E90 Pre-lci Headlight amber delete
12-02-2013, 06:34 PM | #1 |
King of the road
18
Rep 202
Hey guys,
I'm currently in the process of doing an amber delete on my e90 headlights thought i'd share with the community since there isn't much on this topic. To open them up I used a heatgun and pryed the lenses off. Still not 100% set on what i'm going to do to them, all i know is the ugly amber is going. I'll start taking some better photos to post and share as this progresses, hope this helps some people out and gives them a better idea of the job. Enjoy.
Jet Black / Pre lci E90 / 6mt / FBO /
12-02-2013, 07:18 PM | #2 |
110
Rep 441
Drives: 2008 335xi sedan
I have been thinking of doing this but Im just worried that I wont be able to seal it up 100% and it will get moisture in it
2008 335xi Sedan in Monaco Blue/Beige Dakota Leather/Cold Weather/Premium Package/ Navigation/ Logic7
Alpina B3 Flash, JB4 G5, BMS DCI, BMS OCC, VRSF DP, VRSF 7" FMIC, 30% tint, matte black kidney grills, paint matched e90 spoiler, paint matched front splitter, black finishing rods, BMW OEM Blacklines, Cyba air scoops, powder coated matte black wheels, Koni + Eibachs, more to come. |
12-02-2013, 07:29 PM | #3 |
King of the road
18
Rep 202
I was worried about this to at first .. Aslong as you take your time and triple check everything on reassembly i'm positive it shouldn't be a problem with proper sealant and lens alignment.
12-02-2013, 08:13 PM | #4 |
41
Rep 642
I did this for my other cars headlights. Problems I had before was bubbles because I didn't really have a good vacuum pump to degas everything fast. Now I do. Am considering doing a retrofit on my original OEM holagen headlights to have projectors, angel eyes and be badass. Or just buy Magnille headlights for $500ish a side and some very minor retrofit with those.
Not sure the clear reflectors on my Depos will transfer over or if I can find clear ones. If I have to, guess I will make a mould and cast some clear ones.....so long as all my stuff to do it is still good lol Basically, I made a box big enough to hold the reflector and mould. I press clay on the bottem of the box, put my reflector on top of the clay and seal around the reflector with the clay to form one side of the mould. I then pour the mix for the mould on top of the reflector. Let it completely set for a day or so....forget how long. Once set, I remove the clay from the other side and rebuild the box if needed. And then make a moulding of the other half of the reflector. Once both halves of the mould is done, I fill up a half of the mould with my clear cast mix and enclose it with the other half. Let it set and now I have clear reflectors. Last edited by Casca; 12-02-2013 at 08:26 PM.. |
12-02-2013, 09:27 PM | #6 |
King of the road
18
Rep 202
I'll post some better close up pics later, once you see them you'll get a better sense of what was done to get the lenses off. As for sealant I have a friend who owns a body shop who said he was going to give me suitable stuff to seal them up, when I pick it up either tomorrow or the next day i'll be sure to share.
12-02-2013, 09:31 PM | #7 | |
King of the road
18
Rep 202
12-02-2013, 10:54 PM | #9 |
BimmerPost Supporting Vendor
469
Rep 4,938
You cant really do clear reflectors because there is nothing behind there. You need to go with some sort of color or something solid.
I have a couple sets of Black CF reflector pieces already made up. You just need to glue them over the amber piece. 100% they fit correct and you cant even tell they are not OEM. I can post a pic if you want. Send me a PM. Also FYI - if you plan to keep the chrome inside DONT touch it. It comes off way too easily even if you tough it with a soft cloth.
12-02-2013, 11:31 PM | #10 |
King of the road
18
Rep 202
As mentioned earlier here are some pics of how the housing looks after disassembly, the technique is basically: heat up the upper plastic lip that sits over the headlight lens until it turns malleable, then gently lift it (I used a thin putty knife) to somewhat of a 90 degree angle which then exposes the entire headlight lens. Once you go around the entire headlight you can then gently slide a blade under the lens and the second lip under the lens cutting the remaining sealant holding it together. Don't be afraid of bending the upper lip, its plastic and you'll later reheat it and bend it back into original shape when its reassembly time. It took me roughly 2 hours each headlight just to open them up, patience is key with stuff like this.
12-02-2013, 11:51 PM | #11 | |
King of the road
18
Rep 202
12-03-2013, 07:35 AM | #12 | |
41
Rep 642
Also, with it being a reflector and all those odd surface details, not even sure a completely "clear" reflector will show through to what's behind it. This is a Depo headlight and the pic is Demented328's car Look at this pic Can you see the black behind it on the reflective area? I think with the e90 reflector, the outer parts with all the prisms(?) will mask what's behind it fine. Maybe even the inner area that is more smooth. If not, that area can easily be isolated and beadblasted. Like to start on it, but I gout a flywheel/clutch change + 3 stage intake manifold swap and then all control arms and bushing upgraded to M3 stuff as well as subframe bushings to do before I worry about headlights. |
12-03-2013, 11:13 AM | #14 |
469
Rep 4,938
http://www.e90post.com/forums/showthread.php?t=422068
That is a link to the headlights i have on my car now.
12-03-2013, 07:01 PM | #15 |
11
Rep 123
I've heard that when removing the lens the angel eye rings must be unclipped somewhere or they will break. Is this true? If so how do you go about doing this. Thanks.
12-03-2013, 08:15 PM | #16 |
469
Rep 4,938
100% true! you need to remove the angel eye bulb first, then remove the black plastic holder. After that you will be able to see the angel eyes fully. THere are 2 small tabs on the top of the angel eye tube that need to be lowered slightly. This will allow the tube to slide out when you open the headlight
12-03-2013, 08:20 PM | #17 | |
11
Rep 123
12-03-2013, 08:41 PM | #18 | |
379
Rep 2,365
Drives: 2007 E90 323i (Cdn)
I like it unique so not sure if depos or OEM LCI are for me. |
12-05-2013, 10:23 PM | #19 |
King of the road
18
Rep 202
Finally got some spare time on my hands to work a bit more on the headlights. The lenses got wet sanded and polished, they look brand new! Did some testing on the amber reflectors and I think I found the colour i'm going with... I also managed to grab a picture of the sealant my friend is hooking me up with, this stuff is amazing and looks exactly like the factory glue that the headlights were originally sealed with. I reassembled the headlight quickly to share with you guys. This is not the final product as I still have to re install the angel eyes in the housings and i'm still debating a few other things . Enjoy.
12-06-2013, 10:02 AM | #20 |
Rep 41
12-06-2013, 11:08 AM | #21 |
469
Rep 4,938
for sealing it up i might recommend permatex clear RTV silicone. I've had great luck with it.
12-09-2013, 07:19 PM | #22 |
King of the road
18
Rep 202
Finally finished the lights over the weekend and I tossed on an M3 rep front.
CornerGorillaPit238.50 |
