Rattle from throttle pedal.
10-30-2007, 11:21 AM | #1 |
1869
Rep 13,043
Drives: BMW M340I G20
I don't know if anyone else has the same, but my throttle pedal sound really cheap and plasticy,(not a real word) I’ve looked at it close up, it's where the connecting rod locates in the back of the pedal, there a socket and pushrod arrangement, but mine has too much clearance between the two, and rattles about when no pressures applied.
Is it just mine or has anyone noticed? |
10-30-2007, 11:24 AM | #2 |
Moderator
325
Rep 5,493
Haven't noticed that on mine, and I'm PICKY about rattles as some people on here already know. I'll go have a look at mine, but I'm pretty sure there's no play in between..
... ... DMS Remap Review ----- Quaife LSD Review ----- Hartge Antiroll Bars Review ----- Bilstein PSS10 B16 Ride Control Review ----- Detail by ShineOn ----- Paintshield Review |
10-30-2007, 11:27 AM | #3 | |
1869
Rep 13,043
If I lift the top edge of the pedal, I can feel a movement of about 2mm, I need to have a closer look at the weekend, and see if I can take up some of the slack in any way. |
10-31-2007, 04:10 AM | #4 |
15
Rep 239
I have a slight clicking sound when I lift my foot off - not sure why will investigate over coming days
Le Mans Blue 320D Blacklines MSport 18"193's /Black Dakota Heated leather/Auto Rain & Light Sensors/Comfort Access/Xenon Lights/6FL USB Port/Bluetooth/Sun Protection Glass/Park Distance Control
10-31-2007, 05:24 AM | #5 |
1869
Rep 13,043
10-31-2007, 03:00 PM | #6 |
85
Rep 2,353
Drives: 2009 Z4 sDrive 23i
When lifting quickly and returning to normal it can sometimes click... but is this not the detector thing that detects ff you are going to brake quickly and prepares the brakes (or something along those lines?)
E89 Z4 sDrive 23i... for the more discerning driver
11-05-2007, 06:57 AM | #7 |
1869
Rep 13,043
Update..
At the weekend I decided something had to be done, so I sheeted up the drivers foot well, and set to with my lithium spray grease, I managed to get some between the pushrod and it's little socket on the back of the pedal, after the solvent in the grease disappeared the pedal fell silent, ah bliss. |
11-06-2007, 03:06 AM | #9 |
15
Rep 239
ok - having investigated a little further it appear the sound is a spring - I have put some grease around and se what will happen
