Heat became cold
11-13-2013, 09:24 AM | #1 |
Captain Dutch Rudder
204
Rep 2,258
Heat became cold
Hi guys, so this morning I actually used the heat. Worked great.
As I'm driving to work, I noticed I was getting cold... Checked the vent and cool air was coming out but it was 73 degrees, and not on AUTO setting. Didn't really mess with it, cause by that time I was at work. Can anyone weigh in on this? It kinda has been bothering me as I'm sitting at my desk. Thanks OH, and yes the little dial was set to RED, so I am not an idiot lol.
No more E92 or E82
11-13-2013, 11:52 AM | #2 |
84
Rep 1,099
u had it set to 73 degrees and cool air was coming out? that sounds normal to me. If i want the heater i go to 80 degrees. 73 is what i use in the sping/fall and sometimes summer. idk maybe i'm spoiled with cali weather. or maybe the air comes out cool or hot depending on the temperature outside and what you want inside
11-13-2013, 05:54 PM | #3 |
124
Rep 5,627
As E92-bmw posted, one of the odd things about the BMW CC system is that the temp must be set very high (to maximum in my 128i) in order to get heat from the dash vents when NOT on AUTO. Apparently the reasoning is that most drivers prefer cooler air from the dash vents and warmer air from the foot well vents.
So if you simply want to heat your car, use the AUTO setting (70o works fine for me) and there should be no air from the dash vents - unless you set the vent dial to blue. Tom |
11-13-2013, 06:33 PM | #4 |
977
Rep 3,875
Drives: 330i, 135i
Yeah move it to 80+ degrees in order to get heat but if this does not work your water pump is starting to fail my friend... sorry. Lets hope not!
11-14-2013, 07:59 AM | #7 |
204
Rep 2,258
Read the last line of my post... lol
No more E92 or E82
11-15-2013, 10:49 AM | #8 |
Rep 32
Just wondering if you were able to find out what the cause of this is - I am having a similar problem (and strangely enough, I also live in Charlotte!).
Similar steps as the OP - dial turned all the way to the red, heat on full blast at 84 degrees, and it's just warm, not as hot as it used to be. I have a 2009 328i. Want to get this fixed before it gets too cold and I need my heat every day, but I don't want to try 3-4 different fixes, spending loads of money, without actually solving the problem. Any help is most appreciated! |
11-17-2013, 04:19 AM | #9 | |
Titanium silver + Sport + Premium
32
Rep 662
11-17-2013, 11:20 AM | #11 |
33
Rep 655
I dont get it. Whats the point of the blue/red button below dtc ? When i bough the e92 i have been looking why i was getting cold air for weeks. The temp should be enough for car to find out if i want hot air. Not even mentionning the rear vents were also at blue ...
11-17-2013, 11:32 AM | #12 |
Awesome
9
Rep 64
Check the coolant level, If its too low that may be why.. I've had the same problem where your driving and it gets hot then you get to a light and it starts blowing cold air
11-17-2013, 11:41 AM | #13 |
BMW Addict
11
Rep 424
They won't blow full hot from the middle vents anyway, only from defrost and floor vents. Something about ze engineerz knowing that hot air in the face causes people to fall asleep.
'07 Z4 3.0iS White/Saddle - Sold | '05 330 ZHP Silver/Grey - Sold | '06 330i SGM/Black - Sold | '07 335i Jet Black/Saddle - Sold
Volks are SOLD | '03 330i ZHP Silver/Grey - Sold | '11 X5 35i Sparkling Bronze - Sold |
11-17-2013, 12:20 PM | #14 | |
Rep 32
I would think there ought to be a way to look at it, which would obviously provide a pretty good indicator of whether or not it's the thermostat issue. |
11-17-2013, 12:20 PM | #15 |
Rep 32
Thanks - this is interesting. Is this easy enough to DIY? I'm not particularly handy, so please keep that in mind when determining if this is easy enough, haha.
11-17-2013, 12:22 PM | #16 | |
Rep 32
Hopefully this can be something that's relatively easy/inexpensive to fix - I'm just concerned about taking it to the shop and spending loads to diagnose/fix, and not have it actually fix my problem. |
11-17-2013, 02:06 PM | #17 |
204
Rep 2,258
Interesting... Some one else said something like this. How do you know?
No more E92 or E82
11-17-2013, 02:53 PM | #18 | |
BMW Addict
11
Rep 424
In my previous career I worked in the fixed ops side (i.e. non-sales) of the car business. I have consulted for the local dealer, been to the US e90 launch, have two buddies who are shop foremen at large shops, and numerous friends that are BMW master techs and have met the regional FE numerous times in person. It could have changed in this generation, but both my E90s do this so I suspect BMW is still going with that philosophy.
11-17-2013, 04:17 PM | #19 | |
Rep 68
11-17-2013, 07:42 PM | #21 | |
Rep 32
Thanks - I don't have iDrive though, so that's not going to work for me. Did see a manual for how to access the hidden menu on my version, but I'm not sure how helpful it will be. I understand you can't access it while the car is moving, and I would need to see the engine temp after it heats up, etc. Oh well. |
11-17-2013, 09:10 PM | #22 |
Rep 32
Doing some research tonight, it sounds like a low level of coolant can cause the cabin heat to not work as well. So took the coolant cap off to have a look in the tank - there is nothing in there. Literally, no liquid, and the little stick isn't floating or anything.
Can anyone shed some light as to whether or not I should see anything in the coolant tank? I am NOT getting a coolant warning light or anything, so I'm quite confused. Thanks for any help. |
