2Addicts
2Addicts
2Addicts | BMW 2-Series forum Technical Topics Mechanical Maintenance and TSBs: Break-in | Oil & Fluids | Servicing | TSB Break in period
      12-21-2013, 09:22 AM   #1
mankid247
Wingman
mankid247's Avatar
110
Drives: M235i
Break in period
I am going to do ed on an m235 sometime in the spring and seeing as how I would get a chance to drive on some fast roads and what not wanted to push the car a little, one thing that I was wondering is how far can I push it speed and rpm wise without having to worry about the break in? My brother is a big enthusiast and he just got a new 335 in the fall and would not go over 3-4 thousand rpm for the first 1200 miles
2014 F22 M235i
2014 F30 335xi
2014 F31 328d // 2016 F85 X5M
2009 E60 M5 // 2004 E46 M3
2019 G05 X5 50i // 2017 Alpina B6 Gran Coupe
      12-21-2013, 11:14 AM   #2
Roundown
576
Drives: BMW
Two schools of thought on this:
1. By the book: until 1200 miles, keep revs low and varied (i.e. don't drone away at 2k rpm on the highway) and never, ever approach WOT in any gear.
2. Race Car Style: gun it from day one. Score the cylinders early and it'll be good for life.
In either case. Do what BMW requires of M cars, get the fluids changed after break in (oil, 6MT fluid and particularly the diff fluid if you LSD). With all the metals burrs in the first run oil, it's money well spent.
      12-21-2013, 12:32 PM   #3
M.barnes
41
Drives: 123d
Under 4k for 1200 miles is run in on m235i then oil change.
      12-21-2013, 03:27 PM   #4
Lucky13
Lucky13
Drives: 2014 M235 manual, 2020 X3 30X
Please don't turn this into the 1,000th when do we need to change the oil threads. Literally this has been discussed on every vehicle BMW makes and about every 6-8 weeks when a new person buys one and doesn't use the thread search.
1995 325i, 1996 328ci, 1997 528i, 1997 Z3 2.8, 2000 528i, 2001 X5 3.0, 2001 330i Convertible, 2002 M3 Convertible, 2003 M3 Coupe, 2004 M3 Coupe, 2004 Z4 3.0, 2004 X3 3.0, 2007 X3 3.0, 2007 335i Convertible, 2013 X1 28 sdrive, 2014 M235 manual, 2020 X3 30i Xdrive
      12-22-2013, 03:58 PM   #5
ska///235i
***** noob
ska///235i's Avatar
Drives: 325xi>M235i>428GCx Mspor
2006 325xi  [0.00]
The question here is not if the engine will get properly broken-in buy rather if you're out on the autobahn and not live it.
I did ED back in 2005 and drove my car to 140 mph...no regrets and still have the car today
Also when they QC the car from the factory do dino up to 120mph
2006 325xi (Sold)
2014 M235I (Current)
2015 428xi Gran Coupe (STB)
      12-22-2013, 04:00 PM   #6
mankid247
Wingman
mankid247's Avatar
110
Drives: M235i
And that's what I was looking for... Did you work up to it or did you put the throttle down more or less?
2014 F22 M235i
2014 F30 335xi
      12-22-2013, 04:01 PM   #7
ska///235i
***** noob
ska///235i's Avatar
2006 325xi  [0.00]
Didnt redline it or at least not long
2006 325xi (Sold)
      12-22-2013, 05:39 PM   #8
Sy546
44
Drives: E36 M3, E46 M3, E92 M3
its more important to break in your brake pads and tires semi-gently. first couple of hundred miles
      12-22-2013, 07:00 PM   #9
Greenkirby21
Vrooom :)
Greenkirby21's Avatar
Drives: C7 Stringray
If I was doing ED I would go on the autobahn and nurburgring! That's why you are there right
As long as you don't kill the car, I think you should be ok! Just make sure the engine is warm
2014 C7 Corvette Stringray - Laguna Blue - NPP Exhaust - Competition Seats
      12-23-2013, 12:41 AM   #10
mattssi
875
Drives: 2019 X3
I've NEVER done a break-in period on a vehicle. If you did ED, you'd be losing out. Drive it like it should - nothing will happen. If they can't make a car that can be driven hard off the lot - f em.
2021 ///M3
2019 X3
      12-23-2013, 05:18 AM   #11
Math
Math's Avatar
Belgium
10
Drives: BMW F21 116D
+1 on this!
2012 - BMW F21 116D ED
Please check my amazing car rental website at http://www.bscc.eu!
