What's wrong with my CCC iDrive?
01-08-2014, 09:05 AM | #1 |
31
Rep 722
Drives: 2008 BMW 335xi
Video:
Controller knob still has feedback. Tried doing the reboot method, no luck. Ejected navigation cd, no luck. Is my CCC dead? Screen and controller seem to be fine. I've scheduled a service appointment for this weekend in the meantime. It's been working fine, until two days ago when we got blasted with -40 weather. |
01-08-2014, 08:16 PM | #2 |
A family of bimmers
2748
Rep 7,742
more than likely it's throwing a code and possibly an update may fix it. or you will have to replace the entire CCC. im in the process of getting my CIC replaced for a similar issue. Mine wont load the harddrive (no navigation, no local music) and it reboots until it can load it. some days it'll crash once, others, 7-8 times every time i start the car..
2018 PB/Black G01 X3M40i | 699M | ZDA | ZPP | ZPX | Maxton front lip | X3M vents | 15mm Spacers | Diamond G20 style grills |
01-11-2014, 01:27 AM | #3 | |
31
Rep 722
Sometimes, I feel like its a battery issue in a way, but eh.. I'm not too sure what is going on. Not being covered under CPO is a big thing too. I'd rather throw the $135 I'd pay for a diagnostic towards a new battery. Even if it didn't fix my problem, I'm still on the stock one, so it's pretty much due for a replacement anyway. |
01-11-2014, 06:54 AM | #4 |
A family of bimmers
2748
Rep 7,742
I had mine diagnosed at the dealer and thought battery as well, but they tested it and it wasnt that. They said the crash logged an error and it was stating that the CIC needed to be replaced. Since it keeps crashing on you, maybe start at the battery but look to the search here for the Red Screen Of Death issue. It may be helpful for you since you have the CCC.
01-11-2014, 05:53 PM | #5 |
18
Rep 315
without wishing to offend anyone... basically they are a piece of junk
check it out (a uk company that specialises in engineering out the hopeless quality of electronic components fitted to most cars these days) entertainment http://mfd.bba-reman.com/bmw-idrive-navigation-system rest of the car http://www.bba-reman.com/content.asp...s_and_tips#bmw I came across then when a GM branded car's bosch abs played up... turns out all bosch abs modules have much the same appalling design flaws... these guys repair it better than when it came out new |
01-13-2014, 06:11 PM | #6 |
22
Rep 140
Try This
Disconnect the negative battery cable for 20 minutes...
re-connect after 20 minutes... car will then reset and perform full MOST network scan and things might work again! worth a shot.. up to you of course. ta. Tich.
01-13-2014, 08:47 PM | #7 |
31
Rep 722
Gonna try this tomorrow. I've just been busy with work and too tired after, lol.
01-14-2014, 05:59 PM | #8 | |
31
Rep 722
Car is now sitting in the garage with the terminal off. Here's hoping. |
01-16-2014, 06:17 PM | #9 |
31
Rep 722
No luck with a battery disconnect. Left it over night and same thing.
The thing will reboot until it does stay stable and come on. I canceled my last week appointment cause it was working for a few days straight, but now it reboots every start up until it stays on. Guess I'll see if the dealer can grab some faults from MOST. |
01-20-2014, 05:18 PM | #10 |
A family of bimmers
2748
Rep 7,742
Just got mine replaced under a good will replacement at the dealer. Thankfully. All is great now and it's fast again
01-20-2014, 10:24 PM | #11 |
31
Rep 722
Awesome. I'm getting mine replaced this weekend at my dealer for about $1k. It's not free, but what're you gonna do.. Need that damn iDrive to do anything.
01-21-2014, 09:41 AM | #12 |
A family of bimmers
2748
Rep 7,742
ask them for a good will replacement. thats what i just got. I have two cars with my dealer and they understand they want to keep me as a customer. It doesnt hurt to ask. Explain its the reason you bought the car and cant believe something this integrated into the car is not covered under the CPO (if you have one)
01-21-2014, 10:02 AM | #13 | |
31
Rep 722
I gotta be a real customer like you first, before I can get something like that. Soon enough. |
01-26-2014, 02:11 PM | #14 |
31
Rep 722
Dropped my car off yesterday to get the CCC replaced.
My SA said "programming" would take "hours and hours." Do you guys think they are doing a whole progman update? Because a single update through winkfp would only be a few hours, right? |
01-26-2014, 03:16 PM | #15 | |
Rep 1
I notice long cranks to start the car in the morning, two weeks ago the CCC got stock at rebooting mode (Only switching from BMW symbol and blank screen, no audio). A week later, fifth cylinder coil failure (OBD 2). No OBD2 battery fault (if that exist). I am leaning to believe that it is an electrical issue what cause all this. I am taking the risk of DIY instead taking it to BMW dealer. All OEM parts, coils, spark plugs, battery (Bosch), CCC (eBay) and INPA/NCS/SSS software (eBay). Any lesson learned will be appreciated. I will post the outcome with tips. |
01-27-2014, 08:31 AM | #16 |
A family of bimmers
2748
Rep 7,742
believe it or not, most of the time programming fails and they have to start it over again. Ive had a car in for programming for 3 days because their computer, not my car, kept having problems.
01-27-2014, 08:51 AM | #17 | |
31
Rep 722
If they used an autologic, I know it would pretty much be like progman. |
01-27-2014, 10:00 AM | #18 | |
555
Rep 1,244
Drives: 2013 F10 M5
Progman was discontinued back in 2008 in the dealerships and replaced with ISTA/P (part of the ISPI system) which is much more reliable and faster then Progman ever was. ISTA/P will want to reprogram every module in the car that requires an update because BMW works on the concept of integration levels instead of individual software versions for modules). Although most of those take a few minutes, the CCC can take a couple hours. Honestly, and this is just me, I wouldn't have paid $1k to replace the CCC unit and just retrofitted a CIC for a couple hundred more. 100x faster and 10x more functionality. |
01-27-2014, 12:42 PM | #19 | |
31
Rep 722
I looked into the CIC, but it definitely wasn't only a couple hundred more. It was almost a thousand more. At the very least, it was like $500 more. I wasn't going to source used parts off eBay, then have the trouble of trying to get them updated, coded, etc, where it could potentially be bad and fail sometime down the line again. I got a brand new part, along with all my car software updated supposedly, backed by warranty from an actual BMW dealership. The loaner I got while this is being done has NBT, which is nice. But after I had it set to where my radio was playing. I didn't pay attention to it. The wow factor of how fast it is and the eye candy was nice, but I would've gotten over it soon enough. I barely use nav.. CIC/NBT is really nice, but it just didn't seem worth it to me. |
01-28-2014, 10:26 AM | #21 |
18
Rep 315
whole car software update will be nice... hope all goes well
so which controller do you have? try a later switch, if it works there's a chap selling the whole lot cheap on another post (inc wood trim) |
01-28-2014, 05:26 PM | #22 |
31
Rep 722
Got the call back from my dealer today.
Going to pick it up tomorrow morning. Will my coded things like digital speed be need to be recoded you think? Also, my car has an OEM alarm retrofitted. Will that need to be programmed again? |
