BMW X3 Forum
BMW X3 Forum
      12-11-2013, 11:02 PM   #1
exon
25
Drives: 2014 X3 35i Jet Black!
Exhaust Drone on a 35i?
Got my X3 35i for a month and find the exhaust drones when cruising around 75-80, especially when in 8th gear and going up hill.
Anyone notice the same thing? What's the best aftermarket mod to reduce droning?
      12-12-2013, 09:01 AM   #2
n55x3
72
Drives: n55 BMWs
When there is load on the engine it will drone a bit, not much you can do about that. Maybe shift back into 7th (increase RPMs slightly) and the drone will turn into more of a wail which might be less annoying. Stepping up to a larger model like X5 would probably eliminate much of that drone due to increased sound deadening materials used in the more upscale vehicle. You won't find any after market exhausts that are quiter, typically the after market exhaust goes the other way in that it will be louder.
My wife drives our 35i X3 daily and for the first 3 years of ownership I had unplugged the exhaust flap which created even more drone but I liked it as I liked hearing the N55 do it's thing (typically the flap only opens under cold starts and hard acceleration). Just last weekend I plugged it back in (now flap works as intended) and I was shocked by how quiet the X3 rides now.
      12-12-2013, 10:03 AM   #3
lbjgh
lbjgh's Avatar
105
Drives: 2013 AW X3 M-Sport
There is a flapper in the muffler that opens and closes (search golf tee mod).
Perhaps the valve is not operating correctly...
I find the 35i fairly quiet at 'speed'.
2013, AW, xDrive35i, M Sport Package, Technology Package, Dynamic Comfort Package, Premium Package, 3M Clear Bra, Euro foglight switch, a few coded fixes
      12-12-2013, 10:23 AM   #4
The X Men
99
Drives: 2013 X3 35i
What some people called exhaust drone, other call exhaust note The 28i doesnt have the same exhaust note, its quiter. I am guessing the 35i's exhaust system is a bit more free flowing than the 28i's. To get rid of the exhaust note, you can try changing the muffler to a more restrictive one like the one you can find at Midas
      12-12-2013, 01:52 PM   #5
Pitiful Old Man
Drives: 2011 X3 35i
Have your exhaust system checked. Our 2011 35i with 30K+ miles has no noticeable drone. Could be a gasket, the valve, or a problem with the muffler.
      12-12-2013, 04:11 PM   #6
DonC
Drives: 2013 X3 3.5i M sport, etc
I like it!
2013 X3 3.5i AW,Msprt,rear fogs,PS,CP, Tech, etc...
Other cars
2005 S2000
2018 i3S
      12-12-2013, 05:02 PM   #7
c3uo
39
Drives: 3 Series
Mine has droned on highway since new. Hate it. Told it was normal. It is worse below freezing as exhaust steel and floor pan resonate more at low temperature. Otherwise love the vehicle. Have thought about trying remus exhaust and/or adding more sound insulation to trunk floor liner. Don't hear engine at all, only exhaust and wind noise on highway.
      12-12-2013, 06:57 PM   #8
danox3
danox3's Avatar
Drives: X3 M Sport
Sounds
I would suggest this too, though it's probably normal.
Glad I found this board as I just got an M Sport 35i.
      12-14-2013, 04:15 PM   #9
exon
25
X5 doesn't seem to have that flap. It has dual exhaust so probably don't need the flap to provide enough air flow.... That's my guess.
I will probably looking into putting some sound proofing in the trunk area.
      12-14-2013, 04:17 PM   #10
exon
25
Dealer said it is normal...
The 28i is much quieter at cruising, surprisingly.... My previous 535i doesn't drone one bit.
xbimmers
