11-19-2013, 03:08 AM | #1 |
3531
Rep 11,292
Heated rear window and mirrors take a while to clear
I noticed today the heated rear window seemed to take a heck of a long time to clear this morning and a lot longer than my old E90. There was no ice on the window – just condensation. I also noticed that the mirrors take a while to clear, although I’m sure I’ve read this on another thread. Is this normal for an F30?
Conversely, the windscreen actually defrosts very well – with the windscreen blower on. Even with ice on it, it will defrost completely with a light frost in around 5 mins without the need to use a scraper or de-icer. First car I’ve had that does that (bar Ford’s quick clear windscreen). |
11-19-2013, 03:11 AM | #2 |
46
Rep 121
Spooky, I have just posted a post around teh same issues - though I believe that the windscreen on mine clears slowly when compared to my previous Insignia.
Deffo the rear window takes absolute ages, even more important on the saloon where we do not have a wipe to clear off the glass. Just out of interest, what blower settings are you using to clear the windscreen?
New Car - G20 320d Sport - Sunset Orange, Oyster leather interior
Previous New Car - X1 Sdrive M Sport - returned it - hated it Old Car - F30 320d ED in Mineral White |
11-19-2013, 03:20 AM | #3 |
3531
Rep 11,292
Hey Thompjas, yes seen your thread too!!
To defrost the windscreen I just press the windscreen button, on the far left and touch nothing else. I think the A/C is on, but not sure if that works below a certain temp anyway. It was -0.5 deg C this morning and it defrosted very well. It defrosted similar a couple of times last week too (I only had my car last Monday so still getting used to everything). |
11-19-2013, 03:20 AM | #4 |
1854
Rep 3,983
Does take a while. Tend to start car, set defrost & turn on heated seat and wheel, lock car, have cuppa and then get into clear heated car with hot seat and steering wheel. Know you're not allowed to do on road but nothing wrong with doing on private land.
San Marino Blue M3 Competition Package with Carbon tat, ACS RS suspension, uprated brakes, 'modded' exhaust and a weeny bit more power courtesy of JF Automotive; M235i Convertible with ACS Sports Suspension; Disco 5 HSE Lux
11-19-2013, 03:32 AM | #5 |
20
Rep 270
Drives: 335D Min Grey Beige Reg 3/2014
I have always put my car in garage so happens minimum no of times . Incidentally I have space only for BMW below 15ft 3ins - do hope when I get it measurements of length specified are right otherwise ".........boohoo".......
11-19-2013, 04:16 AM | #6 |
512
Rep 1,404
I noticed the rear window taking a while to defrost also, seems a bit longer than on the E92, didn't notice so much on the mirrors though, had a lot of steam rising of them, looked a bit odd from the outside! But rear window was definitely a while before I even started to see the elements appearing. I try not to use de-icer so I tend to start the car up 5 to 10 mins before I head off.
Current - F80 M3 CP SS/SO | M Performance Extras
Prev - F30 330D M Sport | White | M Performance Kit | Various Extras Prev - E92 330D M Sport | Black | Highline Older - E46 330i | Silver | AC Schnitzer, E36 328i Coupe | White |
11-19-2013, 04:19 AM | #7 |
6659
Rep 15,858
Speed of defrosting will depend to a great degree on consumer load from start up. Energy management will clock or limit the high energy users, if there is not the battery or alternator capacity to serve them all.
The demands can be massive if you have rear heated screen, mirrors, heated seats and the like all switched on together. There is also the electric PTC heater element in the HVAC unit, which gives the more instant front screen demisting. Even worse if the engine is on idle, as alternator is not at full capacity. BMW set a 'priority' list for consumers, so some functions get reduced output. Typically heated rear screen and mirrors are high up on that list for electrical load reduction. HighlandPete |
11-19-2013, 04:21 AM | #8 |
3531
Rep 11,292
Seems they are all the same then with regards the time it takes to clear the rear screen. One could assume it may be some “ECO” thing so that less energy is used to save fuel – probably.
11-19-2013, 04:23 AM | #9 | |
3531
Rep 11,292
11-19-2013, 04:29 AM | #10 |
46
Rep 121
I will switch off Eco Mode another time and see if 'comfort' assists more !!
11-19-2013, 04:36 AM | #11 |
3531
Rep 11,292
11-19-2013, 04:37 AM | #12 | |
512
Rep 1,404
I don't switch on any other heating elements first thing, I even turn the stereo off and make sure the car is in Comfort and mostly don't bother with the max windscreen blower, still seems to take longer for the rear window to heat up, not a big deal but I did notice it in this car compared to my last one
11-19-2013, 05:01 AM | #13 |
46
Rep 121
I do have a 320Ed, so it always starts in Eco Mode - I will have to read the manual to see if I can alter this for the winter months !
11-19-2013, 05:08 AM | #14 |
3531
Rep 11,292
11-19-2013, 05:21 AM | #15 | ||
6659
Rep 15,858
Putting the electrical loads in perspective, even if we switch off some of the smaller consumers, we still run the heavy demand items like the HVAC heating element and rear screen. I haven't the data for the F30 but in the E9* diesel models the PTC auxiliary electric heater is 1250 watts. Even that is limited in current draw. Quote:
If you are on the move, then the alternator will be generating more amperage, and we get faster demist response. HighlandPete |
11-19-2013, 05:42 AM | #16 | |
84
Rep 729
Is this HVAC heater standard on all F30s, or only fitted on diesels as they heat up slower? I wasn't even aware that it existed before now. |
11-19-2013, 08:05 AM | #17 | ||
6659
Rep 15,858
Miss it in my petrol 535i, it is the only negative about the car. Miss the fact the 330d diesel, would start giving cabin heat almost immediately. When I get to the next village (3-miles) ECT is about 53 - 55C (similar to the diesel at around freezing temperatures) I'm no where near at the same cabin heating. It is just warm, where the 330d would be pumping out loads of heat. It takes a lot of energy to get a warm cabin a freezing temperatures. Posted this comment in another topic last winter. Quote:
I remember the days of living with the 15 amp dynamo, how we have moved on. HighlandPete |
11-19-2013, 11:44 AM | #18 | |
84
Rep 729
Yes, the electrical power that's required by modern cars is quite amazing. I too was thinking about the old days of dynamos earlier on when I read your previous post |
11-19-2013, 01:52 PM | #19 |
Newbie!
Rep 39
I wondered if starting the remote auxillary ventilation would help defrost in the morning. So I am sitting in my car (waiting for my daughter to finish gym) with car off and locked and have started the aux ventilation via my IPhone. Interestingly the start/stop button lit up and a slight whiring sound from the dash and I can just (and I mean just) feel a slight breeze if I put my lips to the vent (got a few strange looks doing that one!!!). So don't think that helps or in fact think it does much at all - unless I did something wrong!
I know some people start their cars and then leave it defrosting but how do you lock your car as I thought the keys needed to be in ther car for it run? Also I was told it not a good idea to leave a cold car idling - although it was my Grandads advice 22 years ago when I had my first car a 1.0 Metro City X so maybe technology has moved on a bit (that car even had a choke!) |
11-19-2013, 02:08 PM | #20 | |
6659
Rep 15,858
We had to do our own energy management in those days, or you'd soon get a flat battery. HighlandPete |
11-19-2013, 02:12 PM | #21 | |
6659
Rep 15,858
An idling cold engine is not a good idea, never has been. Diesels take ages to warm at idle. Users are doing it for the electrical functions to heat, not really the engine. Best to drive off after a few seconds for fastest engine warm up. HighlandPete |
11-19-2013, 02:52 PM | #22 | |
7
Rep 142
