Headlight help
11-25-2013, 12:53 PM | #1 |
10
Rep 154
Headlight help
Hello i have a 08 white 4door 328xi and i got a turnsignal malfuncton so i jsut bought these http://www.carid.com/2008-bmw-3-seri...ts-263923.html i put hids in them and they suck the rings are so dim and the driving visibility at night sucks i have the oem headligths the car came with but the right turnsignal is malfunctioning so any suggestions would help please
11-25-2013, 01:08 PM | #2 | |
Brotographer
88
Rep 1,741
Assuming there is no physical damage to the headlights, you could just replace the turn signals! Honestly, those aftermarket housings (mostly the projectors) suck a lot. They're cheap, not built for width, and not designed for HID bulbs. The result? Too much foreground light (reduces your long-distance vision b/c your eyes adjust to the brightness right in front of you), a poor cutoff, and a narrow beam pattern. AKA nothing you want on a vehicle. You can upgrade the projectors to nicer ones yourself, or you can pay someone to do it. If this is something you're interested in, I will provide more information in another post. |
11-25-2013, 08:48 PM | #3 | |
10
Rep 154
How would I fix my turnsignals and how would I upgrade the rings |
11-25-2013, 08:48 PM | #4 | |
10
Rep 154
https://www.dropbox.com/sc/irb3wsvsv7arzft/ur_c5AVN8N |
11-25-2013, 09:23 PM | #5 | |
Quiet till poked
99
Rep 1,176
As for rings, your best bet is to get a OEM set of xenons or LCI halogens. After that you can swap the AE bulbs for led bulbs like LUX or you can swap the AEs themselves for umnitzas. However, since you bought those knockoffs, you can still put them to use, if you so choose and upgrade them. Again like rollinstone157 mentioned. If you decide to replace the AEs, I recommend getting them done at Lightwerkz in Oakland, NJ. While there, you can choose to do a custom paint scheme, swap in clear lens and CBI bulbs (if you bought the xenons), or retrofit projectors (if you bought the LCI halogens). Here's how mine came out link Last edited by kisho; 11-25-2013 at 09:31 PM.. |
11-26-2013, 08:06 AM | #6 | |
10
Rep 154
11-26-2013, 09:30 AM | #7 | |
Quiet till poked
99
Rep 1,176
LUX are just led bulbs that you swap the AE bulbs with. This will be really easy, since the lights aren't even in your car. BTW, your old lights DO NOT HAVE AEs. Halogen pre-lci models, 06-08, do not come with AEs. Only Xenons and LCI halogens have AEs. |
11-26-2013, 12:06 PM | #9 | |
10
Rep 154
11-26-2013, 09:46 PM | #12 |
10
Rep 154