      12-23-2013, 07:01 AM   #12
Vervain
398
Drives: .
      12-23-2013, 03:05 PM   #13
Ganxxta
Germany
85
Drives: F32 4er Coupé
Just a small heads-up for everyone doing ED:
Most parts of the german Autobahn are limited, be careful to go only full-throttle on unlimited parts, otherwise you might loose a few $$$
Have fun.
      12-23-2013, 06:21 PM   #14
Ramos
Ramos's Avatar
Drives: G20 2020 M340
Or you could do 140 MPH without redlining the car or ever exceeding 4000 RPM
      12-23-2013, 07:05 PM   #15
ska///235i
***** noob
ska///235i's Avatar
2006 325xi  [0.00]
No way you can do 140 w/o exceeding 4k rpm...impossible
2006 325xi (Sold)
      12-24-2013, 02:14 AM   #16
wdlfbio
68
Drives: 2013 4S, 2015 3500 HD Dually,
ED for a 328xi, hit 100 often but not 120 mph until after 1,200 miles. Second ED Z4 35is, didn't abuse redline, but waited for 160 mph until 1,200 miles. Plenty of spirited driving until the 1,200 mph. Next car might be the 235i and that will go from Munich to the Ring. If it blows up, that's what warranty is for .
'16 235i
'15 3500 HD Dually
'13 C4S
      12-25-2013, 11:21 AM   #17
Ramos
Ramos's Avatar
It depends on gearing, on my ED trip driving my brand new E90 335, I was cruising along on the autobahn at 120 MPH at around 3500 RPM in 6th gear.
      12-27-2013, 02:51 PM   #18
w3rkn
10
Drives: BMW 135is
BMW break-in:
Start the car and let it idle at least 5m before driving, then.. when it is @ operating temp.. it is yours do what u want.
Very simple!
      12-27-2013, 03:34 PM   #19
Red Bread
Drives: Smog machines
Originally Posted by w3rkn View Post
BMW break-in:
Very simple!
Just about the worst idea, as undue idling is hard on a car, five minutes of idling is almost certainly not enough time to heat the oil and this will also do nothing for transmission temps.
Just ignoring break in protocol, the best way to warm up a car is to actually drive it. That way the transmission also warms up with the motor. Ideally, you'd rely on an engine oil temperature gauge, not a coolant gauge to determine when it's safe to bring the revs up. This is what recent M cars indicate with the variable redline. Most BMW manuals give you guidelines of what the oil temp should be at before exceeding 4k rpm and redlining.
      12-28-2013, 06:42 AM   #20
w3rkn
10
Drives: BMW 135is
That is not what I have said.
I said START your car and leave idle for 5 minutes, before you drive away every morning, every night, every time. (specially if u have a turbo engine)
Then, while you are out & about driving casually, when the engine is at nominal, then u can have fun with it, and have no qualms. That doesn't mean take it to the track, or bounce it off the rev-limiter, it just means u need to know when it is ok to step into a fresh engine.
      12-30-2013, 02:08 AM   #21
nunka
perpetually salty
nunka's Avatar
Drives: '13 AW 6MT 128i M Sport
That's exactly what you said, and he's acknowledging that and saying it's bad. The official word from just about every BMW owner's manual (take that for what it's worth) is do not let your engine sit idle for any significant amount of time before driving it. Wastes gas, invites condensation build-up, does not actually do much warming up, etc etc. You "warm up" your car by driving it gently until it's at operating temps.
      12-30-2013, 09:14 AM   #22
dmboone25
dmboone25's Avatar
4972
Drives: 2024 Golf R / 2022 718 Spyder
2007 E92 328i  [10.00]
2007 328i  [10.00]
This is such an interesting conversation to me - I was at my Ducati dealer the other day and was having the same convo about my bike (I ride in the winter), so I was curious about his thoughts on the topic.
He said that you should let the bike warm up for a few minutes, especially in the cold. Mentioned that "allows the oil to heat up" before you start actually driving.
I have never let any of my cars or bikes warm up - unless it's for a minute or two running back into the house to get something in the morning. Not because I am mechanically inclined, but because I know it wastes gas.
Would there be any kind of difference between how you might handle a bike vs. a car in terms of warm up ? Just curious to see what you guys think.
Past rides: 2016 981 BGTS, 2020 MINI JCW, 2017 F80, 2015 981 CS, 2014 F22 235, 2011 E82 135, 2008 E82 135, 2007 E92 328, 2007 E92 328 (My lady drives an OG M2. So does my dad)
2addicts
