SES light that only shows in the winter and the answer is...
12-23-2013, 10:47 AM | #1 |
Captain Crunch
168
Rep 548
New Urea tank for everyone!
I have owned my car for 2.5 years now and this is the last year it will be under warranty with 42k on the odo. Every winter I have had several SES lights which I assumed to be the fuel cap, as most of them are related to it. I would undo the fuel cap, retighten, and the SES light would go away a few days later and then come back a week or two. Rinse and repeat until Spring, never fails. So being this is my last warranty winter I decided to take it in to have the fuel cap replaced. Instead they read the codes and found that the temperature sensor for the urea fluid was not reading correctly under 35F and had to be replaced. However, the sensor is inside the tank, and so the entire tank needs to come off and replaced. They ordered parts, needed more, and 5 days later I'm still in a 320xi (which blows, btw). I might get the car back today, but most likely will be after Christmas. I'm not terribly worried about the fix, but the fixers. The SA told me that mine is the 3rd of these they have ever done, and so every tech/foreman is looking at my car. Not sure if this is good or bad, but im hoping that the rest of the winter goes smoothly. I'll try and see what the out of pocket costs would be when I pick up my car. This is the 2nd thing thats been broken, with the 1st being a squeaky dash panel. So I can't really complain.
On Order (in transit): BMW iX 50, Oxide Grey
Retired: BMW Welt Delivery 4/14/16: European Delivery - 2016 340i EBII/Saddle - ZMP | ZCW | ZDA | ZLP | ZTP | M Adaptive | Rear Shades | MPPSK Before and After Dyno Retired: 2011 335D Space Grey/Black - ZSP | ZPP | ZCW | 6FL | Sat Radio | Nav | $600 Base Audio Upgrade |
12-23-2013, 04:10 PM | #3 |
147
Rep 2,383
I have had a similar problem since my warranty ran out. LOL
I would get a SES light. Then, I would fill up the fuel tank and the SES light would go out after restarting it once or twice. Then it would go on and then out again if I let the tank got down to around a quarter. I assumed it was a fuel pump/fuel cap problem. This went on for a long time, and then the SES light just started to stay on all the time, with no noticeable performance problems. Then we had a sudden cold snap a while back and shortly after refilling the fuel tank the SES light went out. Surprise surprise. Now it is back to staying on. But no performance problems. I am deathly afraid of handing the car to a dealership mechanic I don't know knows these cars. I am thinking it is some kind of pressure sensitive device causing my SES. I have read that fuel tanks expand and contract depending on the temperature, so my guess is that there is some sensor which is getting bad readings based on pressure in the tank which changes with temperature or a defective fuel cap. Please give us the codes your car is throwing, the codes I get off my car are kinda useless because they arent listed anywhere. We will protect you if BMW tries to kill you for giving out the codes, we are not in Germany.
Speakers: CDT Audio HD-42 comps--front doors (RAAMmat deadened), CDT ES-06 6.5" woofers--kickpanl Pods, Hertz EBX202R dual 8" ported trunk sub. Amps: Phoenix Gold RSd 500.4 (comps & pods). PG RSd 600.1 (sub). Power & Ground: 4AWG Streetwires w/RockFosgt RFDB1 distro blocks. Input: HU lineout--Kicker KISL RCA adapters--RockFosgt RFIT-6 cables--Audiocontrol Matrix--Monster cables--RSd 500.4--lineout Monstr Cabl to RSd 600.1.
12-26-2013, 09:55 AM | #4 | |
Captain Crunch
168
Rep 548
I asked my SA about the approx cost to fix this out of warranty and he said at the time, they were at $1.1k with parts and around $1.5k with labor. I'll get the final total when I pick up the car.
12-26-2013, 10:03 AM | #5 |
171
Rep 504
Same issue here. Scanned for the code (using a cheap ELM BT 327 and Torque app) the code that i was provided with: P21a9. Researched a bit and found that it is the code for the temperature sensor in active or passive urea tank. Cleared it for now using the "Torque" app on android. its been almost 500kms and it has not come back on.
12-26-2013, 03:11 PM | #6 | |
147
Rep 2,383
12-27-2013, 07:03 PM | #7 |
171
Rep 504
Here is what BMWhat says:
The code is still there, but its not throwing CEL until now. May be if it gets triggered a few more number of times, then it will show up as CEL. |
12-30-2013, 07:50 AM | #8 |
Rep 31
I have a 2011 335d and my SES light came on too. My car only has 22k on it. I'm in Cincinnati and Jake Sweeney had it for almost a week (while I drove a terrible 320xi). I get it back for 30 minutes and the light comes on again. I'm supposed to take it back this week. I'll post the codes it was throwing when I get home later.
12-30-2013, 09:43 AM | #9 |
411
Rep 3,049
Drives: 2009 BMW 335d
Keep us posted dude.
