best place to put a ballast for a hid kit
10-29-2007, 09:05 PM | #4 |
8
Rep 166
let me know if it works out with the halogen housing and hit kit without warning. I'm thinking of doing the same but don't want to waste money on hid kits where it gives me warning. Still in college, so money is an issue right now.
06 325i - Standard |
10-31-2007, 02:41 PM | #6 |
Too many Alex's, from now on, call me Beaufort
342
Rep 6,188
Its really not that hard to remove the fender lining. I just did it when I installed my LUX. Takes about 5 mins once you have the wheel off.
13 HD FatBob
17 A4 Glacier/Black 1st Edition/Pre+/Sport/EurocodeTMD/Racechip 16 S6 (gone),14 S6 (gone),14 S6 (gone),13 S6 (gone),10 S4 (gone) 07 335i(gone) |
10-31-2007, 09:11 PM | #7 |
8
Rep 166
How hard was it to do the wiring? or did it came pre-wire and all you have to do is connect things?
11-01-2007, 04:54 PM | #11 |
8
Rep 166
My friend and I installed the hid kits on his e30 M3. It was easy, everything was pre-wired, all we had to do is drill a hole and connect the wires, and plus his car doesn't give any warning to anything so it was easy(Cheap). Drilling the hole on the back covers wasn't hard. We drilled it out and sealed it with hot glue. It's sealed very good. I'm just worrying about cutting any extra wires. If all I have to do (after i get the right hid kit without warnings) is drill 2 holes and connect the wire, I can do that.
11-01-2007, 05:00 PM | #12 |
309
Rep 2,458
yea thats all you have to do, i believe creative, jlevi, and UED are all selling these for 150 without errors.... hmm im not sure i want to drill, but i want hid kit.
11-01-2007, 05:07 PM | #13 |
17
Rep 144
11-01-2007, 07:09 PM | #14 |
8
Rep 166
$150 for the error removal kit or for EVERYTHING?
11-01-2007, 07:50 PM | #15 |
20
Rep 650
It's actually $149 + $20 for the resistors from Jlevi. With the resistors all you have to do is attach one end to the low beam positive and the other end to the ground and you should get no error. I just got my kit today and haven't hooked it up yet. I'll do it on Monday or Tuesday. The only difference with what you guys want to do and what I am doing (and what tino did) is that I am using OEM xenon housings.
"it remains the benchmark by which all competitors, including Lexus, must be measured."
11-01-2007, 10:03 PM | #17 |
8
Rep 166
Saw this on ebay: http://cgi.ebay.com/ebaymotors/MTEC-...spagenameZWDVW
Does that work correctly? Does that kit actually give out no error message?
11-01-2007, 10:09 PM | #18 | |
17
Rep 144
http://www.e90post.com/forums/showth...=84882&page=12 |
11-01-2007, 10:28 PM | #19 |
8
Rep 166
o nice. The pictures look nice, what temp did you get? Do you have to do anything to replace from halogen to xenon after getting hid kit to work? I mean would you have to connect extra wire to the xenon housing?
11-01-2007, 11:27 PM | #20 | |
17
Rep 144
And a little modification on the spring clip which hold the bulb, http://www.e90post.com/forums/showpo...&postcount=241 |
