F30POST
F30POST
BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > 2012-2019 BMW 3 and 4-Series Forums > General F30 Sedan / F32 Coupe / F36 Gran Coupe Forum > Reduced Performance after Limp Mode
ARMA SPEED
      11-06-2013, 10:36 PM   #1
sinuspain
sinuspain's Avatar
Drives: 2013 F30 335i EBII
I don't know if I am being paranoid but ever since my car engaged in limp mode 2 days ago it seems that it is not driving as smoothly. Symptoms were there: radiator fan on max the whole trip, no revving past 3k rpm, and really low oil temp.
Maybe I am just nit picking since its basically a new car (got it with a few hundred over 5k miles now 6k miles), but it seems like its just not as powerful as it was days ago. In stop and go traffic and picking up speed something seems a little off. Don't know how to explain it.
I went to the dealer today and explained the situation to my SA and he basically said limp mode is usual with turbo cars and that I shouldn't worry about it if no CELs or lights showed up on the dash. He said its most likely fine and that I should bring it in if it shows up again.
      11-06-2013, 11:17 PM   #2
floydarogers
Curmudgeon and Pedant
floydarogers's Avatar
Drives: 2010 335d, 2014 328d
If it went into limp mode, there are almost certainly stored codes. The dealer would have had to charge you ($125-$150) to read them. Get them read for free by an auto-parts shop (Kelly's, Autozone, etc.), then ask here again.
      11-06-2013, 11:24 PM   #3
OC40
51
Drives: 335i MSport + MPS/MPPK
2013 MINI S  [0.00]
2013 BMW 335i  [0.00]
If your dealer is charging you to run codes, then you need a new dealer.
      11-06-2013, 11:24 PM   #4
OC40
51
2013 MINI S  [0.00]
Mine does as well. I believe a couple of other members mentioned this as well.
      11-07-2013, 09:29 AM   #5
RoundelM3
RoundelM3's Avatar
Drives: 15 F80 M3, 22 G01 X3 30i
2022 BMW X3  [9.83]
2015 BMW M3  [6.50]
Your SA is full of crap - limp mode is NOT "usual" with turbocharged engines - it only happens if something isn't working correctly. You may have a defective auxiliary cooling fan (located behind lower driver-side grille) like mine did - although mine never went into limp mode. In normal and even spirited driving, you should never go into limp mode unless something fails - generally, it's either the oil, engine coolant, or intake air temp going beyond safe levels. If you're running a "tune" other than the factory MPPK, its possible that it may be pushing the limits too far and causing the DME to protect the engine from potential damage.
Your car is under warranty, and bringing it in to check for codes should not cost you anything - if they claim it does, then speak to the service manager or the dealership manager and complain.
2015 F80 ///M3 Sedan 7DCT Tanzanite, 2022 X3 sDrive30i 8AT Brooklyn Grey
      11-07-2013, 09:31 AM   #6
shivaswrath
shivaswrath's Avatar
Drives: 2012 335i
you are in need of a new dealer...
CURRENT: 2017 RS3 (miss you guys)
SOLD: 2012 335i Mineral Gray
M Performance Exhaust/Brakes/Suspension/LSD|Bav Stage 1/AMP||ER CP/IC/DP/OC | Dinan CAI/N55 PWG BIG TURBO|BMWF30.com
      11-07-2013, 09:55 AM   #7
btbossman
Drives: 2013 335xi M sport--2014 M6
I think its just you being more careful...I have had limp mode 6 times...the last 2 times the car got all jerky on me as I was down gearing(basically drive my car in manual all the time) I do remember in the days after I was just being a little more careful. I was thinking last night, damn ive been dogging this car for the last few days, glad no limpies! If its gonna happen its gonna happen...ive had it anywhere from being stopped at a stop sign and starting to move, to cruising on the highway for hours...its a software error.
      11-07-2013, 11:24 AM   #8
snowghost
snowghost's Avatar
Drives: '13 335i M-Sport 6MT
+1
F30 Sapphire Black M-Sport 335i 6MT
      11-07-2013, 12:11 PM   #9
sinuspain
sinuspain's Avatar
Guys, my SA never said it costs money to check codes
I decided last night I'm going to take it in though because I don't think this should be happening...going to get that stupid auto start/stop feature disabled too
      11-07-2013, 03:13 PM   #10
KnoxDawg
KnoxDawg's Avatar
Drives: 2014 EBII 328i
Of COURSE it's not normal and shouldn't be happening. That is why everyone is saying you need a new dealer man....
2014 F30 M-Sport 328i, Estoril Blue, Sport Auto, Moonroof, Lighting Package, Navigation, Harman Kardon, Black Performance Grilles, Stainless Pedals.
      11-07-2013, 03:47 PM   #11
sinuspain
sinuspain's Avatar
Question is, go to another dealer (Long Beach or Nick Alexander) or take it up with the service manager?
      11-07-2013, 04:40 PM   #12
snowghost
snowghost's Avatar
At the end of the day the dealer is going to defer to the BMW area rep as to the remediation. So might as well pound on the most convenient location if you're otherwise happy.
      11-07-2013, 05:05 PM   #13
t335xi
7
Drives: 2013 335xi Sedan Sprt Line ppk
It could be any number of things .mine was a bad air mass sensor with no codes or lights showing but a noticeable lag in power. Find a new dealer and make them tear the drive train apart until they find it. If they can't fix it its a lemon.
      11-07-2013, 05:12 PM   #14
v1k1ng01
v1k1ng01's Avatar
Drives: 2013 335i M-sport
Your Stealer is BS'ing you. If your car went into limp mode codes will be stored in ECU. Talk to the service manager or find a new dealer.
      11-07-2013, 05:45 PM   #15
sinuspain
sinuspain's Avatar
I talked to the service manager at the dealer I've been frequenting (South Bay bmw) and she wants to set up a drive in with one of the service guys. She said the earliest is next Tuesday as they don't have any loaners.
I'm afraid they aren't going to find anything by just sitting in the car--is it time to just take it to another dealer?
      11-07-2013, 06:28 PM   #16
oonowindoo
244
Drives: 2021 M340i RWD
OP, sounds like you have not seen this thread.
http://www.f30post.com/forums/showthread.php?t=786475
But i know the feeling you are talking about after limp mode.
The car feels like the turbo stopped working when you drive it the next day.
Give it a few days, it will feel normal again.
      11-12-2013, 05:28 PM   #17
sinuspain
sinuspain's Avatar
So I was right...took it into the dealer yesterday and just like expected they found some fault codes associated with the auxiliary fan. They are contacting PUMA right now...
      11-12-2013, 06:52 PM   #18
Seagull
Seagull's Avatar
289
Drives: F87 M2, E84 X1
Have fun... I'm not
Current: F87 M2 MT MPE, E84 PP SP LP
Previous: F30 - 335i AT, E90 - 335xi MT, E90 - 330i MT, E46 - 330i MT
f30post
