Reverse Led Lights
12-17-2013, 08:40 PM | #2 |
Came to the N55 Darkside
1112
Rep 12,740
I've had the LUX ones for 2 years and love them. Yes, they blink on start up because of the bulb check, but I honestly couldn't care less enough to code them out.
12-17-2013, 10:00 PM | #4 |
72
Rep 702
I got all my LEDs coded for cheap from one of the guys on the forum. As well as Alpina flash, brighter lux, auto folding mirrors when locking, amber corner led delete all for $100 bucks. Took 30 min and he came to my job. Well worth it
12-18-2013, 04:14 AM | #5 |
No 55mph
1622
Rep 8,476
There aren't any LED's that won't blink during startup - due to OEM bulb check.
Only way to eliminate is to code out the Cold/Warm Bulb checks...
F32 435ix//MGM//M Sport-Prem-Tech-Driver Assist-Lighting-Cold Weather-Dyn Handling Pkgs//M4 Black Lthr Int w/M4 Alum Blade Trim//HK w/Bavsound Stg3//763M//M4 Euro LCI Tails//M4 Mirrors w/CF Covers//AWCarbon CF F/R Spoilers-Side Splitters-Diffuser 6WB/ID6 HU+HUD/IND M4 Alcantara Armrest//PURE S2 Turbo//AA FMIC+DP//ER CP+TIC//3.5bar TMAP/TS DV//AWE Tuning Exh w/Blk Tips//Turner MS CF Intake//BM3 Cary Jordan Tune//MPerf Diff//PrecRW Ignition Kit
12-18-2013, 05:06 AM | #6 | |
1112
Rep 12,740
12-18-2013, 12:37 PM | #7 | |
BimmerPost Supporting Vendor
469
Rep 4,938
Glad everyone's happy with the LUX Backup lights though!
12-19-2013, 12:02 AM | #8 |
Brotographer
88
Rep 1,741
I'd just code, and then make it part of your bi-weekly/monthly routine to check. And honestly, if you're careful with coding, I THINK it's possible to code it in such a way that it will throw error if the bulb breaks the complete circuit when it dies. Because if you unplug an LCI tail light, it flashes turn signals quickly and says "rear L turn signal out, take to dealer yadayada". So there must be a combination of codes that would allow for it to perform something like a "ping" test in networking terms...just see if a flash of current makes it across to the other side.
12-19-2013, 02:00 AM | #9 | |
No 55mph
1622
Rep 8,476
And the bulb checks already are pretty much as you describe with your 'ping' theory. System shoots a tiny current thru the circuits - as long as there is continuity - bulb is deemed OK. Problem is, the current sent thru the system during bulb checks is small enough to NOT light an incandescent style bulb - but LED's need very little current to excite - hence the flashing. There are no coding lines to reduce the amount of current sent thru the system during bulb check AFAIK... The LCI models that use LED's from factory use the FRM3 module - which is designed to accommodate LED's specifically - that's the reason there is no problem with the LCI cars & they behave as you state. Problem comes when you retrofit LED's into a car that did not come with them - those cars use the FRM or FRM2 modules that were designed for incandescent style bulb systems.
