BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > Cosmetic and Lighting Modifications (exterior/interior) > How to remove 3M residue from splitter
      10-29-2007, 05:50 PM   #1
wingineering
Drives: 06 AW E90
I want to reinstall the splitters, I got the splitters taken off from the bumper, and want to retape this whole thing.
The original 3M tape that comes with the spitter is no good, but removing the tape and its residue is absolutely a pain.
I try to peel this thing off by hand, but it only comes off less than 1/10 of an inch at a time.
What is the best way to get this thing off?
      10-29-2007, 05:51 PM   #2
3onDubs
You live by the sword...
3onDubs's Avatar
216
Drives: M4
2007 328i  [0.00]
That's the hard part....you're going to have to do it 1/10 at a time....either with your finger nail or with a razor blade.
Call up some friends and throw a "1/10 at a time" party
      10-29-2007, 06:01 PM   #3
wingineering
Drives: 06 AW E90
i have to add that after peeling one tiny spot at a time, there is also some heavy residue/gum remaining, n i have to rub the hell of it to get that spot clean..
i don't want a 1/10 of an inch peeling party and another 1/10 of an inch rubbing party ..
      10-29-2007, 06:02 PM   #4
ejazbmw
blahhh
ejazbmw's Avatar
302
Drives: 2014 M235I
i wonder how goo gone would work for this...worth a shot
      10-29-2007, 06:03 PM   #5
3onDubs
3onDubs's Avatar
216
Drives: M4
2007 328i  [0.00]
I did this with some old side skirts (from my e46) and for my trunk lip spoiler (had to reinstall it properly). That tiny bit that is left after peeling...I just left that there and put a new layer of 3M over it. Just be sure to get 90% of it off so that it sits flush...
      10-29-2007, 06:04 PM   #6
3onDubs
3onDubs's Avatar
216
Drives: M4
2007 328i  [0.00]
not a bad idea (for the tiny bit that is left at the end)
      10-29-2007, 06:26 PM   #7
khuuster
Hella Nor*Cal Vinyl
khuuster's Avatar
Drives: 2015 M3 f80 Alpine White
use a blowdryer, it might help in the process
      10-29-2007, 09:33 PM   #8
E90 Agio
Indonesia
19
Drives: E90 Agio
you can use bit of gasoline.
it wont damage your paint job...I used that before and everythings is fine.
you can try for it..good luck
      10-29-2007, 09:36 PM   #9
wj4
Drives: E90 manual 335i
Use a hair dryer to heat up the splitters and slowly remove it, the glue will become less resistance this way. Use Goo Gone to remove any residue that is left behind.
      10-30-2007, 01:10 AM   #10
brandon @ eas
brandon @ eas's Avatar
Drives: F30 335i
I agree with the Blow dryer. I have had the 3M aftermath several times, and if you heat it up enough, you can literally roll it off in one piece!
      10-30-2007, 03:01 PM   #11
MLK407
Drives: M3
hair dryer will help, this is a royal pain in the ass however. it will take a bit of time
      10-30-2007, 03:07 PM   #12
LENELSA
LENELSA's Avatar
Drives: 2016 Audi A6 3.0 /BMW M240i
WD-40
      10-30-2007, 04:22 PM   #13
Eberhard
Drives: '08 335i Monaco
I use a product called "Goof-Off" available at most hardware stores in small cans. Apply it with a soft cloth and just gentle rubbing will remove most adhesives without disturbing the clear coat. Afterwards, let it air dry completely and apply a good wax such as Zaino Bros. over the area you cleared.
As always, try it on an unseen surface first to be certain (under the hood?). I have used it for years on some very expensive vehicles with 100% success.
Eberhard
      10-30-2007, 05:00 PM   #14
Swoop
Resident Noob
Swoop's Avatar
Drives: You Crazy w/ My Rear Fogs
2007 335i  [0.00]
2004 Acura TSX  [0.00]
easy, use Afta and just rub with your hands and it'll rub off.....
A/W 335i e90 l Sirius l M6 Wheels l M5 Bumper l Eibachs l 20% Tint l CPE Exhaust & Standback l BLK Matte Trim l Xenon Interiors l Lux 4.0 l 8000k D1S l MTEC H7/H11s l Invisibulbs l BLK Matte Grill l Blacklines l Alum Pedals l Splt Armrest l Rear Fogs l RBT l K&N
