leaking oil
12-13-2013, 06:32 PM | #2 |
681
Rep 3,696
Oil Filter Housing Gasket (OFHG). Its covered under CPO, usually what happens is the oil leak will also kill your water pump and u get both done for the $50 deductible. While they have it apart... Make sure they also check your valve cover gasket for leaks.
12-13-2013, 06:41 PM | #3 |
12
Rep 39
thanks fazman. unfortunately i ran out of warranty not to long ago. do you how difficult it is to replace the gasket?
12-13-2013, 08:15 PM | #4 |
138
Rep 2,731
12-13-2013, 08:26 PM | #5 | |
681
Rep 3,696
On my 335 i hear it should be a 2 hour job @ indy mechanic rates. |
12-16-2013, 08:39 AM | #7 |
30
Rep 644
thee325i. You need to do this right away and you need to replace your serpentine belt. The oil has been leaking on it for a while and it looks like it is about to come apart in the picture. You don't want that happening. It can damage a lot of stuff if it breaks while the engine is running.
12-16-2013, 09:00 AM | #8 |
74
Rep 2,848
Simple fix. Not as bad as it looks. and as others stated after its cleaned up and fixed get a new serp belt since it looks like quite a bit has dripped on it.
