2Addicts
2Addicts
2Addicts | BMW 2-Series forum BMW 2 Series (F22) Forum BMW 2 Series Coupe and Cabriolet (F22/F23) General Forum BMW 2 Series M Performance Parts Revealed
      11-27-2013, 11:18 AM   #1
Jason
Administrator
Jason's Avatar
Drives: F80 M3
Exclamation BMW 2 Series M Performance Parts Revealed
BIMMERPOST NEWS
110
COMMENTS
First look at the BMW M Performance Parts for the 2 Series Coupe, covering performance, handling and styling.
Power
  • M Performance Power Kit available for the 220d coupe which increases power from 131 bhp to 200 bhp and torque from 380 Nm to 420 Nm.
  • M Performance exhaust system will be available for the M235i Coupe and M Performance exhaust pipes in carbon fiber or chrome with the M logo.
Handling
  • M Performance limited slip differential for M235i Coupe (and 4 Series Coupe)
  • M Performance sports suspension (lowers 20mm)
  • M Performance brake system with brake calipers painted in a choice of red, yellow or orange.
  • 19-inch forged BMW M Performance light alloy wheels are also available in two design versions.
Styling (exterior / interior)
  • M Performance aero kit (requires M Sport pack)
  • Black decorative grid for the BMW kidney grille,
  • Exterior mirror caps in carbon,
  • Side sill foils with M Performance inscription
  • BMW M Performance accent stripes in two color versions
  • M Performance sports steering wheel in Alcantara/carbon finish with red central marking and Race Display in 12-o’clock position
  • Gear lever and handbrake handle in carbon fiber
  • Alcantara gaiter.
  • Carbon fiber finish available for the gear selector switch of the automatic transmission.
  • Interior trim in Carbon fiber and Alcantara,
  • High-grade steel pedals and a driver footrest in corresponding design
Press Release
The market launch of the BMW 2 Series Coupé clinches pole position in the premium compact segment. The figure 2 in the model designation stands for supreme sporty flair while the letter M refers to the attractive features available for making a dynamic driving experience even more intensive. As in the case of the BMW M Performance automobile BMW M235i, BMW M Performance parts developed for all variants of the BMW 2 Series Coupé will be available as of the market launch in March 2014. The retrofit components designed in close collaboration with BMW M GmbH in the areas of drivetrain, suspension, aerodynamics and cockpit perceptibly boost driving dynamics as well as underscoring the athletic appearance and sporty interior ambience of the new 2-door model. The product selection forms part of the Original BMW Parts program and enables the driver of a BMW 2 Series Coupé to add a touch of individual style in a way that expresses motor racing enthusiasm.
The BMW M Performance Power Kit available for the BMW 220d Coupé creates perfect starting conditions, increasing the output of the 4-cylinder diesel engine by 12 kW/16 bhp to 147 kW/200 bhp and maximum torque by 40 Nm to 420 Nm. The increased sprint capacity achieved has no impact on fuel consumption and exhaust emission figures. A BMW M Performance silencer system is available for the BMW M235i Coupé which reduces exhaust gas pressure to produce a striking, sports-style sound. In addition BMW M Performance tailpipe trim elements are offered in chrome or carbon, bearing the M logo.
A highlight in the suspension area is the BMW M Performance limited-slip differential available for the BMW M235i Coupé. When the dynamic stability control function DSC is deactivated, the torque-sensitive mechanical limited-slip differential in the rear axle ensures traction-optimised distribution of drive torque between the rear wheels. It reduces the slip that occurs on the wheel with less grip by transferring more drive power to the other wheels using a blocking effect. This converts engine power into forward momentum as effectively as possible so as to be able to accelerate out of a bend even more dynamically, for instance.
Products available for all model variants include the BMW M Performance sports suspension including a lowering of 20 millimetres as compared to the standard version, as well as specific dampers and shortened coil springs finished in red, and the especially light and high-capacity BMW M Performance brake system with brake calipers painted in a choice of red, yellow or orange. 19-inch forged BMW M Performance light alloy wheels are also available in two design versions.
The exterior components created to optimise aerodynamic properties have been developed with characteristic M precision. As a supplement to the M sports package available ex works and in conjunction with the BMW M Performance rear spoiler in carbon there is a BMW M Performance Aerodynamic Kit available for the front apron which has been tailored specifically to this model. The combination of air ducting elements at front and rear guarantees an ideal aerodynamic balance and can be supplemented with a diffuser insert for the rear apron as well as attachments for the side sills. Other individual accents to the outer appearance of the BMW 2 Series Coupé can be added by means of a black decorative grid for the BMW kidney grille, exterior caps in carbon, side sill foils with M Performance inscription and BMW M Performance accent stripes in two colour versions.
An cockpit ambience inspired by motor racing is created by the BMW M Performance sports steering wheel in Alcantara/carbon finish with red central marking and Race Display in 12-o’clock position, a gear lever and handbrake handle in carbon and an Alcantara gaiter. A carbon finish is likewise available for the gear selector switch of the automatic transmission. Other features available for a highly sporty and individually designed interior include interior strips in carbon and Alcantara, high-grade steel pedals and a driver footrest in corresponding design.
      11-28-2013, 05:08 AM   #2
Aust350z
Aust350z's Avatar
Australia
243
Drives: F87 M2
Sign. Me. Up. For. This!!!!
