TPMS Question
11-19-2013, 07:00 AM | #1 |
34
Rep 295
TPMS Question
Do LCI E90s have TPMS on them? My low tire pressure light just went on 1 week after I put my snows/rims on. Tire pressure is fine...
I also tried to reset the light in the cluster and cannot... Cheers...
E46 330i (Sold)
E90 328i (Sold) E90 325i (Sold) E90 328i xDrive |
11-19-2013, 07:20 AM | #4 |
34
Rep 295
I have a 328 xdrive...what do you mean screen on the dash? Ie. Idrive?
E46 330i (Sold)
11-19-2013, 07:57 AM | #6 | |
681
Rep 3,696
2) use BC Stalk to toggle to tire symbol 3) press and hold bc stalk button to initiate reset (5-10 secs) 4) once u see the word "resetting"... Then go ahead and start driving your car. 5) get up to freeway speeds and the tpms light should go out. Are u sure u are not using pre-lci tpms's in those tires/wheels with your LCI car? Because they will never work since they use different frequencies. I tend to add 3-4psi above what is listed in the door jam for my go flat tires. |
11-19-2013, 08:02 AM | #7 |
34
Rep 295
I just reset the light in the parking lot at work, but did not have a chance to drive it yet. However, I thought that 335s only came with TPMS...
Thanks Fazman
E46 330i (Sold)
11-19-2013, 08:20 AM | #8 |
packet jockey
16
Rep 299
I'm pretty sure USDOT requires that all MY2007+ vehicles purchased in the US require TPMS.
(pardon the alphabet soup)
2011 335d
With great torque comes great responsibility |
11-19-2013, 10:22 AM | #9 |
Rep 63
USDOT requires some sort of TPMS, but there are 2 different types...direct and indirect. Direct measures the actual air pressure thru a sensor that transmits some sort of radio signal from inside the wheel. And indirect will calculate that the pressure is incorrect, usually by using wheel speed sensors...when pressure is low, the overall diameter of the wheel changes, which changes the rotational speed of the wheel in comparison to the other wheels.
Just call me Cliff Claven...I provide lots of information, but none of it really useful.
2011 BMW 335i xDrive Ruby Black Special Edition
BMW Perf Power Kit, BMW PE, KW V1, 18" style 189 |
11-19-2013, 10:24 AM | #10 | |
BimmerPost Supporting Vendor
15
Rep 678
Also, I assume your snow rims/tires have TPMS ? |
11-19-2013, 10:42 AM | #11 |
34
Rep 295
They are oem winter wheels, but don`t think that they do. The fault came up almost a week and a half after install. Coincidentally, I had a leak as well so I am not sure if it was the sensor or the actual fault...will drive around and let you guys know...
E46 330i (Sold)
11-19-2013, 01:23 PM | #12 | |
124
Rep 5,627
Tom |
11-19-2013, 04:02 PM | #13 |
Rep 150
I just have the flat tire monitor system in my 2007 328xi, and I have found it is very sensitive. If my PSI drops by more than 5PSI, it will say I have a flat tire.
The way to calibrate and reset it on iDrive cars is through the service menu. You fill the tires to correct PSI of your choice (I use 40PSI all around), then hit reset and it will store that value as the tires are all correct and full. DO NOT JUST RESET THIS WITHOUT PUTTING ALL TIRES TO THE CORRECT PSI!! |
11-19-2013, 04:07 PM | #14 |
15
Rep 678
yeah, if you don;t have them then you won't be able to reset and remove the warning.
11-19-2013, 04:08 PM | #15 |
I have to return some video tapes
362
Rep 4,712
dumbest thread i've seen in a while.
13 Carbon Black e70 X5M - 13 Black Sapphire e92 335i - 10 Le Mans Blue e92 335i - 09 Monaco Blue e92 328i xdrive - 07 Sparkling Graphite e92 328xi
11-20-2013, 07:47 AM | #16 |
34
Rep 295
If you don't like the thread then stay out of it...Keep your ignorant opinions to yourself...
E46 330i (Sold)
11-20-2013, 11:59 AM | #17 |
362
Rep 4,712
In what way was that ignorant?
11-20-2013, 12:08 PM | #18 |
I used to be conceited, now I'm perfect.
571
Rep 1,826
Drives: 2018 M3 CS
If your car is Canadian you don't have TPMS. You have a different system that uses the ABS. If you just reset it you should be fine. It's just sensing a difference in your wheel/tire diameter. I'm assuming you went down a size?
2018 M3 CS - Alpine White l l
"I used to be conceited. Now I'm perfect" |
11-20-2013, 12:53 PM | #19 |
34
Rep 295
Yes, you are correct, I went down 1 size...
E46 330i (Sold)
11-20-2013, 12:58 PM | #20 |
571
Rep 1,826
Drives: 2018 M3 CS
You should just be able to use stalk to reset it then.
11-20-2013, 01:01 PM | #22 |
571
Rep 1,826
Drives: 2018 M3 CS
