also 2 air bleed valves in the coolant system of an n54 at least.
01-10-2014, 07:53 AM | #17 | |
23
Rep 322
01-10-2014, 09:40 AM | #18 |
815
Rep 2,869
BMWs are known for runing very hot, and have always had "cooling system problems"
Coolant in my car is not something I want to cheap out on. The "BMW" coolant isn't much more expensive than any other coolant, so not sure what benifits there are to saving $7 or something irrelevant compared to a $10k+ car....
2019 X3 m40i:Carbon Black:Executive:Premium:Adaptive:Vernasca:699M:HK: Ambient:IND trim:M Mirrors:15mm spacers:Maxton lip:20% tint windows/pano:dsg paddles:TLG mudflaps
2008 328i E90 Jet Black:6MT:RWD:Premium:Sport:Xenon:MTEC V3 AEs:Front Splitters:CF spoiler:19" VMR FF v710 |
01-11-2014, 09:53 PM | #20 | |
188
Rep 1,755
01-11-2014, 10:07 PM | #21 | |
103
Rep 2,783
If no codes are being thrown use Chevron Techron fuel injector cleaner (concentrate). It solves rpm fluctuating upon cold start-up. Also, for most BMW problems start off by scanning your car with the Peake Research Tool. It contains the actual BMW codes. If you want to register a newly installed battery for free (just buy a $10 cable) and google/download BMWLogger
01-12-2014, 06:18 AM | #22 | |
17364
Rep 18,757
