100k service
11-07-2013, 08:49 AM | #1 |
13
Rep 188
100k service
Hey guys I'll be approaching 100k soon on my 08 328xi. Was wondering what kind of services or maintenance would be a good idea to get done. Thanks in advanced.
11-07-2013, 09:01 AM | #2 |
Rep 95
I picked up a 328XI 2008 at 73k from a friend. I have 75k on it now. So far I did front/rear diff, transfer case, trans pan drop with filter replacement. I have ignition coils on backorder (went with Bosch) and NGK plugs waiting for a tune up. When I do the plugs I'm going to do the belt and tensioner as well.
I'm draining/replacing the coolant hopefully next week and soon will drain/replace brake fluid and power steering fluid (filter as well). Once I have all this completed I should be about 80k. Will do front/rear diff and transfer case every 50k and trans filter/pan drop every year. Drain/repalce radiator coolant yearly (easy and not expensive) Belt around 150k and hope she makes it to 200+ with no issues. That is the plan anyway.... |
11-12-2013, 07:17 AM | #3 |
Rep 95
Drained the coolant and replaced with BMW coolant and distilled water. Once I realized there was no engine block drain it went quick. I was going to change the belt and tensioner but it looked brand new so I am going to leave it on for now.
