Studio RSR
BMW 3-Series (E90 E92) Forum > BMW E90/E92/E93 3-series General Forums > Regional Forums > UK > Suspension turmoil
      01-02-2014, 05:12 AM   #1
breathe3asy
breathe3asy's Avatar
South Africa
112
Drives: 340i F30
E92 325i  [10.00]
Suspension turmoil
Suspensions gurus,
I'm struggling to decide on the right setup for my E92 M Sport 325i. Looking for better than OEM M Sport suspension, improved handling & for the arches to sit more flush.
My observations so far:
Eibach Pro Kit
-can be paired with M Sport shocks
-no sacrifice to comfort
-drop is minimal
H&R Sport
-can probably get away with pairing up on M Sport shocks but run the risk of reduced life span (current shocks done 18K)
-comfort (bit worried about this)
-drop is healthy
Coilovers
-the expensive way but the proper way
-takes time getting the setup right with all the customization coilovers offer (anyone with experience here)
-I don't track, are coilovers overkill?
Eibach Sportlines
-between H&R & Eibach Pro, not sure if can be paired with OEM shocks
-comfort of Eibach
-drop is lower than Pro Kit but not as low as H&R
-real question is whether these springs are available for E92, as I can only see for E90/E91
I've wanted to make a move for a long time now but the right option for me hasn't been clear.......help!
      01-02-2014, 05:30 AM   #2
Icekube
Scotland
46
Drives: E87 130i
you've missed, for me, the best suspension option going for a daily, road going car, and that is a Bilstien B12 spring & damper kit. excellent Bilstien dampers paired with Eibach Pro-kit springs.
http://www.europerformance.co.uk/pag...?product=48921
given the relitivley low mileage of your current setup, i would imagine you could recoup a decent sum of cash for your current spring/damper setup selling on second hand to help towards the extra cost.
      01-02-2014, 01:04 PM   #3
breathe3asy
South Africa
112
Drives: 340i F30
E92 325i  [10.00]
That seems like a very solid setup thanks!
      01-02-2014, 01:14 PM   #4
Rudz
Rudz's Avatar
United Kingdom
249
Drives: F30 335D xDrive Shadow Edition
That is a great find Icekube, thanks
Ceaton mate, Know of any garages in Brighton who could fit this kit ? It looks great value for money
I suspect this will be as good as the birds kit.
      01-02-2014, 02:08 PM   #5
safe d
10
Drives: BMW E92 325 i M Sport
You should go for Teins. http://www.tein.co.uk/srch/uk_search...=STREETADVANCE.
Nice balance between comfort and low ride
      01-02-2014, 05:59 PM   #6
breathe3asy
South Africa
112
Drives: 340i F30
E92 325i  [10.00]
I'm yet to find a worthy garage in the Brighton area, when I do I'll let you know. If you find one, also let me know
      01-02-2014, 06:00 PM   #7
breathe3asy
South Africa
112
Drives: 340i F30
E92 325i  [10.00]
Interesting thanks
      01-04-2014, 04:31 AM   #8
breathe3asy
South Africa
112
Drives: 340i F30
E92 325i  [10.00]
Came out of a car park last night & on the downwards ramp my front nearside always rubs!! & I think to myself each time F me what would that be like with lower springs!?
I always take it at lower speed as well, however, I do tend to have a car full of lads so that probably doesn't help......but still
      01-04-2014, 05:27 AM   #9
Josh1a1h
United Kingdom
170
Drives: AzuriteBlack 335i E92
Coilvovers ftw.
Do it once, do it right.
      01-05-2014, 05:36 AM   #10
richk84
England
130
Drives: e93 330i
Why does running H&R springs reduce the life of your m-sport shocks? Anyone know?
      01-05-2014, 05:47 AM   #11
seanblee
seanblee's Avatar
47
Drives: 2021 G21 M340i
The H&R springs are much stiffer than the factory springs and the M-Sport dampers aren't specified to control a stiffer spring, so they wear more quickly.
2019 VW Golf GTI Performance | H&R rear ARB
Previously 2007 E92 335i SE auto | Quaife LSD | Birds B3 ARBs | Evolve Stage 1
      01-05-2014, 06:12 AM   #12
richk84
England
130
Drives: e93 330i
Thanks for that.
I'm guessing if your planning on keeping your car a long time and put high miles on it H&R probably isn't the route to go down
      01-05-2014, 03:16 PM   #13
lolololol
United Kingdom
96
Drives: M4 F83
Been discussed a million times on here. Look for a thread which was prominent about 3-4 months ago which discussed many different setups.
If you want Rolls Royce then get Ohlins (fully adjustable)
Great high mid range and tuned specifically for E9x then get the Birds setup.
There are plenty other Bilstein setups et al which are detailed in the thread I mentioned.
Go search all the info is out there.
Personally I have the Birds setup and it's the best money I have spent on my FBO 335i.
Ps: just doing springs is pointless unless you just want a visual job and don't care about ride quality
Engine Mods: VF HEX Stage 2, ER Charge Pipes, VRSF Catless Downpipes, BMS Intakes and PCW Exhaust Mod
Running Gear Mods: HRE Flow Form F01, Yellow Stuff pads.
Cosmetic: Performance Grill, Lip Spoiler, Splitters, Side Skirt Extensions, Diffuser and BMS Tips
Tags
eibach springs h&r e92 sportlines
