12-29-2013, 04:24 PM | #1 |
Rep 21
Valentine One & The 4-Series
Just wondering if you guys had any tips as to how to set up a Valentine One radar detector in the 4-Series. I'd prefer to not have to hardwire it but I also appreciate concealing the wiring.
Right now I'm looking at plugging it into the rear power outlet and running the telephone cord under the rear floor mat, passenger's seat, front floor mat, and trying to hide the cord alongside the leading edge of the dash to where the detector is mounted behind the nav screen. Any better ideas out there? |
12-29-2013, 06:21 PM | #2 |
42
Rep 503
I placed my Escort on the driver's side just beneath the rear view mirror. I ran the cord up along the roof (there is a slight gap between the windshield and interior ceiling), and under the liner alongside the front passenger door, then under the floor mat to the power plug on the front passenger side. Worked pretty well at concealment, although I did have to wrap a couple spots on the cord with electrical tape to make sure it stayed hidden along the ceiling.
12-30-2013, 09:45 PM | #4 |
Rep 24
I bought the Valentine 1 accessory that plugs into the OBD port, then ran the wires under the trim in front of the front driver-side door, then above the windshield (under the trim) to the passenger side of the rear view mirror. This way, I can move my sun visor whenever I want without hitting the radar locator. I drive 90% of the time alone. When I have a passenger, they just need to be aware to not push the visor too far in.
I also have the remote display, so the radar detector does not light up in the window. I put the remote display in the lower right part of the instrument panel. I also thought of installing the radar detector at the top center of the back window, since I have the remote display. I did that in my previous car (2008 MazdaSPEED3), and that worked out great. The detector was nearly invisible and I never had to take it down for fear of it getting stolen. |
01-01-2014, 12:42 PM | #5 |
Rep 3
I picked up my new 2013 328i xDrive about two weeks ago, and did a lot of searching around the forums and finally settled on using an inviscord to the review view mirror assembly, and a blendmount. I'm pretty happy with how it looks and the positioning. I gave up the concealed display that I was using in my last car (C300) so I didn't have to worry about running wires around the car. Some pics below.
http://www.blendmount.com http://www.invisicord.com It's not the cheapest solution, but I think it looks great. |
01-01-2014, 01:11 PM | #6 |
20
Rep 268
Drives: 528, 428 GC
I had the savvy unit installed in our 5-series. I ran the cord under the trim, down the A pillar. Unfortunately, I can tell you for certain that this method will not interfere with air bag deployment and you can remove everything in about a minute while a tow truck is about to take your car away.
01-01-2014, 03:30 PM | #7 |
29
Rep 633
Mine is not a Valentine, but a passport 9500ix. I used the associated direct 'smart' power chord with the store/mute/GPS functions as shown. It allowed me to use the gutter space between the dash and the windshield to run it along and behind the A pillar, down to behind the panel by the driver to be able to pull / get at the inline fuse if required, then wired it to the downstream side of the ignition module behind the dash.
Takes a bit of effort, but well worth it. The Detector is attached to the dash using Velcro for quick removal in sketchy situations, and is set up between the iDrive and HUD to be part of the normal driver scan field.
01-01-2014, 03:39 PM | #8 |
50
Rep 808
Here's how I did mine in my 335 - I have the SAVVY so I plug right into the OBDII
View post on imgur.com |
01-01-2014, 04:06 PM | #9 | |
29
Rep 633
I hooked mine to the Key side of the Ignition module because I always find it bothersome to manually switch it.. If the ODBII has switched power, that saves a step..
01-01-2014, 04:12 PM | #10 | |
50
Rep 808
01-01-2014, 05:56 PM | #11 |
396
Rep 3,893
this is the only way to go IMO. wireless and placement must be in the upper center of the windshield.
01-01-2014, 06:12 PM | #12 |
29
Rep 633
To each their own. As a long time pilot, I like to have it in front of me like the other readouts that matter, but off high to the right is OK also, since the mirror is there and get's the odd glance..
01-02-2014, 12:41 AM | #13 |
50
Rep 808
03-28-2014, 08:01 AM | #14 |
Rep 13
I have a question for 435 guys with Valentine 1. I am moving my V1 from my 2000 328i to me new 435i.
I am thinking of getting Savvy for a much neater/cleaner/hidden installation, but I noticed on the 435, the OBD port is facing down (vertical) as opposed to horizontal. I was curious if anyone is using the Savvy with the 435, and if so, does it's downward installation protrude down so far as to impeded your left foot getting in and out of the car or using the dead petal? Thanks. |
03-28-2014, 07:40 PM | #15 | |
50
Rep 808
03-29-2014, 06:02 AM | #16 |
Rep 13
Thank you Steve. I ordered the Savvy yesterday with a couple other accessories I need to do a good hidden install.
Looking forward to having Mike protect the new ride. Have a great weekend.
2014 435i - M Sport Line - Mineral Gray Metallic - Harmon Kardon Sound - Heated Seats - Premium Package - Drivers Assistance Package - Technology Package - Black Leather Interior - Aluminum Hexagon Trim - Estoril Blue Trim Finishers.
03-29-2014, 08:17 AM | #17 | |
124
Rep 704
Drives: 2014 328d
2014 328d SportLine
03-29-2014, 01:43 PM | #18 | |
50
Rep 808
Radioshack for the phone cord and you'll need a D-Sub pin connector kit (a few $$) to connect it to a harness. Use the middle two wires in the phone cord for power |
03-29-2014, 01:47 PM | #19 |
I need a 911
8
Rep 68
Installed mine by tapping into a switched power in the sunroof panel! Works great, reversible, no need to pry anything apart except the sunroof panel being dropped
nickmanderfield.com - ecommerce, magento, internets
my4series.com - 2014 435i Mineral Gray build site |
03-29-2014, 03:09 PM | #20 |
124
Rep 704
Drives: 2014 328d
On second thought, I think having the detector below the mirror will be too distracting as it's in the field of vision. Any opinions on putting the Escort 9500ix behind the mirror (a bit to the left) on the windshield with the new Sticky Cup and running the Invisicord to the back of the mirror from there? I think if the detector is high up on the windshield it will be less obtrusive.
2014 328d SportLine
03-29-2014, 03:31 PM | #21 | |
29
Rep 633
03-29-2014, 04:25 PM | #22 |
124
Rep 704
Drives: 2014 328d
FYI I found the answer to my question: BBE-2017
2014 328d SportLine
