11-16-2013, 06:25 AM | #1 |
52
Rep 367
Removing wheel nuts
Please can someone recommend a suitable tool for removing wheel nuts? The cheap wrench I have just isn't working on my wheel nuts. Does it need to be a torque wrench? If yes is there any particular one I need? Thanks
11-16-2013, 06:36 AM | #2 |
297
Rep 701
It doesn't have to be a torque wrench, but if would strongly suggest you use one. They're not that expensive and you'd get one from ya local Halfords, just check the settings before tightening.
11-16-2013, 07:02 AM | #3 |
297
Rep 701
11-16-2013, 08:04 AM | #4 |
50
Rep 542
For undoing the wheel bolts what you need is 17mm socket with a long bar attached to it. This gives you the leverage to loosen the bolts. You only need torque wrench when finally tightening them. You do them up to say 3/4 of the final figure and then pinch them up the final 1/4. I was told the the torque figure was 120Nm.
11-16-2013, 08:57 AM | #5 |
25
Rep 597
It's 140NM for most new BMWs now as they use a M14 lug nut (was M12 in previous models). A lot of dealers still get this wrong, but it is in their TIS.
11-16-2013, 10:19 AM | #7 | |
6659
Rep 15,858
As has been suggested, best use a simple breaker bar on the 17mm socket to undo the wheel bolts. Again us the crisscross method to undo the bolts, to prevent any wheel/hub distortion. HighlandPete |
11-18-2013, 01:57 PM | #8 | |
67
Rep 650
SX03017 Alloy Wheel Impact Socket 17mm 1/2"Sq Drive via Amazon. |
11-18-2013, 02:37 PM | #9 | |
6659
Rep 15,858
In fact used it today, fitting my winter wheel set. HighlandPete |
11-18-2013, 02:43 PM | #10 |
498
Rep 1,502
Drives: M4 CP SSII/SS
Ooh very posh. I just use insulation tape wrapped around.
Current: F82 CP SS/SS
11-18-2013, 02:59 PM | #11 |
6659
Rep 15,858
The benefit of an protective/insulated and extended socket, does everything properly, IMO. Protects the wheel and can be used with a breaker bar and torque wrench without an extension, so a safer tool. Plus you can 'hand wind' the wheel studs with the same socket. Simplifies the whole wheel change.
HighlandPete |
11-18-2013, 03:00 PM | #12 |
1042
Rep 6,946
Good quality socket, insulating tape round it and a good quality breaker bar. Search Ebay for the bar, I bought a Sealey one and its great quality and very strong.
