Paddle Shifter Quetion ?!
10-28-2013, 05:33 PM | #1 |
54
Rep 504
Hey Everyone
I recently bought a 2009 335i with 38,000 kms. It has CA package, exectuive package, but unno if it has sports package.. Anyways it came with the sport steering wheel without any paddle shifts... is their anyway I can install them? Thanks, Teddy |
10-28-2013, 05:45 PM | #2 |
12
Rep 136
10-29-2013, 12:25 AM | #5 |
69
Rep 1,766
You'll have to get a new steering wheel that's paddle shifter compatible. You can retrofit it from the forum's DIY guide if you choose to keep your current steering wheel but I wouldn't risk it if you're a novice. This is the perfect time (and excuse) to upgrade to an m-sport steering wheel! Before you ask more though:
It's your best friend around here!
JBD @ 100% | KW ST Coilovers | M3 rep. front bumper | 888Concepts AE Upgrade | GP Thunder 7500k fogs | Cyba 4" carbon tips | BSW Stage 1 | APEX ARC-8 W/ Michelin PSS | Ziza LED interior | Weisslicht LED side lenses | Sprint Booster | Euro side mirrors | M-Sport semi-conversion | Coded | LOTS of carbon fiber
10-29-2013, 04:09 AM | #6 | |
No 55mph
1622
Rep 8,476
> If your car does not currently have paddle shift - you can retrofit paddle shift. You will need:
> If your wheel is currently a Sport wheel as you stated - the airbag is correct & will simply transfer over, along with the front wheel trim (all though there are many choices of trim available-MSport, M3, Alcantara, aftermarket carbon fiber) > The multifunction button modules you have do not have the pin connectors that the paddle wires plug in to. There is a way to custom wire the paddles without buying the paddle shift specific MFB, but IMO that is 'mickey mouse' better off buying the correct MFB. My 09' did not originally have paddle shift, but did have Sport wheel. 1st I retrofitted a MSport wheel with SSG paddles (buying wheel, paddles, MFB, wire harness). Then I went to the M3 wheel with DCT extended paddles & carbon fiber Sport trim as shown below: Currently I have the MPerformance non-electronic Alcantara blue stripe wheel with DCT extended paddles & carbon fiber MSport trim. After the 1st install/retrofit, the other wheel swaps were quik & EZ - I can do a complete steering wheel swap in 15min now
F32 435ix//MGM//M Sport-Prem-Tech-Driver Assist-Lighting-Cold Weather-Dyn Handling Pkgs//M4 Black Lthr Int w/M4 Alum Blade Trim//HK w/Bavsound Stg3//763M//M4 Euro LCI Tails//M4 Mirrors w/CF Covers//AWCarbon CF F/R Spoilers-Side Splitters-Diffuser 6WB/ID6 HU+HUD/IND M4 Alcantara Armrest//PURE S2 Turbo//AA FMIC+DP//ER CP+TIC//3.5bar TMAP/TS DV//AWE Tuning Exh w/Blk Tips//Turner MS CF Intake//BM3 Cary Jordan Tune//MPerf Diff//PrecRW Ignition Kit
10-29-2013, 05:38 AM | #7 |
I used to be conceited, now I'm perfect.
571
Rep 1,826
Drives: 2018 M3 CS
I believe the paddles were a $100 option when ordering. In Canada anyway.
2018 M3 CS - Alpine White l l
"I used to be conceited. Now I'm perfect" |
10-29-2013, 06:27 AM | #8 |
40
Rep 2,431
Don't bother with the DIY update. You'll use them for a day or two and then forget about them. You known you can use the shifter already. How often do you find yourself shifting manually with that? If all you're looking for the look, it's a bit expensive and potentially damaging if you don't do it correctly. Just a thought before you go through this process. There are a lot of other upgrades you could do for the price.
My speeding isn't the problem. It's the Slow Folks ahead of me that cause accidents!
10-29-2013, 06:31 AM | #9 | |
40
Rep 2,431
Most excellent write up!
10-29-2013, 07:08 AM | #10 |
No 55mph
1622
Rep 8,476
^^^^ Thanx!
Yeah, In my case, I actually like using the paddles over the shifter. Drive around in DS all the time
10-29-2013, 08:48 AM | #11 |
Leeeroy Jankins
31
Rep 423
I agree there are other things to spend your money on. After you put a tune on the car you'll forget about those. Honestly I like using the shifter more than my paddles since it makes me feel like I'm actually shifting
e90 LCI w/ -= VRSF 7" FMIC =-
-= Cobb: Stg1 +FMIC Aggressive ST =- Last Install: BMS DCI + Caliper/Drum Paint "If you're not 1st, you're last" -Ricky Bobby |
10-29-2013, 09:20 AM | #12 |
571
Rep 1,826
Drives: 2018 M3 CS
Paddles are way better than the shifter in my opinion. You never have to take your hands off the wheel. I never use the shifter. And I have driven manual for all my previous cars.
"I used to be conceited. Now I'm perfect" Last edited by Kid Eh; 10-29-2013 at 09:28 AM.. |
10-29-2013, 10:53 AM | #13 |
Leeeroy Jankins
31
Rep 423
Personally I thought the paddle shifters attached to the steering wheel was a great idea at first... After tryin to shift multiple times while turning the wheel I miss the ones that were on my Infiniti that didn't move
