E90 Vacuum pump undwer warranty?
01-07-2014, 01:48 PM | #1 |
Rep 10
Hi, been told that I need the vacuum pump replacing as its leaking oil. I have the extended warranty on a 2007 E90 1.8i. Was first told that it was the rocker cover but after having a look been told by the dealers that its the vacuum pump. Been told its not covered under the warranty. Had a look in the book and it shows as being covered. How can it be wear and tear, when the part as failed resulting in oil leaking.
Thanks for any help. |
01-07-2014, 01:53 PM | #2 | |
886
Rep 9,097
If your vaccum pump is failing then your CCV might be blocked. Worth of reading this thread which covers most of 318/320i problems. http://www.e90post.com/forums/showthread.php?t=669908 And yes, its not wear and tear part. It is a mechanical part which has failed.
F36 Xdrive for her - HUD, park assist, heated steering wheel, rear camera, Apple car play
F36 RWD for him - HK, M sports pack, GTS tail light, Apple car play |
01-07-2014, 03:15 PM | #3 | |
Rep 10
Thank you for your help.
01-10-2014, 04:27 PM | #4 |
86
Rep 313
It's the N46 B20 engine for 318i/320i
http://en.m.wikipedia.org/wiki/BMW_N46 I had rocker cover, vacuum pump and sump pan gasket to replace! |
01-11-2014, 03:09 AM | #5 |
20
Rep 185
Just a word of warning about rebuilding it; this only replaces the seals that separate the two parts of the pump and the one between the pump and engine. There may be a seal next to the pump bearing as well to stop oil getting in to the pump and this may actually be the root cause.
