11-10-2013, 05:29 AM | #1 |
50
Rep 542
Urgent Help Needed
Hi, I'm half way through changing over to winter wheels/tyres and I now find I have a problem. Lifting the back of the car was easy, put the jack under the diff. But where the hell do I put the jack to lift the front? As I don't fancy punching a hole through the floorpan instead of lifting the car! All of the front suspension points seem too far away from the edge of the car. There is not much clearance under the car.
11-10-2013, 05:41 AM | #2 |
25
Rep 597
11-10-2013, 05:59 AM | #3 |
36
Rep 398
just done mine too,there is lifting blocks built into the sills just at the bottom of the side skirt
f31 330d mineral grey/black interior with extra stuff fitted
11-10-2013, 06:29 AM | #4 | |
77
Rep 182
You also need to remember to chock the front wheels when doing the rears if you don't have x-drive! |
11-10-2013, 07:23 AM | #5 |
50
Rep 542
Problem solved, thank you. summers having been thoroughly cleaned are now in my garage. Arch gaps look big as the cars just been lowered back to the ground and not been driven anywhere.
11-10-2013, 09:10 AM | #6 |
20
Rep 63
What size and design wheels/tyres are those Captain? Am looking to get a winter set for my 330d x-drive but was worried 17" would look ridiculously small on the car compared to my summer 19"s and there is quite a price difference between a set of 17s and 18s.
11-10-2013, 10:27 AM | #7 |
163
Rep 641
The 5 spoke M sport 18s that I have just fitted with the winters to replace M sport 19s certainly show off the blue brake caliper covers rather well (having cleaned them while the wheels were off). Dont know if it is the 18s or the non runflay pilot alpine but the ride is smoother, though I am not unhappy with the 19 & runflat setup for Summer (but my other drive is a Z4MC on 19" CSLs with pilot supersports which can loosen teeth on the wrong roads)
11-10-2013, 01:26 PM | #8 |
50
Rep 542
These are design: V-spoke 413 with 225/50R17 I paid £1572 instead of £1700
11-10-2013, 02:11 PM | #9 |
133
Rep 2,046
I bought a jack adapter off ebay too, so I can use my trolly jack to lift the car otherwise it will ruin the jack points. I just lifted the car from the front jack point and was able to change front and rear at the same time.
11-11-2013, 03:35 AM | #10 |
50
Rep 542
I shall look into it.
11-11-2013, 03:39 AM | #11 |
Supreme Being
1804
Rep 5,425
I saw these adapters on eBay and hadn't considered they may be a mandatory item!
How else will I clean the back of my wheels etc... More money.
Current: F90 M5 Competition
Gone: F80 M3 Competition Pack / M135i / F15 X5 M50d / Saab 9-5 Aero HOT / F30 335d xDrive M Sport / E92 LCI 320d M Sport / E46 320d M Sport Touring / E46 318i Touring |
11-11-2013, 06:23 AM | #12 |
32
Rep 652
I have them for the new car i trashed the jacking points on the e91 basically just winging it, they are sacrificial and can be replace but i decided to pay the £10 quid for the adaptor. I have seen on some sites people also use a hockey puck if you have one lying around.
11-11-2013, 07:22 AM | #13 |
8
Rep 252
I have a pair of those for SWMBO's E46. I've trimmed them so they sit nicely in the top of my axle stands. Makes me feel a little more secure that nothing is going to move.
11-11-2013, 07:33 AM | #14 |
371
Rep 1,216
These trolley jack adaptor pads, do you mean these?
http://www.ebay.co.uk/itm/NEW-55mm-B...item258186c88b
M3 Azurite Black now instead of the 335d. Roughly the same really.
11-11-2013, 12:27 PM | #16 |
8
Rep 112
I made some out of a thick piece of ply (inch or so) I had. Just a rectangular block to fit inside the plastic liifting point and then lifted on a normal trolley jack!
11-11-2013, 02:04 PM | #17 |
133
Rep 2,046
One problem I have is what the car sits too low to get my trolley jack under the jack points. My solution is place a brick in front of one front wheel, drive up onto it, then I can jack the car up. I do the same after fitting the wheel, lowering it onto the brick, then roll off after.
I know some trolley jacks have a low lift point but mine doesn't! |
11-11-2013, 02:22 PM | #18 |
32
Rep 652
I like the concept but maybe a sandbag would be a better idea mate. I think the brick maight be awkward to get the car set right onto it. http://www.ebay.co.uk/itm/5-JUTE-HES...item27d4668338
I found some on ebay. Only cheap I think thes would be better just need a bag of sand from B and Q. |
11-11-2013, 02:23 PM | #19 | |
29
Rep 626
Clarke CTJ2000A 2 Tonne Aluminium Trolley Jack http://www.machinemart.co.uk/shop/pr...m-trolley-jack The main drawback for me is the cost, its cheaper to take the car to a garage. The jack pads are great and well worth getting as without them you risk damage to the jacking points. |
11-12-2013, 08:51 AM | #21 |
36
Rep 398
with one of these you dont need pads and it fits under easily
