BMW 3 Series E90/E92 S3 Coilover for sale$750
12-30-2013, 07:36 PM | #1 |
21
Rep 82
Drives: 2007 335i
2007-10 BMW 335i S3 suspension sonictuning mw/e92/bmw-3-series-e90-e92-s3-adjustable-coilovers-with-camber-plate.html Features: • Full length adjustment system on lower mount • Separate ride high and pre-load adjustments • Aluminum alloy construction: lower mount, top mount, spring seat and locks • Multi-positional manual damping force adjustment * • Forged aluminum top mount • Compression and rebound: Each application has a different number of manual damping adjustments • Adjust damper rate by touch of a knob. • 12 level adjustable damper - adjustable dampers allow fine-tune the suspension stiffness to best suit the driving condition. • Scm440 hardened piston rod: special high strength grade material with extra hardened process effectively improves the chances again deform, fracture and leakage. • Special formulated oil – stable and durable high quality oil seal can minimize any suspension failures or oil leaking to increase durability. • Racing suspension fluid – high performance suspensions fluid can effectively stabilize the damper force and ensure suspensions condition under severe driving. • Inner polished seamless steel tube – quality high strength tubes ensure the strength of the struts (cylinders) the micro finished inner surface ensures a precise and smooth action, which can reduce the changes of fluid leakage and prolongs struts endurance. • Mono tube design; come with quick response and comfort suspension fluid is separated from high-pressure gas in order to reduce damper failure. • Advanced formulated rubber parts: effectively increase the endurance and help eliminate abnormal noises. • Forged aluminum alloy top mount: increase the strength and effectively reduce the weight, and provides sensitive driving feedback. • Sae9254 spring: high strength material formed spring effectively minimizes deformation. • 6061 t6 aluminum alloy plate: lighter than normal steel parts. (13 photos) Last edited by marcos335i; 12-30-2013 at 07:55 PM.. |
01-01-2014, 03:26 PM | #3 |
21
Rep 82
Drives: 2007 335i
I bought it this past summer. It has less than 6000 miles. I am selling because I am selling my car
01-02-2014, 04:58 PM | #5 |
21
Rep 82
Drives: 2007 335i
750$ shipped
01-17-2014, 08:03 AM | #6 |
21
Rep 82
Drives: 2007 335i
650$shipped
01-17-2014, 08:03 AM | #7 |
21
Rep 82
Drives: 2007 335i
USA shipment only
01-20-2014, 12:23 PM | #10 |
21
Rep 82
Drives: 2007 335i
Maryland ellicott city 21042
01-21-2014, 08:33 AM | #12 |
29
Rep 542
Drives: '11 BMW 335i
still available?
U.S. Army Veteran/Iraqi Freedom
11' 335i -M-Sport/LeMans Blue Metallic/Sport/Premium/AT - Current 06' 325i -Base/Arctic Metallic/MT - Retired |
01-21-2014, 08:38 AM | #14 |
21
Rep 82
Drives: 2007 335i
Sold!!!
Sold to David
