Winter warm-up...
12-13-2005, 07:35 AM | #1 |
18
Rep 740
Drives: e90 325i
Winter warm-up...
I have heard about idle-ing the car to warm up is not necessary. I agree with that too.
However, how long should we warm up the car by driving softly before we can kick in some high rpms? I have been driving around yesterday night (-23C....) softly for 5 - 10 minutes. For some reason, mebbe just being my own worst enemy, I thought the engine does not sound the same when I rev from 3k all the way to 6k. There seems to be some resistance or not as smooth as usual. Mebbe it is just my worries of something broke down... *worried*
e90 325i Jet Black / Sports Pkg / Auto
12-13-2005, 07:52 AM | #2 |
418
Rep 12,276
One of the things I miss is an engine temperature guage. I have always waited until the needle begins to move (indicating that the thermostat is open and hot water is flowing) before turning on the heat. Now I just guess and turn it on after I've driven a couple miles.
Depending on how cold it is outside you should probably not rev the engine too high for several minutes or miles. Wish there was a damn guage!
I think it is bad luck to be superstitious |
12-13-2005, 08:14 AM | #3 | |
565
Rep 3,742
I miss the temp guage too, as I did the same thing in my E46. |
12-13-2005, 08:56 AM | #4 |
Rep 54
If you leave the heater in auto you will notice it only turns the fan on when the engine is warm. I always warm the car up a little because i don't want to sit in the cold car.
stack |
12-13-2005, 09:58 AM | #5 |
Absolute0
168
Rep 5,078
Just turn on the car for 30 seconds and go...the temp gauge on the E46 and any other cars are useless. It's the water temp, not the oil temp. The M3 has the oil temp and I think the new one will definitely get it too. Just drive under 3.5-4k rpm until you reach the first 10 miles of the trip.
To procede or not to procede......
12-13-2005, 10:26 AM | #6 | |
418
Rep 12,276
As the engine warms up, the water in the block heats. As the water heats to a pre-set temperature, the thermostatic valve opens to allow the water to flow through the radiator for cooling. The sensor in the water system passes the approximate temperature to a guage in the instrument cluster. The driver is hearby able to accertain that the engine has begun to reach, or has reached operating temperature. Before cars began using the hot side of the A/C compressor for heat, this hot water from the cooling system was the sole source of heat for the passenger cabin, and thus it was good to see the temperature guage before turning on the heat (unless you enjoy cold air blowing on you in the winter). I have always waited until the temp gauge began to move before turning on the heat. I hate using the A/C for heat if I can help it... unless I'm trying to defrost icy windows or something.
12-13-2005, 10:34 AM | #7 |
Bemuri
Rep 124
I fully agree with Coreslogic about the temp meter.In cold climate you need it.I have installed in my car a Defa heating system which uses 220volts and it then heats the engine and inside the car.It is a heating block installed under the engine to heat it with 220 V.Then there is an adaptor for connecting a heater inside the car to keep the windows clear.On front of our houses in the parking places we have a system where have a socket for 220 V.
Alpine Weiss 320i,(man)sport package,17"Breyton Inspiration wheels,through load system,proff radio,hifi speakers,bi-xenons,auto air-condition,alarm,light package,pdc,rainsensor,cruise control,cup holders,heated seats,headlamp washers,tinted windows rear,Ac-Schnitzer aluminium pedals.
12-13-2005, 11:19 AM | #8 | |
15
Rep 340
12-13-2005, 11:23 AM | #9 | |
82
Rep 5,732
12-13-2005, 03:29 PM | #10 | |
119
Rep 2,909
12-13-2005, 05:48 PM | #11 |
18
Rep 740
Drives: e90 325i
an update: today, i run around town for 20 minutes or so before I
go M mode, and do a 1st 7k -> 2nd 7k -> 3rd , not another unusual rpm noise again. (smile on my face afterwards of course) i guess for yesterday, either.... i didn't warm enough or it was just my imagination worries..
