The Tire Rack
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > Mechanical Maintenance: Break-in / Oil & Fluids / Servicing / Warranty > Help!??!!? Aa Bov Diy
      10-28-2007, 11:33 AM   #1
BMWdmk
*Rollin 3rd*
BMWdmk's Avatar
Drives: Something fast
so yesterday
i went and took an AA Tuning BOV off some1's hands
started the DIY with a couple of buddies
All was going good until we had to fit the intake pipe to the
THROTTLE BODY
so we get it on but not COMPLETELY all the way and decided to jsut test it out
...the first blow off was rough but the second and following sound right
now heres my problem....how do u get that darn pipe on the throttle body
i have a reduced power limp mode cuz it seems like ai have a leak at the T/H
SOME1 PLZ HELP! lol
ill buy u in n out lunch if some1 can help
      10-28-2007, 11:47 AM   #2
scooby9
scooby9's Avatar
61
Drives: 2007 E90 BMW 335xi
Check out this post:
http://www.e90post.com/forums/showth...&highlight=bov
It sounds like a biz-natch to get on but it's do-able if you have the correct angle.
2007 BMW 335xi 6MT TiAg
      10-28-2007, 06:59 PM   #3
BMWdmk
*Rollin 3rd*
BMWdmk's Avatar
problem solved
thanks man that really did help me
so here the update
everything works no reduced power codes or anything
one problem is that the BOV seems to blow off late
any1 think this is bad?
      10-28-2007, 08:28 PM   #4
scooby9
scooby9's Avatar
61
so here the update
That could be an issue. As soon as you let off the throttle, the valve should open instantly. Otherwise, it could cause the turbos to wear quicker because of the sudden back pressure when the throttle body closes up. How much of a lag is there?
      10-29-2007, 08:46 PM   #5
BMWdmk
*Rollin 3rd*
BMWdmk's Avatar
an all right amount, like i have a feeling its misfiring
its only when i full throttle it
but active autwerk claims this harness should fix my problem
according to the codes i sent them
but lemme know wut u think is happening
i like my turbos!!!!!!!!!