      11-28-2013, 05:38 AM   #3
Zorro83
7
Drives: None...yet
That is just filthy...the wheels are the only thing that I could without. I prefer the reg. M235 or even the 228 m sport ones.
I hope they come out with some sort dual exhaust for the 228i if only for the looks
      11-28-2013, 05:39 AM   #4
leon1984
140
Drives: Old Mini! (M235i gone)
boot spoiler, side skirt decals, grills, gear shifter and peddle covers... lovely.
      11-28-2013, 07:14 AM   #5
M.barnes
41
Drives: 123d
spoiler is perfect!
love the flocked dash bits too, and of course that wheel.
      11-28-2013, 07:45 AM   #6
arthurtwp
arthurtwp's Avatar
Australia
36
Drives: '12 1 Series M '17 M3 Comp DCT
wonder how much that will all cost. for my e87 cf interior 1.5k cf exterior mirrors 1k cf diffuser 1.2k and the list goes on. you could buy a new car if you optioned everything.
agree standard rims are nicer. and way easier to keep. probs get csl reps though in black?
must say the front bumper panel I was sexy
      11-28-2013, 07:56 AM   #7
M.barnes
41
Drives: 123d
yeah £436 GBP for the CF mirror caps on the e87. Dread to think on the M235i how much some of the bits will be but definately want the spoiler.
E82 one is £362 GBP so fingers crossed the M235i one will be similar
      11-28-2013, 09:34 AM   #8
Maus
Message Board Crawler
Netherlands
Drives: Sofia
The rear bumper looks so much better than stock, is that available separately or do you have to take the entire aero kit to get it? And what is the other "design version" of the wheels, is that all-black?
This looks just a bit too ricey for my taste, but I think it would still look amazing with just the aero kit and the wheels in EBII.
      11-28-2013, 09:39 AM   #9
vinny84
vinny84's Avatar
Drives: 2005 BMW X5
Wow. Looks like the M235i with all these M Performance parts is going to cost me some cash
Totally worth it
      11-28-2013, 09:49 AM   #10
jrstech
jrstech's Avatar
78
Drives: '21 M550
Rear diffuser will be a hit and it looks like it can be purchased separately. This really should have been a stock M235 item.
'17 F80 (RET)
'14 F22 M235i (RET)
'11 E90 335i (RET)
'07 E92 335i (RET)
'89 E30 M3 (RET)
      11-28-2013, 10:02 AM   #11
number1draftpick
14
Drives: 328i
This completes it perfectly. Anyone wanna photoshop in black sapphire metallic and Estoril Blue ?
Those are the colors I'm considering in addition to white.
Thanks for the Thanksgiving treat, Jason!
      11-28-2013, 10:08 AM   #12
ska///235i
***** noob
ska///235i's Avatar
Drives: 325xi>M235i>428GCx Mspor
2006 325xi  [0.00]
OMFG
2006 325xi (Sold)
2014 M235I (Current)
2015 428xi Gran Coupe (STB)
      11-28-2013, 10:13 AM   #13
M.barnes
41
Drives: 123d
imagine how good that carbon and alcantara would look with BMW Performance seats!
      11-28-2013, 10:16 AM   #14
number1draftpick
14
Drives: 328i
Everything looks wow from every angle now.
      11-28-2013, 10:26 AM   #15
Husker
Husker's Avatar
Drives: Junk
Well, now I'm back to even on the fence.
      11-28-2013, 10:35 AM   #16
Husker
Husker's Avatar
Drives: Junk
Does this mean it tones down the sound?
If so, why would anyone want that, please explain the How & Why?
      11-28-2013, 11:09 AM   #17
bimmerfile
bimmerfile's Avatar
621
Drives: 2019 BMW X2 F39
+1
I think they made the stock //M235i diffuser look crappy just so they could upsell a shitload of M Performance diffusers.
Good job BMW Marketing.
2019 X2
      11-28-2013, 11:16 AM   #18
e92ben
e92ben's Avatar
1053
Drives: BMW M3 BMW 635csi
Originally Posted by Husker
A BMW M Performance silencer system is available for the BMW M235i Coup which reduces exhaust gas pressure to produce a striking, sports-style sound.
In some parts of Europe they call an exhaust a silencer. Also by saying reducing gas pressure they mean freer flowing lol. Fancy words man that's all
e92 ///M3
      11-28-2013, 11:20 AM   #19
Neph
Drives: 2010 328i E92, Sport, 6MT
Stunning combos to be had!
      11-28-2013, 11:23 AM   #20
lasovan
14
Drives: bmw 320
Nice. Btw, the 220d has 184hp and not 131bhp
Max. output in kW (hp) at 1/min 135 (184)/4,000
      11-28-2013, 11:30 AM   #21
Powaup
Powaup's Avatar
Drives: 2021 Supra 3.0 (Past: 2015 M23
2015 BMW M4  [10.00]
Wow I love every single piece except for the side stripe maybe. However if I were to do ED I would not have these items on my vehicle at the time since they are port install correct?
Happy thanksgiving
Check out my YouTube Channel Powaup
Instagram: @ Powaup
      11-28-2013, 11:36 AM   #22
swagon
swagon's Avatar
13521
Drives: F80 6MT
Love everything! Rear diffuser and carbon trunk spoiler are going to be very popular I predict, just like it is with the outgoing E82. I now regret putting down a deposit on an E82 this week haha.
P.S.: Still needs a drop.
2addicts
