after market radio/cd 7 inch lcd
12-26-2013, 07:01 PM | #1 |
Rep 65
looking for info on using after market radio/LCD vs BMW after market
any ideas.. i have questions; like- what power output to get, i have the surround sound according to the window sticker, i assume its the 420 watt based on the size of the amp also. But the Bentley says the 420 watt comes with the navigation system. it also shows floor mounted woofers for the base 180 watt radio. confusing t say the least. thanks |
12-26-2013, 07:36 PM | #2 |
1918
Rep 13,117
You need to find out for sure what you got.
L7 or Hi Fi if you have a car 09 or older. Find a free vin checker site and print out your options. look at the option number for the sound system. 677 = l7= Top Hi Fi , 676=Hi Fi These systems can be in a Nav/idrive or in the Pro Radio versions they are separate amp and speaker systems. Read the following links BMW stereo types http://www.e90post.com/forums/showthread.php?t=352586 http://www.e90post.com/forums/attach...2&d=1266451970 http://www.e90post.com/forums/attach...2&d=1260829447 http://www.e90post.com/forums/showthread.php?t=343673 http://www.e90post.com/forums/showthread.php?t=138949 http://www.e90post.com/forums/attach...1&d=1209780605 http://www.e90post.com/forums/showthread.php?t=641323 http://bmwcoders.com/forum/3-er-8/bm...1-e92-e93-291/ http://www.e90post.com/forums/attach...1&d=1209780865 http://www.bawarec.ru/manuals/3er/e9...3er-e90-12.pdf http://www.musicarnw.com/page-2/ http://www.e90post.com/forums/attach...4&d=1278871872 If you have logic 7 sound and you want to change the Head Unit then the amplifier must go to. Why because there is and optical connection between the head unit and amp and nobody makes a aftermarket head unit that has the same type of optical output. Last edited by ctuna; 12-26-2013 at 07:47 PM.. |
12-27-2013, 10:31 AM | #4 |
223
Rep 5,120
