F30POST
F30POST
BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > Tracking / Racing / Autocrossing > 1/4 Time from Atco Raceway tonight
ARMA SPEED
      11-05-2013, 09:49 PM   #1
F30MSport
F30MSport's Avatar
Drives: 2016 Alpine White M3 6MT
Went to Atco tonight to run my car and was happy with the results! 2013 335i xdrive with MPPK 8AT 18" 400m w/ oem all season tires. Each run was in Sport + I also used the paddle shifters shifting at 6k rpms.
Best E/T: 12.965
Best MPH: 106.50
Best 60': 1.817
When Motor Trend came out with an article with the same set up they posted a 13.0 @ 105mph so I was hoping to at least match that time. I was skeptical that they may have pumped up the numbers. 12.9's not bad for a grocery getter
Alpine White '16 M3 6MT
      11-05-2013, 10:48 PM   #2
vip
vip's Avatar
Drives: 2001 Alpine White M5
nice times! did you have to do a burnout before the run? is that normally required? i would feel embarrassed if i had to do it and messed up and not put up smoke lol. did you hold the traction control for a few seconds on sport+ til you saw the dsc go off?
sent from bimmerpost Android app
      11-05-2013, 11:05 PM   #3
F30MSport
F30MSport's Avatar
Thanks! No need for a burnout since its an awd car and impossible. The point of a burnout is to heat up the tires for increased grip. Typically you'd want a drag radial similar compound tire and a rwd car. Not the end of the world if you messed up people do it all the time. I just pushed the button to sport then one more time for sport +
      11-05-2013, 11:30 PM   #4
F32
20
Drives: BMW
Nice. Very consistent.
      11-06-2013, 09:58 AM   #5
F30MSport
F30MSport's Avatar
The car was very consistent even with me paddle shifting which was perfect every run. The car was a little more in it for sure in its current state. Mods to come!
      11-06-2013, 07:47 PM   #6
Jamesons Viggen
Drives: '98 M Roadster stg 2+ S/C
1.8 60ft is what had you breaking into the 12s. Describe your launch technique(rpm).
'98 Dinan/RMS stage 2+(VAC cams, CES Cutring etc)
'15 Buick Regal "T"(wife)
'06 Saab 9-5 Combi 5mt (full suspension, LSD, clipped turbo etc)
      11-06-2013, 08:01 PM   #7
F30MSport
F30MSport's Avatar
No launch technique I've got the 8 speed automatic so easy as pushing the pedal to the floor. On two of my runs I mimicked launch control by holding the brake pedal down and holding the rpms around 2k but it still resulted in the same 60' and et
      11-10-2013, 11:52 AM   #8
olehead
131
Drives: 2018 M240I X drive
we just took my wife's stock right off the floor 2014 335 Gt to the track - cut a 13.45 with 104 and a curb weight of 4010 = expect to be in low 12 next spring with a couple of mods - pretty impressive for that car - I race a 13 mustang GT and am mid 12 with minor mods. That bmw could end being a bracket beater for sure - never live it down with wife may have to go Nitrious.
      11-10-2013, 12:04 PM   #9
nicknaz
nicknaz's Avatar
3187
Drives: C6Z
nice times OP. AWD+auto is pretty awesome for consistency
      11-10-2013, 04:34 PM   #10
F30MSport
F30MSport's Avatar
Doesn't appear to take a lot of mods nor money to get mid to low 12's. Good luck with your ride!
Thanks, the AWD is great just look at those 60' times, I had traction off and was told by some guys at the track I was still spinning off the line. Those oem runflats will be gone soon, will be interesting to see if I can improve with wider and sticky tires.
      11-12-2013, 02:23 PM   #11
ZheHbKa
ZheHbKa's Avatar
Drives: the Wind
2014 BMW 335 Xi  [10.00]
very nice, i wonder how it would compare to same car with 6 MT. and JB stage 1 (a bit higher power output then mppk)
2014 F30 335 X-Drive | 6-MT | Alpine White/Coral Red | ZMM ZDH ZDA |
f30post
