Suspension Noise
10-24-2007, 09:53 PM | #1 |
193
Rep 3,469
Suspension Noise
PSS9s
I have a bunch of creaking in the front when Im turning into a parking space or turning into a drive way from the front suspension. Kinda sucks. Also, at times as Im driving, sharp (but not all that sharp) impacts cause a clucking sound in the rear suspension. It makes things sound kinda cheap, you know? I read this thread http://www.e90post.com/forums/showth...coilover+noise but its hard to know which part of it applies to my problem if any.
2016 Alpine White M3 (gone)
2019 Alfa Romeo Guilia (Totaled) 2020 Car-less 😁 (no more) 2020 M340 |
10-25-2007, 01:19 AM | #2 |
Member
306
Rep 22,825
How low is your car?
Front Creak: Sounds like the springs are shifting/turning on the spring pirtch. Rear Clunk: Make sure everything is tightened. If this continues, try either raising the height or stiffening the shocks. |
10-25-2007, 01:33 AM | #3 | |
112
Rep 2,433
10-25-2007, 09:52 AM | #5 | |
193
Rep 3,469
About the spring pirch, why are the springs turning, is that normal? I will call my installer today and ask if my kit came with the bearing washer that was mentioned in the thread I quoted.
10-25-2007, 02:07 PM | #6 | |
Member
306
Rep 22,825
The E90 uses a MacPherson type strut in front and the springs will naturally bind (turn). Therefore, the sound is not abnormal. Depending on whether the sound derrives from the bottom or top of the springs, a washer, which will allow a smooth turn, can resolve the noise. Last edited by Ray; 10-25-2007 at 05:20 PM.. |
10-25-2007, 05:30 PM | #8 |
434
Rep 4,380
Drives: 2014 Audi A4 / 91 Track Miata
Mine originally did that...doesnt do it anymore...I did change to lighter wheels/tires.
Car is now gone .... :-( |
10-25-2007, 08:25 PM | #9 |
193
Rep 3,469
I wont be changing wheels anytime soon, so I have to find another solution. I softened up the suspension a bit and that seems to have helped the clunk in the rear.
Its the fronts and those rotating springs it seems. Why do they rotate? And did my Eibachs and H&Rs on my last car rotate as well?
10-26-2007, 06:47 PM | #11 |
193
Rep 3,469
Thanks Don, Im taking it to my guy on Monday, I will suggest your idea to him.
10-28-2007, 09:45 PM | #12 | |
111
Rep 1,764
Orb |
10-28-2007, 10:15 PM | #13 |
193
Rep 3,469
Oh thanks Orb, Im taking it in tomorrow to have it looked at. Its driving me crazy!!! I hope its a simple fix like that cause Im about ready to have this stuff removed and go back to stock!
10-29-2007, 04:16 PM | #14 |
193
Rep 3,469
UPDATE:
The installer could find nothing wrong. All washers were in their place as they should be. So we went for a ride for him to hear the noises, and he was a bit perplexed. He then decided to tighten up all the bolts at each connection. So he diligently worked on each bolt. After he was done, we took another ride, and to my surprise, all creaks, noises, etc disappeared. Its quiet as can be now. So, check your bolts guys, I guess they need to be super tight. He also mentioned to make sure that the height adjustment rings are super tight as well, if not he said they can flex and make creaking noises off of each other too. So Im much happier now to say the least. The car even seems to ride smoother, but Im sure thats in my head
10-29-2007, 10:22 PM | #16 |
193
Rep 3,469
Yea, me too, I was really really disappointed in them this past weekend. I didnt even wanna drive me car
Its its great now