01-02-2014, 06:18 PM | #10 |
12
Rep 118
Looks like I am having this same issue on my 2011 with 32k miles. Got a persistent SES light 2 weeks ago in cold weather. Was finally able to get it into the dealer and they found that the DEF temperature sensor is faulty. They ordered parts that just came in, so we'll see how long it takes them to fix and get it back to me.
I am in a 528i xDrive loaner which, while not terrible, is definitely not a 335d. Can't wait to get it back. My wifi OBDII adapter and BMWhat app are ready when I get the car back. Chris |
01-02-2014, 09:28 PM | #11 |
Captain Crunch
168
Rep 548
They had the car for about 9 days. They had to order parts 3 separate times due to issues with what was said to be needed and what was actually needed. Dealership gave daily updates and offered to swap loaners when I complained about the 320xi. So if you are in Cincy, go see Rodney at the BMW Store.
Anyways, here is the invoice: The invoice says code 4D32. The code would come and go and was not on when I took it in for service, but was on when I called for service. They read the historical codes and found what I was talking about. Per the SA, the total would have been around $1150 with parts/labor. Not sure where he got the original numbers (in the 2-2.5k range), and I'm not sure I trust the above number either with how much labor they said was needed. Unfortunately my SA was out when I picked up the car, so I will try and get better numbers. Car seems to drive fine now, no issues or SES light.
Retired: BMW Welt Delivery 4/14/16: European Delivery - 2016 340i EBII/Saddle - ZMP | ZCW | ZDA | ZLP | ZTP | M Adaptive | Rear Shades | MPPSK Before and After Dyno Retired: 2011 335D Space Grey/Black - ZSP | ZPP | ZCW | 6FL | Sat Radio | Nav | $600 Base Audio Upgrade Last edited by cptcrunch; 01-02-2014 at 09:35 PM.. |
02-20-2014, 03:45 PM | #12 |
Captain Crunch
168
Rep 548
I wanted to bump this thread as my car is back in the shop. Same codes as before, but with a 'over pressure' sensor code and the vehicle went through 5 gallons of urea fluid in ~1600 miles. I dropped the car off on Tuesday and they are saying it wont be until mid-next-week before I'll have it back. I'll update once a solution is found, but I'm getting a little nervous. Warranty is up June 30 and I dont want to pay for DEF/Urea Tank issues out of warranty.
02-22-2014, 10:09 PM | #13 |
Rep 125
I had mine in for the same cold weather SES light. They wanted to drain the tank and refill it, naturally charging me $200 for a full tank of urea in the process. I told them not to worry about it.
A month later the car was in for something unrelated, and they ended up replacing the tank and sensor without even asking me, no charge this time aside from the $50 CPO deductible. |
02-23-2014, 12:03 AM | #14 | |
147
Rep 2,383
02-24-2014, 10:09 AM | #15 | |
Captain Crunch
168
Rep 548
I talked to the SA on Saturday (while on my back staring up at a Jeep 4.0) and he said they were shrugging their shoulders as they could not figure out why it was behaving the way it was. He said it went through 5 gal of fluid in 1700 miles, so maybe a stuck open metering valve. So they cleared the codes and did a couple of test drives and are going to let me know today.
02-24-2014, 12:08 PM | #16 | |
147
Rep 2,383
02-25-2014, 01:27 PM | #17 | |
Captain Crunch
168
Rep 548
02-26-2014, 01:35 PM | #18 |
Captain Crunch
168
Rep 548
Heard from my SA earlier today. Based upon the errors and readings, they talked with the Regional Engineer and he told them to replace the urea injector as it was crusted over with urea fluid and stuck open. They did clean it before replacement but replacement was ultimately advised as it did not fix the issue. My SA did say that there is a new bulletin addressing this issue, that BMWNA is seeing urea injector damage due to cold weather and water content in the urea fluid. The fluid has been freezing (despite the heaters) and causing all sorts of issues.
He said the part is $130 and that he would let me know the labor cost if I were out of warranty. This has been the only thing wrong with the car, and I hope this is the final fix or I might have to either dump the DPF system or go pick up a m235i from Europe.
02-26-2014, 05:09 PM | #19 | |
147
Rep 2,383
04-24-2015, 12:42 PM | #21 |
213
Rep 2,210
Being that it is fixed by replacing the entire tank/pump system, it has to be even though the sensor itself is not specifically covered. Since the tank/pump and sensors are all one part, they should all be considered the same warranty item.
04-24-2015, 09:12 PM | #22 | |
147
Rep 2,383
I assumed that this was a heater and I believe the Supply Module is the pump. If that is so, the pump and the tank are separate items. I cant find a part number or a diagram of the Active tank so I cant be sure. See http://www.e90post.com/forums/showthread.php?t=1114976
