e90 props from an IS350 owner
12-13-2005, 12:06 PM | #1 |
16
Rep 274
so i was having some buyers regret with my e90 caus eive been seeing the is350's and they really grew on me QUICK so i was checking out the is forums and came across this which i thought was nice...enjoy
http://my.is/forums/showthread.php?t=275527 -------------------------------------------------------------------------------- Hey guys, I just bought my IS350 is crystal white with black int. I have 2500 miles on it so i am past the break in. I was out driving around with 2 of my friend which one of them owns a brank new e90 330i in stick and my friends 04 G35 coupe also 6 speed. we decided to go to an abandond industrial road which is like almost 5 lanes deep. We line up next to each other. 3 Honks later we all take off. The BMW got us both i was right on the E90 rear door panel. and the G35 was aprox 1/4 car length back. Well Im not going to even mention the G35 after this point since me and the e90 both pulled on him slightly. But hell at about 45mph i was starting to catch up to the bmw i was right on his front wheel well... we both then hit 60mph and about dead even, im starting to slightly pull at about 70 mph. Then little do i know his power in 3rd gear just kicked in. Hes starting to catch up. By the time we were done at 105 mph. i was on his rear bumper. I said hell i got a bad luanch. So the G35 stayed out of this one since we were curious. 1 time 2 times, same out come. WTF? si we switched cars he drove the IS and i drove the bmw. well same thing, another 2 times. So then i said you werent trying. My friend in the G35 said, here ill drive the BMW u drive ur IS, so we did. and Another 3 times we go. and SAME OUT come AGAIN!.. well my friends 330i has 1900 miles on it. and i must say. UNDER rated they are, and if u catch someone on a bad day who knows how to drive well.. like i did, i ate the dust.. Ow well.. he still drives a BMW lol... Last edited by 808six; 12-13-2005 at 02:50 PM.. |
12-13-2005, 12:39 PM | #4 | |
there is no spoon
243
Rep 867
[SIGPIC][/SIGPIC]
12-13-2005, 02:14 PM | #10 | |
36
Rep 515
2012 328i White Luxury/ Saddle Brown
12-13-2005, 02:15 PM | #11 | |
36
Rep 515
None shall pass
12-13-2005, 02:42 PM | #12 | |
there is no spoon
243
Rep 867
[SIGPIC][/SIGPIC]
12-13-2005, 02:43 PM | #13 |
16
Rep 274
HERES THE REAL LINK.this was meant to be a feel good thread! so feel good about our e90's or take it as you wish |
12-13-2005, 02:49 PM | #14 | |
16
Rep 274
"yes, unknow what Dallas was , Plano well over 100+ , even colder tonite but thankgoodness no precip..." so i guess your 12 years old too...do not be so quick to judge me when your spelling is just as bad when typing on the forums |
12-13-2005, 05:09 PM | #16 |
3566
Rep 9,788
this really intrigues me...someone on the other forum makes a very good point: 0-60 is one thing and how it accelerates after 60mph is another. Fact is that they test drove a Corvette and a 911 and they both have the same 1/4 mile time. The Corvette has a V8, 400hp, and 400lbs of torque compared to 911's 355hp and 295 lb torque. something is fishy...
12-13-2005, 05:40 PM | #17 |
there is no spoon
243
Rep 867
Well it's no secret that some cars performs better during a certain power band then the other. A car might be faster than the other during 0-60 acceleration and be slower from 60-100... etc. This is very common. Usually some car performs better at higher speed while the other at lower speed.
What's odd about the event in question is that, the BMW jumps out to a lead, and the IS catches up, THEN the 3 series pulls away again. This sounds more like driver error, but since he stated that they swapped drivers several times to eliminate the possibility of driver error, this can be counted out. The other possibility might be that the IS is simply more difficult to drive fast. An automatic with paddle shifter might not be the easiest car to drive fast. It might take more practice to cope out the full 300hp. The initial jump made by the 3 series is pretty predictable. DTC turned off with a stick should have no problem taking a good lead from a stand still. If I remember correctly, you can't turn off the traction control on the IS (unless you got the cheap code?) The IS starts to catch up after a little, then perhaps these guys don't know where is the optimal shift point for the automatic, so they're dropping out of their powerband and thus allowing the 330 to pull away once more. 2 cars with such a large power difference should not yield the result they got. I bet if the IS just stick to automatic and floor it and never take their feet off the gas, the result will be different. I do believe our 330i is dramatically under-rated, but unless Lexus are pumping out production cars that's less potent then what the magazines have been testing, the Lexus should have straight line without trouble.
[SIGPIC][/SIGPIC]
12-14-2005, 12:08 AM | #20 |
Powered By 36DD
337
Rep 7,369
hahaha......it's nice to dream sometimes!
2006 E90 330i Jet Black | 20" WORK VS-XX | FK452 | H&R Sport on Koni Yellow | REMUS QUAD
12-14-2005, 12:57 AM | #21 |
235
Rep 6,874
Drives: 330i E90 C55 AMG
Garage List 2006 BMW 330i E90 [0.00]
2006 BMW 330i E90 [0.00] 2005 Mercedes Benz ... [0.00] 2002 Z3 2.2 USA Spo ... [0.00] 2002 Toyota MR-S Co ... [0.00] |
Can you find out the differences of the tires. 300+ hp cars could do bad launch easily if there ain't enough rear traction to take that up that accelerating power.
BMW 2006 330i E90 Jet Black/Black Leathers/Aluminium, Steptronic Active Steering; MTech Aero Kit Carbon Fibre Splitters/Diffuser. Bilstein PSS9 Coilover, Rays VOLK Racing RE30 Formula Limited Edition 18" Pirelli Rosso; Project Mu 355mm Forged 4pot Caliper. HID:Osram D1S 6000K, PIAA 6500K White Ring, Philips Diamond Vision HB4 5000K, PIAA H490/H491 Super Bright 6500K LED Interior Lights. Chrome S.Wheel Cover, Rear Windows Sunshades.
