FS: KW STREET COMFORT Suspension
01-07-2014, 02:00 AM | #1 |
21
Rep 200
MSRP$ 1850 For Sale$ 1300 10k miles on coil overs INFO OFF KW WEBSITE: Description KW Street Comfort: Individual sport suspension with Maximum comfort Height adjustable Street Comfort allows a lowering of 10-40mm depending on the vehicle. This allows for the flexibility to improve the look while adding custom products like aftermarket wheels. At the same time the lowering has a positive effect on the driving dynamics and road contact. With this discreet but effective lowering more spring travel will be retained to combine a comfortable spring with harmonic dampener, this way the best driving comfort is guaranteed. KW Street Comfort Kit BMW 3series E90 Lowering Front Lowering: 1.2" to 2.3" Rear Lowering: 0.9" to 2.1" Notes 6: Wheel spacers may be necessary if using stock tires. 2: Front height adjustable by threaded shock bodies. Rear height adjustable by adjustable spring perch. 02: Height adjustable front and rear axles (front axle threaded strut housings, rear axle adjustable springs + dampers) 69: Coilover strut housing material: galvanized steel 06: When using original tires, wheel offset spacers maybe required |
