Pair of Swift 336lbs springs, Tckline front coilover over shocks, stock sports rsb
12-15-2013, 09:56 PM | #1 |
12
Rep 248
One pair of Swift 336lbs coilover springs . 8 inch length. These are a pair (2 springs) in total - all are 60mm in inside diameter and meant to be used on coilovers. They are NOT oem style springs - you MUST have coilovers with adjustable perches to use these. Please confirm which diameter and length springs your coilovers use - that is not my responsibility. Asking 95.00 shipped for the pair. One set of Ground control street camber plates setup for 60mm springs. Asking 190.00 -- SOLD Used for roughly 3500miles. Never used in a winter. Now off the car. I also have the pair of tckline coilover shocks. However, these came off the car because the driver's side adjustment was ceased in full soft. These are still under warranty I believe I can send for replacement. The passenger side is working fine. I the driver side go for cheap. If I send for for replacement I will sell the two as a pair in a couple months. Other parts I have available. OEM sport rear sway bar. Sports suspension shocks/springs/oem plates 18k of mileage. Last edited by sutter2k; 07-25-2014 at 10:25 AM.. |
12-16-2013, 11:04 AM | #3 | |
12
Rep 248
I have those I have a new set of 60mm Swift Thrust Sheets I also have those red Front spring upper perches listed in the kit below. However, I believe those are only applicable when running stock top mounts. These are already 60mm plates. http://hpashop.com/product.sc?produc...categoryId=152 I believe this is what it would look like, bottom shock in picuture(just with gc plates). Last edited by sutter2k; 12-16-2013 at 11:11 AM.. |
12-17-2013, 10:52 PM | #5 |
12
Rep 248
12-30-2013, 11:38 AM | #7 |
12
Rep 248
Camber plates sold.
Still have OEM sport rear sway bar. Sports suspension shocks/springs/oem plates 18k of mileage. One pair of Swift 336lbs coilover springs . 8 inch length. Asking 145.00 shipped for the pair. Front pair of tckline coilover shocks. (1 needs warranty service). |
