12-09-2013, 10:34 PM | #1 |
48
Rep 397
Drives: 2018 540i M Sport2015 535i M S
Low tire pressure
Recently have been having low tire pressure warnings quite a bit, is it the weather or just a common problem with run flats? Also today I had one but only for the right rear tire.
Any solutions? Nitrogen possibly?
2018 540i M Sport Alpine White
2015 535i M Sport (Past) 2012 328i Luxury Line (Past) |
12-09-2013, 11:01 PM | #3 | |
51
Rep 1,831
Drives: 335i MSport + MPS/MPPK
12-09-2013, 11:11 PM | #4 |
48
Rep 397
Yea I do usually check it, the fronts have more air then they need about 40 instead of the 32 the rear one was down to 20 or so.
Any one have experience with filling tires with NITROGEN?
12-10-2013, 01:20 AM | #7 |
5714
Rep 3,227
12-10-2013, 02:06 AM | #8 |
40
Rep 125
Drives: 2013 328I Sportline
Mine went off 2 days ago and i bumped them all back to recommended pressures. They all dropped about 4 psi since it weather got colder. Reset tpms and so far so good.
12-10-2013, 02:12 AM | #9 |
342
Rep 1,325
It's probably the cold, as was mentioned.
Nitrogen is a useless ripoff for a road car. If you have a leak, you have a leak. Nitrogen won't "fix" it. A properly mounted and sealed tire assembly will go many months without needed any added air. |
12-10-2013, 07:17 AM | #11 |
9
Rep 161
Was just one rear one down to 20, or both? If it was just one, I'd suspect a nail in the tire with a slow fiz. Keep inflated and find someone to check it out who will fix a runflat.
12-10-2013, 07:24 AM | #12 |
922
Rep 1,156
One tire down to 20 will definitely trip the TPMS on since the others are much higher. Temps vary wildly where I live and I've never had a TPMS go off on me for temps changes.
2020 M2C 24.04.2020 delivery - Sold 24.08.22
12-10-2013, 08:20 AM | #13 | |
317
Rep 3,619
EBII 2014 335i xDrive
335HP, Sport AT, 19" Wheels, MPE, Prem, Tech, Cold, HK, Driver Assist & DH pkgs Deep Sea Blue Metallic 2013 X5 35d Sport Prem, Convenience, Cold and Premium Sound packages |
12-10-2013, 08:30 AM | #14 |
160
Rep 2,248
I use the 78% nitrogen formulation. If you get a TPMS warning, with runflats you really have to check the pressure in all four. You can't assume that you don't have a flat. That's what makes coding for the pressure and temp display at all four corners the most useful coding change available, at least for me.
12-10-2013, 09:21 AM | #15 | |
Too much is never enough
655
Rep 3,079
OP doesn't your car handle like crappie with such terrible pressures? It will understeer like a pig. |
12-10-2013, 02:06 PM | #16 |
230
Rep 1,554
For every 10 degrees from your initial fill drop in temp your tires will decrease in approx 1lb. I noticed my warning goes off when I am down between 3-5lbs. Nitrogen is suppose to fix the issue of fluctuating, BUT not in extreme temperature changes because the temp properties of rubber vs aluminum expanding and contracting are different.
12-10-2013, 09:04 PM | #17 |
48
Rep 397
Yes it does understeer and there is always a pull to the right.
I received the low tire pressure warning again about 2 hours ago on the same right rear tire, it went down all the way to 10PSI I filled her up to about 40PSI hoping it will solve the problem.
12-10-2013, 09:05 PM | #18 |
48
Rep 397
Im going to have it checked for any leaks tomorrow morning.
12-11-2013, 04:57 PM | #19 |
48
Rep 397
So I went to a local autobody to have my tire checked out and I had a nail in my tire. They sealed it up and said it should be good for a while. They are asking for $275 if i need to have it replaced, including installation, I found my tire for $155 on tirerack.com.
