What's your 1/4 mile drag radial set up????
10-28-2007, 09:37 PM | #1 |
Perf BMW mag issue 147, 159
414
Rep 6,803
Please post up guys!
Im trying to decide on a pair of wheels for the track to match up with some drag radials. Right now im debating about going with a 17x9 +35 wheel with 275/40/17 bf goodrich drag radial tire...
'13 Estoril Blue 335i M-sport
*Don't PM me!* Message me here- http://www.facebook.com/ProjectEstoril |
10-29-2007, 12:23 PM | #2 |
ASR Turbos+LSD+Meth= :D
73
Rep 1,517
Drives: E92 335i
a 275 mm rear sounds like a 17x9.5 to me.... not 9
2007 335i Coupe Mods: Check the Garage |
10-29-2007, 01:27 PM | #3 |
414
Rep 6,803
+1. I agree and thats what I have for the Lexus (Supra TT wheels) for track. But I cant find a 17x9.5 lightweight wheel with a bmw bolt pattern..
10-29-2007, 06:05 PM | #4 |
73
Rep 1,517
Drives: E92 335i
strange honestly try 18's then, i dont think a +1 inch diameter will make as bad as a difference as getting 20 mm wider
10-29-2007, 06:24 PM | #5 |
pew pew
166
Rep 6,781
Is it really impossible to fit 16s over the rear calipers? I didn't think the rear brakes were that big... Don't the 328s/325s come with 16s stock? Do they use the same brakes?
I'd really try to find a 16x9 rim and mount the DRs on that. If not a 275 then a 245, it should still hook hard... I've seen street cars cut 1.6s on 245 DRs. I'm going to try and find a 16" and 17" wheel from a camaro or firebird or vette and see if it works. They use the same bolt pattern.
CSL replicas are now CSL counterfeits. Jesus saves, like Valentine1.
10-29-2007, 07:46 PM | #6 | |
414
Rep 6,803
Really? The C5 vette wheels would be cool if the offset is right. Im not sure if 16's will fit or now but I know 17's will
10-29-2007, 08:45 PM | #7 |
Rep 30
The offset on C5 wheels is way off, and the bolt pattern isn't exactly the same, off by about .65mm or something like that. The specs on the 275's say they will fit on 9" wheels.
10-29-2007, 11:04 PM | #8 | |
73
Rep 1,517
Drives: E92 335i
10-30-2007, 03:29 PM | #11 |
40
Rep 983
Go kosei K1 from tire rack, they are 16.8lbs and only cost $165. Get the BF Goodrich T/A II, they are bettr than the T/A. With the configuration that I gave you you will save 13-14lbs per tire/rim. If you go with a smaller tire(265 or 255) you could save another 2-3 lbs per tire.
10-30-2007, 07:28 PM | #12 | |
73
Rep 1,517
Drives: E92 335i
http://www.tirerack.com/wheels/resul...All&sort=Brand
10-31-2007, 10:49 PM | #13 | |
40
Rep 983
Uhmm... that is weird, I posted the source on this post: http://www.e90post.com/forums/showthread.php?t=87825 OK, never mind, I know why, you were looking at 18" and the k1s are 17". The k3s are 18" |
11-01-2007, 10:29 AM | #14 | |
414
Rep 6,803
11-02-2007, 12:42 AM | #15 |
Samtaro!
124
Rep 2,601
I ended up getting BBS RC's 18x8.5 37mm offset all around... for both drag and autox applications. I'm going with Kumho V710's 245/35-18's... hope they stick For sure it'll be better than my current setup, which is all show no go.
11-02-2007, 01:55 AM | #16 |
pew pew
166
Rep 6,781
Honestly the Kumhos aren't a very good drag tire, and 18" isn't the best for it either. Nothing really beats a real drag radial or drag slick. The composition and properties of drag vs. autox and RR tires are very different. Regardless, it will still be stickier than stock tires on the strip, and a lot stickier on the autoX.
11-02-2007, 02:01 AM | #17 |
Samtaro!
124
Rep 2,601
Yes I know its going to be a compromise... but oh well didn't want to spend another ... $6-700 or so for a pair of Kosei K1's and Drag radials
11-02-2007, 02:10 AM | #18 |
pew pew
166
Rep 6,781
I agree. I will probably skip on a drag setup as well and just go with an autoX setup which I would double up as drag use.
