Centric High Carbon 125 Front and Rear Rotors for E9x 335i
01-08-2014, 01:29 PM | #1 |
Rep 10
Front and Rear Centric Rotors in excellent condition - used one track day - almost no wear. Paid $320 - asking $200 plus actual shipping Front Part Number- 125.34093 Rear Part Number 125.34080 See other listing for PFC 08 Pads to go along with these rotors - Will make a package deal if you want both. Centric High Carbon Plain 125 Series Rotor Features: Premium black E-coating finish to combat corrosion on the rotor hat and between the cooling vanes Center split castings for increased strength and stability Superior cooling fin designs Double disc ground finish 100% fully machined finish including rotor hats 100% inspected and mill-balanced for smooth operation regardless of speed Lateral run out held to 0.002" or less Meet or exceed rigidity quality specifications, including cooling vane designs A center split casting increases strength and stability, but to further promote longevity, the rotors feature Centric's exclusive black E-coating finish. Engineered to withstand 400 hours of salt spray testing without corroding, it is applied on all non-friction surfaces to prevent premature rusting. |
