Go Back   6Post.com | BMW 6-Series Forum > BMW 6 Series Forum > Commercial Classifieds [6 Series and M6]
      01-07-2014, 11:05 AM   #1
kenny@velosdesignwerks
kenny@velosdesignwerks's Avatar
Drives: silver
KW Suspension Solutions | V3/Club Sport | 2014 Promotions
Hello Members,
We will be offering KW Suspension solutions for the F12/F13 M6 to the community as always expect the best pricing and customer support. Be sure to use our "request a quote" function on our website. Check out the link below.
Happy new year to all our members.
http://velosdesignwerks.com/products.../kw-suspension
Feel free to PM me for more info or any additional questions.
KW Clubsport:
Coilovers for Race track and road.
These set ups were specifically designed for the Nordschleife using track day tires. By using the optional adjustable top mounts, suspension geometry can be adjusted to the requirements of the tires and the intended use.
These adjustable top mounts coupled with the independently adjustable rebound and compression dampening technology individual set up adjustments according to vehicle load, tire characteristics and different track conditions. Clubsports meets all needs for the road and the race track guaranteeing excellent handling, best performance, great agility and fantastic lap times.
KW Variant 3:
State-of-the-art technology from motor sports for more performance on the road. The separate and independently adjustable rebound- and compression damping allows for an individual suspension setup for different uses and preferences. The unique patented system with its two-stage valves allows a rebound damping adjustment (comfort) and a compression adjustment (driving dynamics) in the low-speed range while the high-speed range which controls the driving safety, is fixed.
Compression- and rebound adjustment
As far it is vehicle-specifically possible, the rebound damping is adjusted by a spindle at the end of the piston rod. Mainly, the traction phase (rebound) controls car body vibrations and also influences handling and comfort in the low-speed damping range. By using the traction phase adjustment, the vehicle can be adapted to the requirements of the driver. Moreover the driving behavior can be regulated from comfortably rolling to sporty and tense with improved road holding characteristics.
The compression phase adjustment is carried out at the lower end of the shock absorber via our patented multi-purpose valve. The large number of pre-set parameters of this valve allows for a wide range of adjustment for individual use. The unique low-speed compression adjustment significantly distinguishes this technology from any other. In this compression range, the driving behavior of the vehicle is drastically influenced. An increase of the damping power supports the vehicle already during compression and therefore avoids rolling and pitching. The directional stability is significantly improved.
Damping technology with individually adjustable rebound- and compression technology
inox-line* stainless steel technology
Individually height adjustable
Adjustment parameters approved by the German Technical Control Board (TÜV)
High-quality components for long durability
Infinitely variable rebound damping adjustment
14-way adjustable compression damping
Unique, individually working damping force adjustment
Comprehensive documentation for easy use
      01-28-2014, 10:27 AM   #2
Drives: silver
PMs replied.
6post.com
