FMIC Causes Increase in Engine Heat?
10-21-2007, 11:28 PM | #1 |
52
Rep 648
I have read through all the threads and post herein regarding FMIC's from the various vendors and there appears to be some debate as to their efficiency, design shape, placement, and more specifically whether or not they INCREASE heat within the engine, and therefore increase the temperature of the oil and coolant systems. These later two systems are important when tracking the car at a road course and have proven to be the reason why engine shut down, or limp home mode has been observed by some of us.
I have come to understand that IC's, especially aftermarket upgraded units, provide an increase in cooling capabilities in air intake temperatures thus resulting in a denser charge air charge within the combustion chambers of the engine. This cooler air will therefore allow the car to create more power, or power output closer to the designed maximum of the engine's capabilities in simple terms. What is in question here, and what should be a simple answer, is whether or not this more efficient combustion will cause the engine to run "hotter". So to restate the question: Will any of the FMIC's cause increased engine temps due to increased engine power efficiency, and if so, will they therefore cause increased oil and coolant temps? The question of design (height, shape, thickness, air flow) is secondary as they all will cool the intake air more than the stock unit. Your simple answers are appreciated. |
10-21-2007, 11:31 PM | #2 |
788
Rep 7,246
im sure ALL the vendors who know their stuff will chime in and answer this question soon enough, give it like 10-20 mins and your answers will start pouring in
LTMW Widebody+1M front bumper+Slek CF Lip|M3 Hood|StopTech BBK|M-Sport Rear Bumper+DD CF Diffuser|Custom Recaro Seats|KW V2|BavX LS3|M3 Side Skirts+Custom CF Lip|BBS CHR 19x10.5+BBS Lugs|LCI Taillights|RD Sport Anti-Sway Bars|GIAC S2|ER Intercooler+CF Shroud+Charge Pipe|Tial BOV|Injen Intake|MS downpipes|Custom Exhaust|BMS Oil Catch Can|M3 DCT wheel+TiD CF Paddles|BMW CF Trunk Spoiler|Aluminum Pedals |
10-22-2007, 12:47 AM | #3 | ||
1577
Rep 3,888
1) Not a single vendor has provided efficiency measurements as compared to stock on the track. Only dynos and pressure drop. 2) There is a question about the placement of at least one of these units possibly restricting air flow to the radiator. |
10-22-2007, 11:50 AM | #5 |
Perf BMW mag issue 147, 159
414
Rep 6,803
no. cooler air into the engine= better burn= less heat created= cooler temps all around.
'13 Estoril Blue 335i M-sport
*Don't PM me!* Message me here- http://www.facebook.com/ProjectEstoril |
10-22-2007, 12:52 PM | #6 | |
52
Rep 1,714
With just a more efficient IC, the engine gets cooler intake air and produces more power but the radiator and oil cooler don't get any additional cooling help. |
10-22-2007, 06:51 PM | #7 |
1577
Rep 3,888
10-22-2007, 06:55 PM | #8 |
128
Rep 2,298
Any intelligent fool can make things bigger, more complex, and more violent. It takes a touch of genius and a lot of courage to move in the opposite direction. - Albert Einstein
01 e46 m54 - Current : 14 f10 n26 - Boring & Gone : 15 f30 n26 - Current : 08 e92 n54 - Gone & Missed!!! |
10-22-2007, 07:09 PM | #9 |
Samtaro!
125
Rep 2,601
The mechanism for this is that cooler, denser air allows more oxygen to enter the engine, which results in more fuel being burned, which produce more power.
More fuel being burned and more power almost always means more heat being generated by the engine.
10-22-2007, 07:24 PM | #10 | |
Rep 19
Imagine yourself having more energy to pedal a bike. You take in the richer food, which invigorates you even more, and therefore you pedal faster, which of course, makes you sweat more. When the pistons accelerate faster because of more power, the oil has no choice but to heat up quicker, which makes the oil breakdown faster. But this is with any power application. There is no way around it if you want more power. -M
MR2 Turbo: bone stock! EVO VIII: 351awhp/354awtq on 91oct @ 25psi |
10-22-2007, 07:41 PM | #11 | |
1577
Rep 3,888
10-22-2007, 07:53 PM | #12 |
1577
Rep 3,888
Ok I have thought about this.
Say you are cruising at 90MPH with intake manifold temp at 100F @ 3000RPM, maybe at 250HP. I'm thinking that the same 90MPH with intake manifold temp at 140F would require like, say 3100RPM to make the same 250. That is because at 3000 RPM with 140F temps, you are making something like 240HP. I think the lower intake temp change gives you more power, at a lower RPM, for the same speed. This reduction in RPM reduces engine heat. (there is no "peddling faster") |
10-22-2007, 07:54 PM | #13 |
Rep 19
No, but the derivative of the rpms does change. Velocity doesn't change, but acceleration does. It's this acceleration that causes a more rapid change in temperature.
-M
10-22-2007, 07:55 PM | #14 | |
Rep 19
No.
10-22-2007, 08:12 PM | #17 | |
Rep 19
Reducing intake air temp increases the volumetric MASS of the air. You'll get more power period (not just at low rpms) since the motor will burn more fuel/air charge per compression stroke and the power stroke will be more explosive which will cause the piston to move downward faster than before (more torque=more horsepower). This will increase friction which of course, causes more internal heat on the oil that is supposed to reduce friction. I hope you are starting to understand now..if not, let me know. -M
10-22-2007, 08:15 PM | #18 |
grand poobah
254
Rep 2,253
In my experience larger/denser IC's increase coolant temps not so much by increasing HP but, by limiting airflow through the radiator and raising the temp of the air passing through the radiator. This is what I would be concerned about not, the extra 5 hp you might pick up.
10-22-2007, 08:20 PM | #20 | |
Rep 19
-M
10-22-2007, 08:25 PM | #21 |
grand poobah
254
Rep 2,253
Do you notice a difference in coolant temps (once up to operating temperature) from when it is 50 to when it is 65 degrees outside? Not really.
Now try putting some painter's tape or cardboard over the front of your grill... |
10-22-2007, 08:26 PM | #22 | ||
1577
Rep 3,888
