F30POST
F30POST
BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > Mechanical Maintenance and TSBs: Break-in / Oil & Fluids / Servicing / TSBs and Service Bulletin > Right Low Beam Malfunction
Studio RSR
      01-08-2014, 11:17 AM   #1
CEJ
Drives: 2012 550i M-Sport
Vehicle:
2012 328i, non-xenon
After Market Installs:
HID Low Beam with error cancellation
HID Fogs with error cancellation
Issue:
Right Low Beam Malfuntion indicator is on and the low beam is not operational. All other lights inlcuding the high beam work. I have had HID's installed for over 1yr with no issues until last week.
I bought another HID kit thinking the ballast went out. Tested new HID kit on the left side and confirmed it works.
Tested voltage at the wire harness connector (right low beam) and confirmed 12V. Installed new HID kit and the low beam did not kick on.
Any ideas what could cause this issue? Could there have been a short which temporarily disables the light control module (LCM) from operating the low beam? All passenger side lights work and confirmed voltage to the low beam so not sure what else there is to check. Also, checked ground wiring and there does not appear to be any nicks or cuts which could cause a short.
Obviously I took a risk utilizing non oem parts, especially when dealing with a sensitive lighting system and a vehicle under service warranty so please help me with the technical aspects and spare the spanking I'm sure this will help several others who may run into this problem in the future.
      03-23-2014, 05:36 PM   #2
sirfatty
Code Monkey
Drives: 2013 328I
if u put the sensor in manual on not auto does it fix it
I had the same issue and I have to do that every so often
f30post
